Need help building a sprayer
/ Need help building a sprayer #1
Code54
Elite Member
Putnam Co. West Virginia
Kubota MX5100, Kubota BX25D,1957 Farmall Cub Lo-Boy Kubota KX91-3, BCS 853
We have a two story cedar home and every year we are in a battle with the carpenter bees and stink bugs. I have sprayed the house before and had decent success but at some points the house is about 22ft above ground level. I would like to build a gas powered sprayer. He is my requirements:
Run of a BCS 853 2 wheel tractor (13hp)
Can spray vertical up to 20 ft
Be able to fan the spray out and do weed control
I know I don't need big GPM, and I have a 15 gallon tank to use and all the metal to build the cart. My problem is I know nothing about pumps and what would work. I also am not sure how to adapt it to my BCS. Any certain type of gun/nozzle I should be getting?
The idea is we have a deck that wraps around 3 out of 4 sides of the house and it has ramps on it so I can easily pull the BCS right up and spray away. The back side is sloped but can get the BCS around there but need to spray about 20ft up and from 6' out (from the house)
Please give me any of your thoughts and ideas and how to do this and what exactly I need to purchase.
THANKS
Anyone know of any good sources of information on small sprayers and how much volume one needs?
/ Need help building a sprayer #3
Possibly take a look at fimco or one of the other small sprayer companies. I have a Fimco 25 gallon trailer type with electric pump. the hand wand will reach out 15 - 20 ft. Best guess on flow rate is around 2 GPM @ 60 PSI from this sprayer.
Thanks - Getting the right balance of GPM and pressure seems to be the tricky part. Im just not sure what the best mix will be...
/ Need help building a sprayer #5
No offense meant to oldnslo but Fimco sprayers are absolutely horrible. Bad design (many don't have a drain) and the electric pumps have to be replaced about every two years no matter what you do to winterize them. Also, they are horrible to clean. There are pockets molded into the bottom of the tanks where the mounts are. Those pockets hold everything and even with a sprayer nozzle on your garden hose its hard to get the crap out of those pockets because it just moves from one to the next one.
I bought one of these off craigslist for about $200 more than the cost of the Fimco and its 10 times the sprayer. It came with an orchard spay wand so you can spray about 30 feet in the air. I don't know if you have a Mills Fleet Farm where you live but they carry a really good selection of sprayer parts and you can get the hoses, wands, etc from them.
A gas engine with a roller pump will do everything you want. Might be more costly than what you want to spend though. The way I figured it, after replacing 3 pumps on the Fimco, I could buy a better sprayer for more money and in the long run it was cheaper.
/ Need help building a sprayer #6
Roller pumps are inexpensive,durable and easily build 150psi to 300psi with enough gpm to supply 1/2 dozen noozles plus extra to re-circulate/stir tank. TSC andNorthern Tool sell everthing you need build a spray system. If you want the best in the west,look at Hypro.
Thanks - I really don't know much about building one but already have a tank, a cart I can use and the BCS tractor to power it so.....
I have a small 12v sprayer but it doesn't build a lot of pressure for shooting up high so this is the reason I'm looking for another solution.
I take it I need a relief valve in the system somewhere, as well as a way to recirculate ?
/ Need help building a sprayer #8
Yes,you need a relief valve in order to control volume and pressure over a wide range of applications. A manifold include's a pressure regulation/relief valve with adjustment knob,outlet for 1 suction hose and 1 recirculation hose plus 1 hose to gun/nozzles. Go to Hypro site and let experts guide you.
Will do, thanks for the advice. I have to learn a lot before I start building anything.
Thats a BIG help, thank you for the info and the diagram is great. Figured it is a LOT cheaper to build one especially knowing I am going to only use it 2-4 times a year for an hour so 2 at a time.
THANKS
/ Need help building a sprayer #12
Now you know where and how to start with assembling a sprayer,let's talk about where and how you will be able to use it. Once herbicide has been run through the equipment,you shouldn't spray trees or anything you don't want to risk damaging. It's very difficult to clean all traces of chemical from the system so most people have more than one sprayer.
Thanks Jaxs. I normally only spray 2 chemicals. The one I use the most is a generic roundup to keep the weeds at bay along the driveway/roadway and a hillside. The second is bug killer to keep the wood boring bees (and those darn stinkbugs) off my cedar house. This is where the sprayer will really come in handy. The back of the house is on a decently steep hillside and the roof line is over two stores high. This is a difficult spot to spray the eves, you can do it with an extension ladder on the hill but need to drive anchors into the hill so the ladder cant slip out from under me. Needless to say I am not real fond of that method so thus the time has come to build a sprayer that will spray the eves from ground level safely.
We have extendable polls for cleaning the windows so I not too worried if I get some on the windows as I would be cleaning them afterwards anyway.
/ Need help building a sprayer #14
:thumbsup: You should be golden with those chemicals and where you are spraying. I only mentioned it in case you never had the subject come up in the past. I've battled wood bees for years in my out buildings and haven't found a way to totally eliminate them. There was a time my grandsons thinned them out with badminton rackets to collect $0.25 each bounty.
That also is not a bad option! LOL
/ Need help building a sprayer #16
As has been said roller pump matched for the power source rpms can do this. But for that reach do you have a pressure washer? You may be able to use it with siphon hose as you do with chemicals to wash house. Never had tried it but know of no reason it will not work if you can get correct ratio on the chemicals. Do use protection with what ever system you use.
Interesting idea you have there. Have a 4000 psi belt drive PW and 18' extension wand for the pressure washer. Getting the ratio right would be a trick but may not be a bad idea....
/ Need help building a sprayer #18
You would need to make sure that the seals in the PW pump can handle roundup or whatever else you plan on putting through it.
I would also suggest using a 12v bilge pump to supply the water to the PW pump unless it is rated to draw from a tank.
Aaron Z
Thanks - I am running a belt drive so it is rated to pull from a tank (I often use a 275 gal. for places it is hard to get a hose to). I was thinking I would use a high pressure injection on the output side of the pump to protect it. Just not too sure I can control the mix and maybe a bit unwieldy.
The other idea I had was using my extended pressure washer wand with a sprayer to get it up higher while keeping it under control.
Lots of good thoughts and ideas coming up from everyone.
2015 Ford Transit 250 Cargo Van (A61573)
2015 Ford Transit...
JOHN DEERE 8330 TRACTOR (A63291)
JOHN DEERE 8330...
1996 RWAY BELLY DUMP (A63569)
1996 RWAY BELLY...
2013 HINO CONV. ICE CREAM TRUCK (A63569)
2013 HINO CONV...
2013 Ford F-450 Reading Service Truck (A61573)
2013 Ford F-450...
INGERSOLL RAND  G25 GENERATOR (A58216)
INGERSOLL RAND...
