The WICKED Root & Debris GRAPPLE!!!!!!!
/ The WICKED Root & Debris GRAPPLE!!!!!!!
I'm glad you enjoy the visuals, snowback. SEVERAL Mahindra tractor owners have told me how useful your 2538 pics have been to them.
Pics are extremely useful when you're shopping for something, especially when it's an accessory for a tractor, truck, car, ATV, etc. The previous statement can't be argued.
IMO, the long bottom grapple is more versatile and I usually recommend it unless a tractor is starving for lift capacity.
This new Wicked 55 grapple rake is a breakthrough in lightweight grapple design. 200 pounds, but it still has the serrated upper and lower tines, greasable pivot points, bolted in runners and an incredible clamping force.
The dozer-like geometry promotes a subcompact/small compact tractor's ability to push the tines through the ground for rock/root/vine removal.
Bolted in runners serve as gauges to limit depth, but they are easily removed if you want to go deep!
The short lower tines keep the load closer to the tractor than the long bottom, which increases a small tractor's lift capacity. This is a Kubota BX 23S with universal quick attach.
All of the above quickly made our Wicked 55 a best seller!
Travis
/ The WICKED Root & Debris GRAPPLE!!!!!!! #2,862
I'm curious, it may have been discussed earlier in this thread or somewhere else on TBN, but how would someone increase the clamping force on a grapple? Say like, having the ends close and have jaw crushing power?
I'm simply just curious, my grapple is not here yet. Next week though!
/ The WICKED Root & Debris GRAPPLE!!!!!!! #2,863
The easiest way would be to increase the diameter of the cylinder.
Mine is 4 inch and tip force is over 7,000 pounds.
But it is a unique design, 44 inches wide and a 31 inch opening:
/ The WICKED Root & Debris GRAPPLE!!!!!!! #2,864
I've been wanting to build a grapple with massive clamping force. I doubt I'll ever have time to actually do it but I came to the conclusion that a 3" or so cylinder with a long stroke was the most practical. Otherwise self destructing was an issue.
/ The WICKED Root & Debris GRAPPLE!!!!!!! #2,865
Why would you want massive clamping force?? With a standard L type grapple, the upper jaw really just keeps the load from rolling out forwards. Not much force at all needed to do that. If you are picking up big rocks then more clamping force is needed but then you have to build up the jaw tine tips to withstand more force. I splayed out the tips of mine lifting up a one ton rock out of the ground. That was with just the standard cylinder. A little heat and persuasion plus adding gussets for the tips has prevented further problems. What do you expect from a $500 grapple??:rolleyes:
/ The WICKED Root & Debris GRAPPLE!!!!!!! #2,866
Here is an idea. I wish my outer tines had fangs, an extension, a spade or blade that could be attached and removed or pivoted out of the way. The spade would be used for busting out Bear Grass, you may know it as Indian Basket Grass, or other pesky shrubs. By extending the spade forward of the grapple, it would not be necessary to bury six feet of grapple into the ground to pluck out one undesirable plant.
The Wicked does a good job of breaking out tough vegetation, but it is unnecessarily wide in many instances. A grubbing blade attachment, please.
/ The WICKED Root & Debris GRAPPLE!!!!!!! #2,867
Also wider is better in this respect. A wider grapple allows the operator to see the outer tines for precision placement. If the grapple is no wider than the FEL, the FEL will block the view.
/ The WICKED Root & Debris GRAPPLE!!!!!!! #2,868
Mac, your statement IMHO is absolutely correct but, it will probably arouse the torch & pitchfork crew.
In fact, I think I hear them coming!
/ The WICKED Root & Debris GRAPPLE!!!!!!! #2,869
The grapple on the CTL at work clamps about 5 times harder then my tractor grapple did. It was better at moving logs. It would bite through a pile and get several where a tractor grapple is on a 1 or 2 basis. It could get a bigger mouth full of brush. And gripping a log on the tips and not actually in the grapple is nice for precise loading on a truck.
/ The WICKED Root & Debris GRAPPLE!!!!!!! #2,871
Nah, I can easily see the edge of my 48" grapple. Try it sometime. I don't need to lean outboard to see it either. Consider the geometry. I just look slightly to the left or right. The grapple tine tips are easily within field of view without needing to change position. I thought I posted some photos about this several months ago when Eric made the same claim. Bogus.
/ The WICKED Root & Debris GRAPPLE!!!!!!! #2,872
How is it that you guys who don't even operate 48" grapples are so confident about this issue????
/ The WICKED Root & Debris GRAPPLE!!!!!!! #2,873
How is it that guys that only operate 48”grapples are so confident they are the best and superior to a larger one?
Brett
/ The WICKED Root & Debris GRAPPLE!!!!!!! #2,874
There should be a separate thread about narrow grapples.....
/ The WICKED Root & Debris GRAPPLE!!!!!!! #2,875
Brett
I've operated a few larger grapples to test them. Never saw the benefit. I don't doubt a few tasks might be done more efficiently with a wider grapple such as carrying two bales of hay at once but for most uses the narrow is just as efficient and the narrow is clearly better for maneuvering in woods, digging and net lift capacity. Oh yeah, they are cheaper too and less likely to twist your FEL when used off center. I paid $500 for my grapple and it is still going strong 12 years later. I'd say it is up to the advocates of larger, heavier, more expensive grapples to justify why theirs are worth more.
/ The WICKED Root & Debris GRAPPLE!!!!!!! #2,876
Brett
Brett, we keep ‘splainin’ to IT that we all have different needs and vastly different uses for grapples, not the “one size MUST fit all” program that he evangelizes for.
I have a 100 HP Tractor with an almost 900 lb. 84” dual lid grapple but, I can lift over 5000 lbs. Wrong? No, it does what I need it to do.
I also have a 50 HP Tractor with a 665lb. 73” single lid grapple, with 42.5” opening, but I can lift almost 3000 lb. Wrong? No, it does what I need it to do.
I don’t need to own a 20 HP Tractor to know it won’t meet my needs.
I had a 27 HP Tractor and ...... it did not meet my needs. Sold it and bought 50 HP tractor.
/ The WICKED Root & Debris GRAPPLE!!!!!!! #2,877
I’m fixing to order a new grapple, it’ll be over $3500 and maybe 84” with dual lids. My wicked stood up to my 100hp 12,000 lb grapple. If you bent the tines on your there no telling how bad I would’ve folded it up. EA puts out a top notch product at a great price and backs it up with terrific customer service.
Brett
/ The WICKED Root & Debris GRAPPLE!!!!!!! #2,878
Brett
This is a forum that is primarily focused on Compact Utility Tractors and SCUTs. Utility tractors are a different breed. Those of you with 100hp tractors represent a very small fraction of the TBN users who are primarily amateurs not farmers and almost everyone who comes here to learn about grapples is a grapple novice. I'm ever so happy for you that you can spend $3500 on a grapple but the vast majority of readers of this thread are grapple novices looking to buy a cost efficient grapple for a sub 50hp CUT and that is who my comments are directed towards.
As for bending my tines, that was the hydraulics operating against a one plus ton granite rock. And it was just the tips of the lid. The bottom tines are 3/8" steel and are stronger than any standard bucket. You couldn't damage the grapple with your loader unless you decided to ram something off center at speed. I doubt you're quite that dumb. BTW, the same grapple I have is used on another TBN members M59. He loves it. No problems.
/ The WICKED Root & Debris GRAPPLE!!!!!!! #2,879
Brett
If it survives I want a try. I'm thinking a 12,000 pound CTL can dish out even more abuse.
2000 International 4900 Tandem Truck (A66285)
2000 International...
Harrell 3pt 4 Row Stalk Puller (A64127)
Harrell 3pt 4 Row...
2002 Built Rite Trailer (A66285)
2002 Built Rite...
New/Unused Wolverine 72in Quick Attach Ripper (A65583)
New/Unused...
2013 CORPUS 40FT T/A CONTAINER CHASSIS TRAILER (A59914)
2013 CORPUS 40FT...
2014 DODGE 5500 SERVICE TRUCK (A65643)
2014 DODGE 5500...
