Oil & Fuel BX2660 cold weather starting problem
   / BX2660 cold weather starting problem #1
vstar1300
Kubota BX2660
StARTS BUT DOES NOT CONTINUE TO RUN. Temperature 4 above.
Changed air filter,fuel filters. Now not starting.Lacking fuel flow.
Do I have to prime fuel line? How?
   / BX2660 cold weather starting problem #2
the bx's are self priming . just turn key on for 10 secs and back of and on again several times. it will bleed out.if your having issues - i'd check the feul . just like mine earlier i had mine gelled up. i swear i added the white power service back in october and i see crystals in the tank. i added 911 and sure enough it ran nice again.
   / BX2660 cold weather starting problem #3
Yes, your engine is self priming. I would second on the Diesel 911... sounds like you have slush in the tank.
Thanks for the advise. Fuel indeed started flowing and engine started. I have lots of Diesel 911 in the tank so hopefully that should keep it from gelling.
Temperature -5F this morning so will wait to put it to work.
Volvo ECR235CL (A53317)
Volvo ECR235CL...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A57880)
2019 FREIGHTLINER...
2017 Ford Explorer AWD SUV (A56859)
2017 Ford Explorer...
2019 ALLMAND BROS, INC. ALLMAND BROS, INC. (A55745)
2019 ALLMAND BROS...
UNUSED FUTURE ML32 - 32" MINI HYD MULCHER (A52706)
UNUSED FUTURE ML32...
12' CONTAINER (A52706)
