Offset Flail Ditch Bank Mower
/ Offset Flail Ditch Bank Mower #21
I hoped that would help. Key is measure the tractor rear from PTO to outside of tire, then confirm with the selling dealer that at full offset the hinge point is beyond the tire. Remember you can always gain a few inches by offsetting the 3pt arms too. On my tractor it gains me and extra 3 inches when hooked up. The Giraffa is a heavy duty model, several grades up from mine.
Happy Holidays
Keith
/ Offset Flail Ditch Bank Mower #22
Powerscol,
Why is it essential that the full rear tire be on top of the bank? I often mow with my rotary cutter with the rears part way off the bank (of course in that case I'm mowing the level part, not the bank).
What happens if the tire actually rides part way down the bank, as one might do to make a second pass?
My concern is that the offset models I'm looking at seem to only offset about 25" from the centerline, but it's only 24" to the inside of my rears. I can get a bit more by offsetting the arms as you point out, but not likely enough to clear the outside of the rear tire, which is about 34" off the center line.
Powerscol,
Well, the embankment could collapse under the weight to the tractor...probable rollover
or
You get a bit too close...and roll over.
It'll depend on the make up of the embankment...all dirt and downslope, use caution and stay away as far as possible.
In my circumstances, the embankment runs along a road and is upslope...minimal chance of rolling the tractor. Even if I operated on the road and mowed the embankment downslope, little chance of rolling as long as I'm watching how close I get to the bank...I'd be more concerned about traffic on the road.
/ Offset Flail Ditch Bank Mower #24
Powerscol,
Roy has mentioned a few. If you get over on the bank at full extension, depending on the weight of the mower it can take you further (sliding on the grass). This has happened to me several times, especially when cutting thick growth as there is a drag on the tractor from the mower head when it is extended down the slope.
If you look at models with an outboard gear box (gear box on the end of the unit) they will reach about 8" to 12" further. My roadside ditch banks get very steep, so I needed to be sure I stay on the flat as much as possible. Its the one time I wear my seat belt. I always have the ROPS up.
Look at some of the Maschio models. I think the Giraffetta SE model like I have will reach, but give them a call.
There are others such as Peruzzo too. What I did was take measurements on the 3pt with a normal 28" arm width (Cat 1 dimensions)and set it as far right as I could go and took measurements from the draw bar to the offset center, outside of tire, etc. Then made a sketch and imposed the measurements for the various mowers (converted metric to inches) that I was looking at. I did have to call the dealers to get the measurements to the gear box from the end to correctly draw things up. Each unit varies considerably depending on the swing are geometry. Generally the longer the arms the further it will reach if they keep the pivot point as far the the left side of the mower body as they can. With a outboard gear box the can shift it left more. There is one orchard mower in Europe, that has the pivot point centered on the mower head so it can swing either way Takes 3 remotes to run.
Hope this helps
/ Offset Flail Ditch Bank Mower #25
Thanks, guys.
I looked at the Maschio models, but I don't find anything under 60", which is too much for my tractor. I'll call them this week and see what they say.
I like the Del Morino but same issue - nothing offered under 60". They make a 41" one but it's not listed on the US dealer's site.
/ Offset Flail Ditch Bank Mower #26
I talked to Tractor Tools Direct, the dealer for the Del Marino that Roy provided the link to above. My concern with them has been that they offer only the 62" model, which is too big for my tractor. My conversation was encouraging.
The salesman claims that just today they were talking about offering smaller models. According to the manufacturer's website (in Italian) they also make 52" and 42" models. He seem interested in seeing if they can offer me one of the smaller models. We'll see.
I think Roy's right that Del Morino is an attractive choice. I expect more reliable quality than the China-made brands, and the price is attractive relative to the other Italian brands. What TTD is offering is actually the manufacturer's heavier duty line - they also make a lighter one.
One concern is as I read the specs, it has only about 18" from the centerline of the tractor to the near end of the mower at full extension.
/ Offset Flail Ditch Bank Mower #27
What is you tire offset outside to outside, and if they could tell you the distance from the end to the hing point it would help you. 18" is more than a lot out there.
/ Offset Flail Ditch Bank Mower #28
The outside of my tires are 34" from the centerline of the tractor - or 68" from outside one tire to the outside of the other.
They don't show the dimension from the centerline to the inside end of the cutters so you have to work it out. The diagram shows it's 70" from the centerline to the end of the mower fully extended. Take off 52" working width and you have 18" from the inside end of the cutters to the centerline. Actually it's a bit less than that because there's an inch or two past the end of the cutters for the outboard bearing and end wall.
/ Offset Flail Ditch Bank Mower #29
You need to find a mower with an outboard gear box. Have you talked to Iowa Farm Equipment? They were a great help to me. I am almost as wide as you are.
Happy Holidays
/ Offset Flail Ditch Bank Mower #30
I tried to but so far they haven't returned my phone call. I did get an email from them that I found a little disturbing, and their prices are pretty high, seems to me.
/ Offset Flail Ditch Bank Mower #31
I did today talk to Iowa Farm Equipment, and as powerscol said, they were helpful. At least I think so, but now I'm re-thinking my near-decision. :(
I had been thinking of the offset flail as a ditch and edging mower, intending to continue to use my 5' Bushhog rotary cutter as my main mower. But IFE pushed me to think of it as a replacement for the Bushhog. That means re-thinking which one I want.
I've been looking at some 47" models, but leaning towards the Del Morino 52". It's their lighter duty line which is attractive because I'm thinking I'm pushing it on our hilly property with my JD 870. It's rated at 28hp and weights 2600 lb. plus 500 lb. or so from the loaded tires.
IFE says I can successfully run their 60" Fox Cross, which weighs 640 lb. I'm not sure about that.
But if I could that would let me abandon the 20-year old Bushhog, solving a storage issue and eliminating the need to change mowers when mowing. I know you flail fans would go for that. But do I have enough tractor to pull that off?
If it helps, here are a couple of photos of the property: The View - Part 2
My iPhone says some of that is 20 degress or steeper, which is 36% grade.
/ Offset Flail Ditch Bank Mower #32
If you going to mow the side hill with it your going to want to invest in a tilt meter or just plan on mowing up and down and having suitcase weights and set of dual tires(if useable) and a front suitcase weight frame available for it.
/ Offset Flail Ditch Bank Mower #33
I mow the steep parts up and down now (except for bottom edge where I have turn around), and use suitcase weights.
How would a tilt meter help?
Is a flail more hazardous on a side hill than a rotary cutter? I've seen dire warnings about them on side hills.
I'd be more concerned with a rotary cutter, if mowing across the slope. The tail wheel can pivot and the cutter may pull the tractor with it. I've experienced this, but it wasn't a steep slope. The tractor was a Deere 790 (about 2200-2300 lbs. when the loader was removed (had 4 42 lb. suitcase weight on front to counter the cutter's weight), the cutter was a 5' Land Pride medium duty...I think it weighed a bit under 600 lbs. which was about 26% of the tractor's weight.
/ Offset Flail Ditch Bank Mower #35
I just placed an order with Iowa Farm Equipment for a Peruzzo Fox Cross 1600 - 60" cut.
I decided on a 60" model because I expect I'll find I will use it for all my mowing, replacing my 60" Bushhog rotary cutter, and I think that's the biggest my tractor will handle.
I decided on the Fox Cross in part because it's relatively light for a 60" which I think is wise for my situation. More importantly, best I can decipher the specs, it has more offset than the others in it's class. It reaches 53" past my wide-set tires (a bit more if I pull the 3-point hitch to the side as I've always done for my rotary cutter). And it reaches around 27" from the center line of the tractor to the inside cutting edge, so it will work better over the side of banks.
Thanks, I think, Roy, for bringing up this topic. At least my wife won't have to go Christmas shopping for me. :)
Thanks also to powerscol for all the helpful advice.
/ Offset Flail Ditch Bank Mower #36
I also have an embankment on my property. Trouble is, it goes up to the road with a guard rail at the top......I am also a cheap SOB, so this is my solution...it also will go down into the ditches etc.
/ Offset Flail Ditch Bank Mower #37
The tilt meter was designed and based on the design of the protractor to measure angles and mounted on the hood of the mule shows the operator the exactly what the angle is that the tractor is operating on as the hood of the mule is positioned at the same angle that the front and rear axles are resting as they move provided the hood is not damaged and unhinged of course.
The tilt meter also has the danger area/angle for a roll over to occur outlined in red(if I remember correctly) on both sides of the protractor in relation to the actual zero angle of the protractor that the tilt meter is based upon. The general rule was 15 degrees maximum angle of slope for safe operation of a riding lawn mower mowing across the slope in this example.
A larger mule will have the effects of gravity and the angle of tilt compounded higher as it is taller than a riding lawn mower or garden tractor and the angle can become greater simply due to the tire size of the mule.
Any side hill is dangerous to operate on unless you have a side hill tractor,combine etc.
Do you remember where you read that about using a flail mower on side hills? The thing is that the entire mower stays on the ground riding on the rear roller and it is not more dangerous to use simply because any and all of the mowed brush/grass passes over the flail mower rotor and then falls to the ground.
If you turn a rotary cutter or for that matter any long implement on a slope it may end up lifting in many cases simply due to the length of the of the implement and the laws of physics affecting the overhanging implement.
The flail mower is not dangerous in using it on a side hill of 15 degrees as the mowers geometry is smaller in length and it is less effected by a turn and will weigh more in most cases and will have much less of a tendency to lift up as long as the tractor is operated properly AND SLOWLY in making turns if the operator intends to mow on the side hill. I always mowed up and down with ours anyway as it was heavy and a towed motorized unit.
Ideally you want to mow up hill in reverse and then down hill anyway with a steeper slope to overcome the potential for the potential of a side hill roll over accident.
Going from memory here:
The only way to overcome the problems with a mule with a higher center of gravity is to purchase smaller rims and tires if available to reduce the height of the center of gravity which is the rear axles center line height from side to side through the axle shafts.
Adding:
A low profile orchard and vineyard mule is perfect for mowing in many conditions and slope angles due to the nature of vineyards and orchards which are on slopes in many cases.
Going a bit slower is always a good idea in slope mowing anyway as the side hill maybe damp and the mule can slide sideways and scare the operator while working possibly causing the operator to overcompensate when controlling the mule while working.
Do not worry Terry you can mow safely with the flail mower and your rotary cutter will be so disgusted it may try to hit the flail mower with stones and by then you can sell it and have more room to store things.
Please let us know when you have received the the flail mower and then I can officially welcome you as the newest lifetime member of the Flail Mower Nations from the Great State of North Carolina.
/ Offset Flail Ditch Bank Mower #38
I've mowed some ditches with my old L3200 & 719 flail that were so steep the high side tire lost traction. I was just inching along in the ditch with the offset on the uphill side. I left it in 2wd to give me an earlier warning on problems. When the high side tire would start spinning I knew it was to steep to continue. I'd back out using 4wd if necessary & avoid that section of ditch until it got less steep.
/ Offset Flail Ditch Bank Mower #39
I understand how a tilt meter works. My question is how does it help? Certainly red lines drawn by a manufacturer with no idea what my tractor is and how it's configured are worthless. How do I know what the real limits are? And how is tilt meter better than measuring the slope directly? I know my steepest areas are 22 degrees already.
Interesting theory, but around here we consider 15 degrees "level." I've been mowing this field for 20 years with a rotary cutter. I mow the part below the fence sideways because there's not other way to do it. It's 20 degrees. I know that at a rather flat 12 degrees my tractor crabs enough that I have to run the front tire at least a foot up the hill to keep the mower from leaving an un-mowed strip.
My question was how will changing to a flail change anything? Why do I suddenly need to buy a tilt meter and dual wheels, and change my mowing pattern?
No, a long implement is more stable if anything. It's not overhanging. It's riding on its own wheel. Why on earth would it lift?
Actually, the usual way is to set the rear tires out wider and load them or add wheel weights.
Do not worry Terry you can mow safely with the flail mower ...
That's not what you've been saying. You've been saying I have to make all sorts of changes to make it as safe as the rotary cutter I've been using for 20 years.
You have to determine what you and your 870's capabilities are. The tilt meter just gives you an indication how close you're coming to those capabilities.
As at least one poster wrote...15 degrees is what the manufacturer (of the tilt meter) has determined to be the beginning of the danger zone for a typical tractor. There are studies, by both tractor manufacturers and, IIRC, some agricultural institutions; of tractor slope capabilities. Obviously, not every iteration can or will be checked...so, it's a guide.
As I'd written in the beginning, you (and any other tractor operator) have to determine yours and your tractor's capabilities...hopefully without rolling over!
2019 CATERPILLAR 326FL EXCAVATOR (A60429)
2019 CATERPILLAR...
2018 VERMEER BC1000 XL PORTABLE WOOD CHIPPER (A63276)
2018 VERMEER...
2018 CATERPILLAR D6T XL HIGH TRACK CRAWLER DOZER (A62129)
2018 CATERPILLAR...
Magnolia Trailer with Adams 25 Ton Fertilizer Tender (A63688)
Magnolia Trailer...
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A63118)
2017 Yale GLC050VX...
Danuser 3pt Auger (A64119)
Danuser 3pt Auger...
