Good morning!!!!
   / Good morning!!!! #66,964
   / Good morning!!!! #66,968
There's a sanitary line in the lower lefthand corner of the above image (in the white box, sticking out from the wall) ... which I'll tap into for a drain and a utility tub. Need to punch a hole in the wall and install a door to get to it though. Probably close off the existing opening and turn it into a utility closet.
A couple of renderings, with some of the walls removed so you can see into the room:
Whoa, that's a pretty serious setup. You thinking about a business venture?
   / Good morning!!!! #66,970
Had no plans of going outside until it reach -0F but not to be,call from work asking me to come for problem once again it was costly human error :rolleyes:
No I plan on not going outside at all.
Enjoy the evening all.
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2025 Mustang MP4800 2in Submersible Pump (A56860)
2025 Mustang...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
PENDING SELLER CONFIRMATIONS (A59575)
PENDING SELLER...
2006 Columbia Medical Transport Electric Utility Cart (A56859)
2006 Columbia...
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
