MossRoad
Super Moderator
- Joined
- Aug 31, 2001
- Messages
- 66,760
- Location
- South Bend, Indiana (near)
- Tractor
- Power Trac PT425 2001 Model Year
Does a ball go inside that grooved tube?
Carl-
I'm no engineer, but it seemed to me that your old one broke right at the end of the weld. That could be caused by a lack of strength, brittleness from welding, or random. I'm betting it is one of the first two. Adding metal, and then a little post welding heat treatment should help.
Given where it broke last time, I would be tempted to get some E10018 welding rod and build up the perimeter starting at the triangular base, crossing the existing weld and going at least half way around the perimeter of the inset/attached tube. I would work up a couple of passes until you have added another 1/4" of material along the outside of the piece and over the existing welds, which will be (I'm guessing) probably be 3-4 passes. I would also try to add more material at the join to build up the web. (If you think of the perimeter of the part as a keyhole, I would be trying to make the keyhole into more of a triangle by adding material at the sides of the circle/triangle intersection.)
All the best,
Peter
What do you supposed the tolerance is on the bore diameter? Would doing that much welding on it cause a problem?
Kevin
That's an excellent idea. That would take the twisting load off that that weldment.Also, would it be possible to add some structure to the frame halves to stop the articulation just before the limit of over stress? Suspension bumpers?
prs
In the early posts to this thread it is reported that the manufacturer was not willing to endorse beefing-up of this joint. Could it be that they are concerened that doing so will transfer the damage to other parts...
I don't think Power-Trac does any finite element stress modelling of their equipment. Their approach is to make everything out of thick plate steel, regardless of how much load it supports. These machines (in most places) are over-built.
Except the doggone drainage hole in the PT422 floorplate right next to the steering linkage.... and apparently Carl's entire tractor (since I think he has broken most of it at one time or another).![]()
And I did not catch the tractor on fire....
What was their recommended changes?They ... offered a different linkage, but it would require me completely redoing all the steering
