Good morning!!!!
   / Good morning!!!! #66,964
   / Good morning!!!! #66,968
There's a sanitary line in the lower lefthand corner of the above image (in the white box, sticking out from the wall) ... which I'll tap into for a drain and a utility tub. Need to punch a hole in the wall and install a door to get to it though. Probably close off the existing opening and turn it into a utility closet.
A couple of renderings, with some of the walls removed so you can see into the room:
Whoa, that's a pretty serious setup. You thinking about a business venture?
   / Good morning!!!! #66,970
Had no plans of going outside until it reach -0F but not to be,call from work asking me to come for problem once again it was costly human error :rolleyes:
No I plan on not going outside at all.
Enjoy the evening all.
Utility Cart (A59228)
2022 Polaris Ranger 900XP 4x4 Utility Cart (A55853)
2022 Polaris...
Bigfoot Plastic Baler (A57148)
Bigfoot Plastic...
CFG Industrail MX15RX (A53317)
CFG Industrail...
2014 NISSAN NV CARGO VAN (A59575)
2014 NISSAN NV...
FORD F-250 CREW CAB TRUCK (A59823)
FORD F-250 CREW...
