Good morning!!!!
   / Good morning!!!! #66,964
   / Good morning!!!! #66,968
There's a sanitary line in the lower lefthand corner of the above image (in the white box, sticking out from the wall) ... which I'll tap into for a drain and a utility tub. Need to punch a hole in the wall and install a door to get to it though. Probably close off the existing opening and turn it into a utility closet.
A couple of renderings, with some of the walls removed so you can see into the room:
Whoa, that's a pretty serious setup. You thinking about a business venture?
   / Good morning!!!! #66,970
Had no plans of going outside until it reach -0F but not to be,call from work asking me to come for problem once again it was costly human error :rolleyes:
No I plan on not going outside at all.
Enjoy the evening all.
MACK T/A DUMP TRUCK (A58375)
MACK T/A DUMP...
2020 FREIGHTLINER CASCADIA 126 TANDEM AXLE MID ROOF (A59575)
2020 FREIGHTLINER...
Kubota SVL 75-2 (A53317)
Kubota SVL 75-2...
40 (A52708)
40 (A52708)
New/Unused CFG Industrial QK18R Mini Excavator (A57453)
New/Unused CFG...
Deere 310L (A53317)
Deere 310L (A53317)
