Tractor broke in half again
/ Tractor broke in half again
So I am waiting for the parts to show, but thought I would share this with you. This is the pin and its assorted parts.
Basically you have the pin (1-1/4" for you engineers)
Jesus Nut
2 Spacers, one on top and one on the bottom
The ball (which if I remember correctly goes into the piece that is broken) and two circlips to hold the ball in.
Engineering thoughts?
/ Tractor broke in half again #22
So what exactly broke?
The eye appears to be similar to a 3pt hitch lower link ball end. Anyone else notice that?
Category 1 lower link ball ends are 7/8" diameter.
Category 2 lower link ball ends are 1-1/8" diameter.
Category 3 lower link ball ends are 1-7/16" diameter.
Category 4 lower link ball ends are 2" diameter.
Anyhow, I'd take the broken part to Tractor supply, or some other agri-supply type place and compare it to the 3pt lower arm ball joints and see if they are compatible.
Do not forget that there are top link replacement ends,,, that would increase the number of sizes,,
CAT 2 is 1",,, much easier to work with than 7/8"
Then there are;
CAT 3
and
CAT 4
I have not looked up those sizes,,,
/ Tractor broke in half again #23
What is the diameter of the ball? What is the height of the circle that the ball sits in?
I think Mossroad has the right idea; this is probably a CAT3 or 4 link ball.
I personally would mill a replacement bracket for that ball that is as thick as there is room to fit it. Since this has broken twice, obviously under-designed. But than I have a couple of mills in my garage that make that kind of experimentation easy and cheap. :D
Amazing that the bracket holding it broke before the circlip gave way.
/ Tractor broke in half again #24
Jesus Nut
A little helicopter reference there?
I am going to ask Terry about this. See what his take is. PT is not one to over engineer their stuff so I wonder why they did not go with a Cat 3 connector. I personally have had bad luck with the rollover bars on the machine, which use Cat 1. The steel on the outer collar never seems strong enough.
TMarks. It si so great you invited me up this week to mill out some new stuff for my machine. Very excited ;-)
/ Tractor broke in half again #30
It appears, from looking at the avatar, that you carry some huge overhung loads with the FEL and grapple. Is that causing the breakage perhaps?
THe PT is an intersting beast. The lift on my particular machine is VERY anemic for its size and weight. It is limited to only 1200lbs of lift. The reason I have been told is so that when you are doing figure 8's at 45 degrees you don't flip over... I do raise heavy loads up high and go sidewas across hills at 30 degrees all the time, definitly a pucker and I doubt the machine could do any weight raised high at 45
/ Tractor broke in half again #34
Good catch. You fly?
Ohhh just found this. A Vietnam ditty?
"The Jesus Nut" - YouTube
Hahaha, no, I don't fly. But I was raised around airplanes and worked at airport FBO's for 6 years while putting myself through school. My best friend from age 4's father was an aircraft salesman and owner of the FBO in South Bend. So to keep current in many models, he had to fly a lot and i went along for the rides.
Another friends dad was also an aircraft salesman, and owned the FBO in the next town over. And our next door neighbors were a young couple with no children, and they had a Piper 4 seater so lots of rides with them.
Anyhow, I've heard the term many times. :laughing:
I like how he just looks up, then slowly over.... then slowly down.... :laughing:
That was the same thing I laughed about. So Wikipedia says Jesus nut is now used for any fundamentally important fastener.
I think I want to buy a used one for my desk.
/ Tractor broke in half again #38
The first time I hear the term, I was poking around the maintenance shop at the FBO and saw a very large aluminum pipe wrench leaning in the corner. Now, I've seen some big pipe wrenches before... but this thing was 6' long! I asked what the heck that was for and the mechanic said for tightening the Jesus nut on a helicopter. So of course, I asked, "What's a Jesus nut?" to which he replied, "It's the nut on top that holds the rotor on. That falls off and you're going to meet Jesus." I almost believed him.... :laughing:
So the new center section arrived today. Over the weekend I am going to devise a few plans to beef this piece up, and Monday will go to the steel shop and see what they have.
Taking all ideas here, if anyone has one.
/ Tractor broke in half again #40
Carl-
I'm no engineer, but it seemed to me that your old one broke right at the end of the weld. That could be caused by a lack of strength, brittleness from welding, or random. I'm betting it is one of the first two. Adding metal, and then a little post welding heat treatment should help.
Given where it broke last time, I would be tempted to get some E10018 welding rod and build up the perimeter starting at the triangular base, crossing the existing weld and going at least half way around the perimeter of the inset/attached tube. I would work up a couple of passes until you have added another 1/4" of material along the outside of the piece and over the existing welds, which will be (I'm guessing) probably be 3-4 passes. I would also try to add more material at the join to build up the web. (If you think of the perimeter of the part as a keyhole, I would be trying to make the keyhole into more of a triangle by adding material at the sides of the circle/triangle intersection.)
All the best,
Peter
TIGER MOWERS TRF102-102" REAR FLAIL MOWER (A63276)
TIGER MOWERS...
2016 Cadillac XTS Sedan (A64557)
2016 Cadillac XTS...
1987 Polar 307 SS 3 Comp SS Insulated T/A Chemical Tanker Trailer (A64194)
1987 Polar 307 SS...
2008 MACK CHU613 DUMP TRUCK (A63569)
2008 MACK CHU613...
UNVERFERTH 2755 SEED RUNNER (A64278)
UNVERFERTH 2755...
CASE INTERNATIONAL 3330 HI-CYCLE SPRAYER (A63291)
CASE INTERNATIONAL...
