Oil & Fuel BX2660 cold weather starting problem
/ BX2660 cold weather starting problem #1
vstar1300
Kubota BX2660
StARTS BUT DOES NOT CONTINUE TO RUN. Temperature 4 above.
Changed air filter,fuel filters. Now not starting.Lacking fuel flow.
Do I have to prime fuel line? How?
/ BX2660 cold weather starting problem #2
the bx's are self priming . just turn key on for 10 secs and back of and on again several times. it will bleed out.if your having issues - i'd check the feul . just like mine earlier i had mine gelled up. i swear i added the white power service back in october and i see crystals in the tank. i added 911 and sure enough it ran nice again.
/ BX2660 cold weather starting problem #3
Yes, your engine is self priming. I would second on the Diesel 911... sounds like you have slush in the tank.
Thanks for the advise. Fuel indeed started flowing and engine started. I have lots of Diesel 911 in the tank so hopefully that should keep it from gelling.
Temperature -5F this morning so will wait to put it to work.
