plowhog
Elite Member
- Joined
- Dec 8, 2015
- Messages
- 4,048
- Location
- North. NV, North. CA
- Tractor
- Massey 1710 / 1758, Ventrac 4500Y / TD9
I have this unit with lock n lube and it works great.
Lock-n-lube with that gun is the bomb. If the lock and lube won't reach then I would adapt the fitting so it would, it is worth the effort.
Probably the worst advise ever. Those fittings are recessed because of their suseptabilty to breakage.
I also have a few spots the lock n lube won't fit due to it's size.
I will most likely replace the coupler on this gun with a better straight one. The narrow coupler on my Alemite gun works great so I will switch it next time and probably buy a replacement if I want to use that gun again.
