Oil & Fuel BX2660 cold weather starting problem
/ BX2660 cold weather starting problem #1
vstar1300
Kubota BX2660
StARTS BUT DOES NOT CONTINUE TO RUN. Temperature 4 above.
Changed air filter,fuel filters. Now not starting.Lacking fuel flow.
Do I have to prime fuel line? How?
/ BX2660 cold weather starting problem #2
the bx's are self priming . just turn key on for 10 secs and back of and on again several times. it will bleed out.if your having issues - i'd check the feul . just like mine earlier i had mine gelled up. i swear i added the white power service back in october and i see crystals in the tank. i added 911 and sure enough it ran nice again.
/ BX2660 cold weather starting problem #3
Yes, your engine is self priming. I would second on the Diesel 911... sounds like you have slush in the tank.
Thanks for the advise. Fuel indeed started flowing and engine started. I have lots of Diesel 911 in the tank so hopefully that should keep it from gelling.
Temperature -5F this morning so will wait to put it to work.
2021 CATERPILLAR 262D3 SKID STEER (A62129)
2021 CATERPILLAR...
2006 Ford F-150 4x4 Ext. Cab Pickup Truck (A59230)
2006 Ford F-150...
1995 John Deere 7400 (A60462)
1995 John Deere...
2005 MACK TRI AXLE DUMP TRUCK (A52707)
2005 MACK TRI AXLE...
2008 MACK CHU613 TRI AXLE 16FT DUMP TRUCK (A58018)
2008 MACK CHU613...
Hardee Tiger SH-360-CO (A60462)
Hardee Tiger...
