The WICKED Root & Debris GRAPPLE!!!!!!!
   / The WICKED Root & Debris GRAPPLE!!!!!!!
What do you have on the back of that machine in the second photo? looking like a flail. Which model ?
Still loving my grapple from you guys!!!!
It is a customer submitted photo, so I do not know any specifics, but it definitely looks like a flail mower.
I'm glad you like your Wicked Grapple. Rock on!!
Travis
   / The WICKED Root & Debris GRAPPLE!!!!!!! #1,432
Most likely a flail given the size and setting and what appear to be metal guards hanging in front. Second choice would be a tiller but I doubt it.
   / The WICKED Root & Debris GRAPPLE!!!!!!! #1,434
From my point of view, just put the tab and slat together and fit in the grapple and tack it. It would be pretty easy to get it lined up right that way it would seem to me. Of course if they all came with the tabs welded in from the factory and the slats were just a bolt on kit you either ordered with the grapple or at a later date, that would be easiest of all. But this is bound to add cost to the base grapple to have those tabs fitted to all of them whether a person wanted the extra slats or not.
   / The WICKED Root & Debris GRAPPLE!!!!!!! #1,435
Yes, for someone with even a 110V MIG and some fluxcore it wouldn't be hard but 1) not everyone has welding equipment, 2) you'd need to grind and then paint afterwards, 3) many folks would just like to start using the grapple as soon as it arrives. No doubt some people will be happy doing the welding themselves and I hope EA makes allowances for that but given that it probably wouldn't take even an hour for one of their fabricators to set up a jig and weld the ?8 or 10 tabs in place I doubt it would cost much to do it at the factory. I've got the welding equipment but just the hassle factor would be enough to make me choose the factory welded version if the price was reasonable.
   / The WICKED Root & Debris GRAPPLE!!!!!!! #1,436
Offering the slats as a customer installed option is the most economical method, for EA and the customer.
Yes, offering them as a factory made option is something Ted and I are pondering/discussing, BUT....
It would require either:
1. Having extra "slat ready" grapple inventory on hand.
2. Welding the tabs to all grapples whether they'll get slats or not.
3. Special order production.
I think #3 makes the most sense, but we'd need to take this into consideration:
In this case, if someone wanted a 60" grapple with slats, we'd have to build another 60" grapple, even if one without tabs is already in inventory.
Travis
How about a sheet of heavy duty flattend expanded metal, framed on the top and bottom with flat stock so it lies just behind the back the last tine barb. You can add some kind of fastener or welded loop that could line up with the holes in the tines and be bolted into place. This way it could be removeable. IF, the distance from the rear tine barb to the back of the lower frame is the same on all the grapples then you would only need to customize the width based on the grapple size. This could help pick up the smaller wood scraps, stones, etc. Just a suggestion.
   / The WICKED Root & Debris GRAPPLE!!!!!!! #1,437
Interesting idea. The problem would be if that expanded metal behaved a bit too much like a bucket and held dirt like a sieve where lots of vibration would be necessary to clear the loam. I guess there are probably various grades of expanded metal though so maybe if the "holes" are big enough it would work.
   / The WICKED Root & Debris GRAPPLE!!!!!!! #1,438
I thought I would have to use the backhoe to get this stump out, but the EA grapple just pulled it right out. The recent rains must have given me a hand.
   / The WICKED Root & Debris GRAPPLE!!!!!!! #1,439
Some sort of root rot on that tree if you pulled it out?
   / The WICKED Root & Debris GRAPPLE!!!!!!! #1,440
Agree. It's always a pleasant surprise when an old stump just surrenders without a fight. The other circumstance is when lateral roots have been ripped with BH ripper and there is a long enough section of trunk remaining to push the stump over before grabbing with the grapple.
2018 Toro Workman GTX Electric Utility Cart (A55851)
2018 Toro Workman...
2005 MACK TRI AXLE DUMP TRUCK (A57192)
2005 MACK TRI AXLE...
2013 PETERBILT 389 (INOPERABLE) (A55745)
2013 PETERBILT 389...
(INOP) 2016 FORD F150 XL SINGLE CAB TRUCK (A51406)
(INOP) 2016 FORD...
2019 Ford F-350 4x4 Flatbed Truck (A55788)
2019 Ford F-350...
2023 Kubota L3560 Compact Utility Tractor with LA805 Front Loader (A55315)
2023 Kubota L3560...
