Anti freeze
/ Anti freeze #1
aspg4
texarkana, ar
Massey Fergerson 135, TYM 554
What is everyone's opinion of which brand of anti freeze is best (for 99 Chevy pickup) and for the various tractors. Are all the brands about the same?
/ Anti freeze #2
I use Napa products whenever possible because I get a discount at that store.
/ Anti freeze #3
To me antifreeze is antifreeze. You got straight antifreeze and a 50/50 mix. Brand names dont mean much to me. I get mine at Wal-Mart. I just put it in and mix it until I get a solution that will test to about 40 degrees below zero Fahrenheit.
/ Anti freeze #4
Agree that they all have to be pretty much compatible as if one was demonstratively superior they would lord it over the others in adverts. Don't buy the pre-mixed, that's like paying 7.99 a gallon for distilled water, which is .89 at the grocery store (or a couple aisles over, if you're there).
/ Anti freeze #5
I go with the dealer's brands in our cars and pickups, as I've gone with the 10 year changouts. Need to be sure you get stuff that's fully compatible with your engine metallics.
For my JD, I've just bought their coolant and change it about every other year, as it's an easy thing to do.
Not sure what I'm going to do about the antifreeze in our Central Maine diesel generator. When I decide to change it out in around 6 or 7 years, I'll probably order from them. Not looking forward to it because containing the antifreeze may be a problem where it's located. Used an oil extractor for its first 50 hour (after about 4 years) oil and filter change. No mess with that. May change out the radiator hoses on it then. They don't impress me as long lasting hoses like the ones were on our 1983 Benz that were still good at 26 years of age.
The additives in the antifreeze have to match the metallics in your engine and radiator system. Not sure Prestone and Zerex are a good fit any more, particularly for 10 year life.
Ralph
/ Anti freeze
No they're not the same and shouldn't be mixed. For GM products after 1995, you're supposed to use the Dex-Cool stuff. Many don't like it, including me, but I'll leave that decision up to you.
For tractors, it depends on diesel or gas. If diesel, it will depend on if you have liners or not, and wet or dry liners.
Check the specification of the antifreeze you're interested in. If it meets the ASTM-3306 specification, it's good for any gas application and light duty diesel use. The best is to use a product that meets ASTM-6210. That specification is for heavy duty diesel service. That spec is common enough that you shouldn't have any problem finding something you like. If you are going to abandon Dex-Cool or any 2 year green stuff, do a through flush of your system.
When Dex-Cool first came out years ago I decided to change to it in my old Buick. Apparently I did not get all the green antifreeze out, and when the Dex-Cool mixed with what was left of the green antifreeze it stopped up my heater core so I was told by my mechanic. It took many flushes to get it unstopped.
/ Anti freeze #7
I dnot know, been running Wal-Mart antifreeze in everything for years. Pick-ups, tractors, van, cars, you name it. Been getting along just fine with it. One tractor is 75 + hp, I think that would qualify as a heavy-duty diesel. It also goes in my 730 John Deere and use to use it in 930 case. My van is 2001 gmc and my pickup are for. I put in my 1531 massey ferguson compact tractor. To me antifreeze is antifreeze. Been running that Wal-Mart (super tech) green antifreeze in everything for years and get along just fine. And I save money over that supposed to be better high dollar stuff.
/ Anti freeze
Flushing is super important when changing types of antifreeze. I don't know how old the old Buick was, but a problem with Dex-Cool is that it has to be in a completely sealed system, including the overflow tank. Dex-Cool does not mix well with air. The overflow tanks on Dex-Cool vehicles have a sealed and pressurized tank that doesn't let air in.
The Buick was a 1994 Roadmaster. Finally used powder dishwashing detergent to clean the system. Put the powder in, and drove the car a day or two and then flushed again really well. That did a really good job cleaning the system, and never had any other problems.
/ Anti freeze #9
As has been stated, Dexcool is what GM specs today.
For gas engines, I usually use Prestone. Any quality modern (HOAT) coolant should be good for 5 years or 250k km in gas applications.
Diesel, I use Delo, basically what is used in OTR (highway) tractors and other heavy equipment - these modern organic acid coolants are long life and distance in heavy applications, somewhat less so (but still very long) in light trucks/tractors. Old school diesel coolant needed SCA or DCA added and tested, to deal with potential cavitation corrosion - been there, can do it if needed, but much prefer the newer diesel coolants....
I use distilled water when mixing.
Any spec meeting name-brand coolant should work fine; just don't ignore the coolant manufacturer's time/mileage limits - they know what they are talking about.
Rgds, D.
/ Anti freeze #10
I was thinking the same thing. Our motorhome diesel uses what is called SCA Pre Charge. My Kioti manual just says anti freeze...no mention of the SCA type.
/ Anti freeze #11
Depending on design specifics, diesels can be very susceptible to cavitation corrosion, or, not so much. While relatively rare, I've seen references to cavitation corrosion occurring in gas engines too.
https://www.engineaustralia.com.au/~engine/sites/default/files/SB011.pdf
Video: Having Issues With Cylinder Liner Cavitation
Any reputable engine manufacturer should be issuing correct specs; see what they currently recommend (updates are often back-spec'd to older equipment - worth checking).
I like the performance of the modern diesel coolants (time/distance/nothing to add), and don't mind paying the slight premium (if any) to get that performance. My local International dealer sells the Delo coolant very inexpensively - that's not something I get to say often in Canada.....
Rgds, D.
/ Anti freeze #12
I switched to Final Charge for everything. I got tired of partial jugs of different types that may or may not be mixed. Now I use Final Charge, which is a premium antifreeze that doesn’t require flushing when converting to it (although I did).
/ Anti freeze #13
Never heard of this dex coil stuff. My van is a 2001 gmc and it runs just fine on Wal-Mart antifreeze. Now my wife suv, that is a different story. It has got some orange colored stuff in it and it is way more expensive than regular antifreeze. The dealer says that is what it needs, but I wonder. Somebody always says you need something that is twice as expensive as regular stuff.
/ Anti freeze #14
I use prestone in the Jeep and mix it 50/50 which will give me freeze protection to -45F and anti-boil to 260F.
I don't know what is in the Kioti, it is OEM stuff and due to be changed this spring. I will make it good to -45F as well.
/ Anti freeze #15
The one thing I absolutely despise about dexcool and I just learned this recently was the way he reacts with a leaking head or gasket. It doesn’t make the traditional milkshake that you’re going to see but rather turns into a sludge which is a lot harder to see and notice deal with. Maybe it keeps from polluting the oil which would hopefully keep the engine from burning up. And with all the legendary had problems in leaks that those Vortech engines are famous for I’m not Impressed by antifreeze that hides the issue if it’s a small leak like they’re so prone to. I’d really like to know chemically what makes that stuff so special .
/ Anti freeze #16
I forgot everything I ever knew about this HOAT and OAT stuff.... but I do recall it being important. And I do recall keeping my 7.3L navistar properly checked and additive levels cared for. Its not as simple as just "anti-freeze" thats for sure.
/ Anti freeze
I decided to go with Valvoline Max Life antifreeze. The label says it can be mixed with any color antifreeze, good for all makes with over 75000 miles, and good for 5 years/150,000 miles. Could not find it locally, and had to order from Amazon.
/ Anti freeze #18
With diesels, especially the 7.3s and 6.0's, using ELC or Ultra ELC is extremely important. For the 7.3s it's for the anti-cavitating properties. For the 6.0s it's for the lack of silicate (i.e. plugged up oil coolers).
Extra Life Coolant (ELC) is defined as any antifreeze meeting the CAT EC-1 spec.
It's the only AF I'll use on my F350 PSD, Kubota L4330, RTV and ZD326 ZTR.
John Deere X380 Riding Lawn Mower (A66285)
John Deere X380...
2023 Case TV450B (A62177)
2023 Case TV450B...
Kubota V3300-T-E2BG Turbo Diesel Engine - 3.3L - Pump Takeout - Tier 2 (A63689)
Kubota...
Grain Drill Hopper (A64127)
Grain Drill Hopper...
2015 Caterpillar 308E (A64126)
2015 Caterpillar...
1970s John Deere 350B Dozer — Only 2,525 Hours — Single Private Owner 40 Years — Light Use, Ready to Work
1970s John Deere...
