Good morning!!!!
   / Good morning!!!! #66,964
   / Good morning!!!! #66,968
There's a sanitary line in the lower lefthand corner of the above image (in the white box, sticking out from the wall) ... which I'll tap into for a drain and a utility tub. Need to punch a hole in the wall and install a door to get to it though. Probably close off the existing opening and turn it into a utility closet.
A couple of renderings, with some of the walls removed so you can see into the room:
Whoa, that's a pretty serious setup. You thinking about a business venture?
   / Good morning!!!! #66,970
Had no plans of going outside until it reach -0F but not to be,call from work asking me to come for problem once again it was costly human error :rolleyes:
No I plan on not going outside at all.
Enjoy the evening all.
4ft Quick Attach Disc Harrow (A57454)
4ft Quick Attach...
2006 GMC W3500 Truck, VIN # J8DB4B16867021673 (A57453)
2006 GMC W3500...
(11) Assorted Steel Rims (A57454)
(11) Assorted...
1ft Bucket Smooth or Cutter Teeth (A57454)
1ft Bucket Smooth...
2015 Toyota Highlander XLE SUV (A56859)
2015 Toyota...
2025 Kivel 42in Forks and Frame Mini Skid Steer Attachment (A59228)
2025 Kivel 42in...
