Which grapple?
/ Which grapple? #21
Pokeboater said:
I have the Anbo grapple. It worked great at first. I would grab a pile of debris and would notice the tines would bend, but then they would spring back to the original position. After a few months, tines started bending and would not spring back and would keep the unit from closing. Being under warrantly, I called Anbo and they were pretty obnoxious about it. At first they told me my tractor was too big for the grapple (a JD 4720, funny when I called originally to get info on the unit they said it might be too big for the tractor). Then they basically said they weren't going to cover it period. I got my dealer involved who techinically bought the grapple from them. Long story short, the dealer heated and bent the tines back and put in steel reinforcements. I had to pay about half the cost (a couple hundred bucks) and either Anbo or the dealer ate the rest. Anbo specifically said that they denied any liability whether they paid any of it or not. After heating the tines they, of couse, lost their temper and most of them are bent again. Unless you are doing really light work, I'd look at another brand that has stronger tines.
From looking at Hammy's pix, it looks like a 2 X 3/8" flat bar across those tines near the tip would solve the bending problem. I'd cut a notch on the back side so it would be flush to the back edge. Any kind of side load will bend that much tine hanging that far in the wind. I had to add a gusset to the tip of my grapple's claw for the same reason, but the tines on the Millonzi are braced pretty well.
/ Which grapple?
Redrocker,
I have had no issues whatsoever with the AnBo grapple. There are different models. I'm not sure which one Pokeboate had but I'm guessing it was their light duty model.
I think I would be hard pressed to destroy this one. The way they constructed it is excellent.
Now the ATI bucket grapple was a different story...
Craig
/ Which grapple? #23
Hammy said:
Redrocker,
I'm not so sure. The issue with these wide top grapples is that you can crush an asymmetric load in such a way that it would torque the top piece. Imagine having a boulder on the left side of the grapple with only air on the right side. The two hydraulic arms, mounted at the far left and right, would try to close the grapple and the left one would stop when it hit the rock but the right side would continue to try to close with 3000lbs of pressure. That would twist the upper grapple arm. I suspect that is what happened to Pokeboate's grapple which was likely the same model you have given his tractor size.
/ Which grapple? #24
air19 said:
Island,
I have read many of your grapple comments. Your latest replies on this thread bring up a couple more questions before I make my decision.
I'm about to trade my old Kubota M5030DT in for a new Kubota M7040. I want a grapple to move a lot of logs around and push back the edge of my fields where I need to grub out rocks, stumps. Harder work than just brush pile maintenance.
I wanted to ask you about your latest comment about 1 top arm vs. 2, where you argue that 1 is always best. For all my log loading work, I thought 2 would be much better to keep the log steady, with less tendency to tip.
I agree with all your comments about light weight, but with all my log moving, I am looking for a manufacturer who will beef up the sides where I expect most of the log tilting stress will occur. Would you still recommend the lighter grapples for a tractor as big as an M7040 given my hard use?
I'm looking at three options:
1. WR Long's new RBG2 60" with two arms, weighing only 365 lbs. Seems like a great combo, but maybe too light duty for my tractor.
2. Wildcat's 60" root grapple at 635 lbs.
3. A modified Millonzi 60" LD with beefed up sides increasing the weight to about 500 lbs.
Thoughts?
I understand that it seems logical that two arms would hold a log more securely than one. However, remember that you are not really holding the log with just the upper arms but rather by pressing the log into the bottom of the grapple. A one arm grapple therefore has essentially three points (top, left and right) and three points is pretty good for picking stuff up and holding it securely. Regardless of which style grapple you get you will always want to grasp a log or group of logs so that they are balanced left and right anyway. Otherwise your tractor will be unstable and you'll put undue stress on the FEL. If the load is balanced, you are really not needing that much force to hold the load in place. I have simply never had an issue getting adequate purchase on a log or tree.
As I don't find the lack of two arms a disadvantage, it is fair to point out the advantages of one arm. As I've noted before, it allows you to "surgically" grasp something right in front of you and automatically have the load balanced. If you grab something with one or the other of the two grapple arrangement you need to reposition if the load is heavy. One example is when you put the bottom tines under a bush that you want to pull out. With one upper jaw you leave the jaw open, stick the grapple under the bush by driving forwards with the lower tines pointed just a bit down and then curl to pop the bush out. Once it comes up you simply close the grapple and you drive away to the burn pile. See photos. With a two jaw grapple you'd do the same first steps but then you'd have to reposition the load, probably even working around to the side of the bush in order to get the root ball under one grapple arm and the body of the bush under the other. More complicated but if you don't do that then you've got an asymmetric load.
I suspect your loader is about the same capacity as my new loader. I've stuck the grapple under things that are heavy enough that I've lifted my rear wheels off the ground (4000lb tractor and 600lb mower). Did not bother the grapple at all. I don't think logs are really much of a challenge for grapples. Construction debris might be but brush and logs just don't seem to fare well when they challenge even 3/8inch steel. I haven't had any trouble lifting pretty big rocks or slabs of concrete either. The main thing that will damage a grapple is an asymmetric load or a sideways load. The point I keep raising is that I think having two upper arms makes it much more likely that you'd have an asymmetric load.
Regarding the grapples you listed: I've always liked the WRLong clamshell. It's cute and for brush alone would be the best choice. For using the grapple as a sawhorse to hold trees while you trim or cut them up it would also be nice as it closes more tightly than a traditional grapple. For lumpy things I think it would be fine but it looses it's advantage over a single arm traditional grapple. It is not as effective at being able to use the upper arm "surgically" because the upper arm is too wide to do that except by using one end which gets you back to the asymmetric load/torque issue again. I find that being able to come over the top of an object and use the upper arm to dig it out or just clamp down right in the middle is very useful so I'd miss that with the clamshell type. Wish I had one of each.
I don't know the Wildcat but based on the weight I'd say that it is too heavy or at least heavier than optimal for a CUT. If you are slamming the thing blindly into piles of construction debris with a big skidsteer or , worse you have an hourly employee who is doing that for you, then maybe such an overbuilt grapple makes sense. Lifting logs and tearing out brush or moving rocks just isn't that tough on a decent grapple so I wouldn't advise spending the extra money.
I've never seen the 60" Millonzi but I believe it has exactly the same construction as the 48" I have except for the two upper jaws. Enough written about that issue already.
I have over a year's experience and probably 70hrs work with my 48 on a smaller tractor and now about 5 hours or so with it on the DK40se. If I were to buy another right now I'd just get another 48" "light duty" from Millonzi. I just haven't seen anything that comes close in bang for the buck and I haven't ever felt there was some other grapple feature or type that would do the all around work I do any better. I'm not sure I'd even want to get it customized by beefing it up as that would make it heavier. Maybe, maybe using 1/2 inch but the weight penalty would probably deter me. I don't see the advantage of T1 steel though it is clearly stronger because it limits your ability to make repairs by heating and bending. Really, I'd just get another stock 48 LD and save the rest of the money for a new toy.
/ Which grapple? #25
Thoughts?
Long has a RBGD-60 that is the heavy duty version of that, which has the 2 arms.
/ Which grapple? #26
I have a Kubota M5040 with a 60" AnBo. I've used it for clearing brush, moving boulders, stumps, and hauling logs. With about 50 hours on it the only damage seems to be the loss of the "AnBo" decals and some paint.
/ Which grapple? #27
talltale what model is your AnBo ? I think your tractor is similar to mine (M5140) in size and HP I am considering an Anbo .... Thanks
/ Which grapple? #28
I have the Land Pride SGC 1560 grapple with the W R Long third function setup. It a heavy rock grapple and has stood up well in the time I've had it.
I've been up and seen ANBO grapples several times. They are an EXCELLENT piece of equipment also and can be built up just about any way you could want.
The ANBO facilities are about 70 miles north of me. I chose the Land Pride because dealership gave me a great break on overall price of equipment and setup.
My Land Pride grapple is every bit as tough as ANBO.
/ Which grapple? #29
oosik, Thanks for the reply. I have narrowed my grapples choices down to Land Pride and Anbo, What Land Pride has going for it is Dealer is in my area. But he wants to sell me a SGC 1572 72"says he can get me a SGC 1560 60"(this is the size I would like to have based on most grapple site forums say get narrow and don't get extra weight, its weight 784# vs the 1572 wt is 882#. He states that he would have to charge me the same for the SGC 1560 as the SGC1572, because of the freight. I will more than likely go with the Anbo GR-S 60" weight is 660# and I can get it shipped to my farm for about 200 bucks less that the Land Pride at the dealership which I would have to pickup and haul it from dealership which is 1.5 hrs from me. Pretty much comes down to the salesman for some reason doesn't want to make an effort to sell me his product.
/ Which grapple? #30
Lets see - so many thoughts/ideas. Unless things have changed with LP, my OP manual lists the following weights - - SGC1560- 820# SGC1572- 922# I'd sure verify that weight situation by going on the LP site. However - LP could have lightened the grapples using less steel.
From the times I visited the ANBO facility up in Colville, WA - the last thing to worry about is the Anbo grapple falling apart. Their listed weight of 660#(GR-S 60") is 160# less than the SGC 1560 and a whopping 262# less than the SGC 1572. I really think the ANBO boys enjoy their welding - they appear to weld every side of all seams.
Your Case 580C would easily handle either grapple - but with the 50" ANBO you would be gaining 160# over the LP. If I would have had an equal deal on Anbo or LP - I'd have chosen Anbo because of its lighter weight.
/ Which grapple? #31
Did you mean 60" ? I will double check the weights. I have asked for a quote from Anbo for their 60".
My 580C is an a 1984 currently needs a minumun of 1600 bucks for a component in its power steering system and the pump should also be replaced 600 bucks these prices are parts only. then there are the steering cylinders, ? I just use it for it's backhoe use. I was pleasantly surprised as I was dragging a tree with my Kubota and it got to point where its wheels (4x4) were spinning, hooked up the 580 and it spun also so I setup and used the hoe to drag it 4' at a time the last 20' to where I wanted it. I was impressed with how much the Kubota could pull.
/ Which grapple? #32
Yes, - too many numbers, too early in the am - - I DO mean 60". I know you would not go wrong with either the LP or ANBO grapple. The advantage is the ANBO is lighter - they use type 400 steel or something like that.
I've found that one of the "neatest" uses for my grapple is back dragging to smooth after it plow and/or disk. Really works like a champ.
However - I must say adios - its a tad past 9am here and NCAA college football is on the air.
/ Which grapple? #33
Pokeboater, What size Anbo do or did you have ? sorry it failed you.
/ Which grapple? #34
Hammy, How do you like your Anbo ? I am looking at the Land Pride SGC1572 (local dealer) so if I do have a problem he is 1.5 hr drive away. Land Pride is 882 lbs kinda heavy. But I am leaning towards the Anbo GS-S 72" as you know it wt is 780# the price is same for either one within 30 bucks. Land Pride made of Grade 80, Anbo states all tines are made of AR400. That maybe why I am leaning to Anbo. Our tractors are the same hp I have a M5140 Loader is LA1153 spec's on my tractor & Loader seem close to yours. How do you like your Anbo now that you have had it awhile. I would appreciate any feed back and suggestions from you or anyone as I am getting ready to buy. Thanks Bill
/ Which grapple? #35
You might be ahead starting a new thread. This thread was 10 years old that you replied to. And the members you are asking questions of have few posts and havent been on here in a year +. So its unlikely you will get any responses.
As to the grapple.....There are many many MFGs of them out there. Personally I dont think a M5140 needs a 700-900 pound grapple if its done right. There are more affordable and lighter grapples that better match the machine IMO.
And I dont think I'd consider putting either (the anbo or LP) on a fullsized TLB like the case 580. But it sounds like that isnt your intent:thumbsup:
/ Which grapple? #36
Originally Posted by case580c
I have been following ALL the Grapple forums and I am leaning to the Anbo GR-S 60" for my kubota M5160 4x4 with rear wheel weights and ballast in rear tires, I was quoted $3900. delivered to my farm. Land Pride is a few bucks cheaper, But the Anbo Tines made with AR400 Steel, it opens to 51" weight is 660# where Land Pride is 784# An EA about 2900 bucks. I hear lots of good things about the Anbo. I have always found if you by a better tool it will last. My two cents. If you see flaw in my thinking please tell me. Thanks
What is the main use for your grapple?
case580c, you didn't answer my question in the Wicked Thread, so I posted it here. EA shipping to northern California is usually $200 or less. Since you have read a lot of the grapple threads you probably noticed that the L bottom grapple is more popular than the clamshell style. My first was a clamshell, main use was picking up sheared off cedar trees. Didn't work well, but better than no grapple. Sold it at got a narrow L bottom, worked great.
Have since bought a 72" wide L bottom, so now have two of the most popular style grapples.
:thumbsup:
/ Which grapple? #37
:thumbsup:
Sorry I did not see your reply to me on the Wicked Site ? I am running into town right now I appropriate your information do you can you tell me the model you got with the L bottom Thanks I will get back to you when I return this is just a hasty reply Thank you again
/ Which grapple? #38
Axfaxman Could you please give me a link to the Wicked Thread ?
/ Which grapple? #39
No problem. The grapples that I have won't be ideal for your tractor. The little Gorilla Grapple that I bought to pick up cut off cedar trees is 44 inches wide, 31 inch opening and weighs 946 pounds:
The Monster Grapple That I use for picking up dead tree limbs, weighs 1168 pounds and opens to 51 inches:
Can't do this with a clamshell style:
You don't need a link, just click the little "View Post" icon after my name in post #36 that I quoted above.
/ Which grapple? #40
OK I went into my profile and R&R my email address I hope that works as I don't get email notification (it's been lonely here just talking to myself. I so you and others thinking I should go with this or something like it -> Mega Compact Utility Tractor Wicked Root Grapple from Everything Attachments
ETA-MCURG-73 Everything Attachments Wicked Root Grapple for Large Compact and Utility Tractors 73"
I know from experience, (I grew up on ranch lots of tractor and equipt experience I am retired now had a Grading and Excavation since 1975 ran lots of rigs from a JD 350 Dozer to D7s and I know what ever grapple I buy I will be careful with it and I have no employees any more to break stuff by misuse and stupidity) But I not want a grapple that is to light in construction for my size tractor as if there is something I want to move I want the pressure relief to not allow me to pick it up, I do not want the loader to lift it and the grapple to bend. I like your equipt. Thanks again
Wolverine Brush Cutter BC-13-72W Skid Steer Mount  (A62679)
Wolverine Brush...
2005 Ford F-450 Dump Truck, VIN # 1FDXF46P65EB16866 (A65563)
2005 Ford F-450...
2022 EZ-GO ELITE...
2015 Hitachi ZX75US Midi Excavator (A64553)
2015 Hitachi...
1993 Transcraft DTL140W2 38Ft 60 Ton Spread Axle Step Deck T/A Trailer (A64194)
1993 Transcraft...
2005 Dodge Dakota 4x4 Crew Cab Pickup Truck (A64556)
2005 Dodge Dakota...
