Ice Scraper attachment
/ Ice Scraper attachment #1
450
New Member
Fairbanks, Alaska
Branson 3725CH
Has anyone used a ice scraper attachment with there tractor? Just wondering if the loader arms on the FEL could handle the task. They make several different one with skid steer attachment. Thanks for any info.
/ Ice Scraper attachment #3
I drop the rippers on my box blade to cut grooves if I get an icy spot. Never seen or heard of the scraper until I watched the YouTube video above. Seems awful specialized.
They work really well removing hard pack. I have a couple of co-works that use them on there bobcat's for removing hard pack. Here in Alaska we wind up with a lot of hard pack due to the extreme cold. There is also a lot of money to be made removing hard pack especially right before break-up.
/ Ice Scraper attachment #5
Looks like it would work well for hard packed snow on pavement. Not sure if you would find lots of scratches in the spring though. For a gravel driveway I think before the frost sets in you are going to be digging up lots of dirt, once the frost sets in it's just not going to get under the ice to break it free.
/ Ice Scraper attachment #6
The other thing they do in my area is use blades that have carbide tipped “fingers” that make grooves in the ice on the roads. That seems to work good but I don’t know if a little CUT FEL would have the down force.
Crazyal,
When it is used up here the ground is frozen and yes it will get up under the ice and pop it loose off of gravel. I now the attachment works great but was wondering about the loader arms on a tractor. My 2 co-workers made over $30K last year on the side removing hard pack but they both have bobcat skid steers.
/ Ice Scraper attachment #8
At 30k in a winter I’d at least purchase it and see. The little CUTs aren’t typically designed for that type of abuse. But heck if the thing costs 3k you could do a few jobs to pay that off and decide if your machine can handle it or if you need to sell the scraper or buy a SkidSteer.
/ Ice Scraper attachment #9
I used an old 3ph one way disk. Could have been fifty years old. Maybe Six Disks 24" or so in diameter. It did a wonderful job scouring the ice. Unfortunately, a cotter pin came out, causing one end to come loose and tore the bearing housing apart on the other side, so I scrapped it. Shame. It was good to have around.
/ Ice Scraper attachment #10
i saw where someone tacked an old crowbar to the box weight so they could rip the ice, I welded a high grade bolt to one ripper on the box blade a few years ago,, and sharpened the end,, worked great
/ Ice Scraper attachment #12
Never used one but they are made for SS and tractors. I would imagine it would be useful for breaking up hard pack snow / ice from blacktop. May not be so good for dirt / gravel roads.
Here's a site with a video of one in action.
Ice Scraper Attachment for Tractors, Skid Steers & Loaders Conterra
Do they make one for 3PH? Might be a problem with no down pressure. Looks like the blade notches would help especially if the front of the blade was tilted down slightly.
Sure works good on the skid steer as seen in the video.
/ Ice Scraper attachment #13
How about using a ratchet rake? Worked on my gravel driveway one year when it iced up in a few low spots.
/ Ice Scraper attachment #15
I used an old 3ph one way disk. Could have been fifty years old. Maybe Six Disks 24" or so in diameter. ....
Pulling your garden/field disks up and down the ice/hardpack to break it up sounds like a good, economical decision.
The thing up here is, people want the hard pack removed not scraped/grooved. It makes breakup a lot easier without all the slush/water. Also the round disc is dished not flat. I had also thought about making one for the 3-point hitch but I don’t think it would work that good without any down pressure.
/ Ice Scraper attachment #17
You could use this principle for downforce.
/ Ice Scraper attachment #18
It’s hard to tell what I’m looking at with regards to down force but I’d love to find out where to get blade edges like that!
I also thought they made something for 3pt augers that applies down force.
/ Ice Scraper attachment #19
Looks like the arm between the 2 lower points of the 3pt pushes on the bottom of the draw bar
/ Ice Scraper attachment #20
I live in rural eastern Canada with long steep country driveway to remove snow. A few times a year I have to go sand them. I would like to have an option to at least scratch up the surface so it is no longer slippery. I bet a racket rake would work good. originally I was looking more like a spring loaded thing in the event it hit something solid it would kick up and not hit some hard on the loader but I guess if I took my time the racket rake would work.
2007 Ingersoll Rand P185 S/A Towable Air Compressor (A59228)
2007 Ingersoll...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A59231)
iDrive TDS-2010H...
2008 CAT 305C (A53317)
Big Tex T/A Flatbed Trailer (A56857)
Big Tex T/A...
Craftsman 42 Inch Riding Mower (A57454)
Craftsman 42 Inch...
2019 PETERBILT 579 TANDEM AXLE SLEEPER (A59905)
2019 PETERBILT 579...
