Good morning!!!!
   / Good morning!!!! #66,964
   / Good morning!!!! #66,968
There's a sanitary line in the lower lefthand corner of the above image (in the white box, sticking out from the wall) ... which I'll tap into for a drain and a utility tub. Need to punch a hole in the wall and install a door to get to it though. Probably close off the existing opening and turn it into a utility closet.
A couple of renderings, with some of the walls removed so you can see into the room:
Whoa, that's a pretty serious setup. You thinking about a business venture?
   / Good morning!!!! #66,970
Had no plans of going outside until it reach -0F but not to be,call from work asking me to come for problem once again it was costly human error :rolleyes:
No I plan on not going outside at all.
Enjoy the evening all.
1974 Ford F600 Grain Truck (A56436)
1974 Ford F600...
New/Unused CFG Industrial MH12RX Mini Excavator (A57453)
New/Unused CFG...
Lee Boy 250 Gal Tack Distributor (A53317)
Lee Boy 250 Gal...
2007 JLG 600S Manlift (A57453)
2007 JLG 600S...
UNUSED IRGC80 Battery Powered Golf cart (A55272)
UNUSED IRGC80...
2015 KOMATSU WA270-7 WHEEL LOADER (A60429)
2015 KOMATSU...
