Flail Mower Let's talk flail mowers
/ Let's talk flail mowers #4,862
Hey Leonz Thanks for the info.
My 907 has 33 Stations in three rows (11 each). Not sure if that is enough but it does great behind the little B3030 if I go slow and use common sense.
Right now it has y-blades on it with Shackles. I ordered smooth cut (duckfoot style) blades and should be here Friday. The balance sense pretty good right now. Then I run it over my lawn it has only a small amount of vibration. Out in the field the 3-4 foot grasses make is vibrate more but not awful.
Any tips on getting a better balance on the rotor? the 907 is set up to have the blade hang from a shackle.
The upgrade to a kubota L4701 or MX4800 will help with power and stability.
But I am still amazed at what I can cut down with a 23hp at PTO and this old flail mower (made somewhere in the late 1960s).
/ Let's talk flail mowers #4,863
Hey Leonz, Thanks for the info. My 907 has 33 Stations in three rows (11 each). Not sure if that is enough but it does great behind the little B3030 if I go slow and use common sense. Right now it has y-blades on it with Shackles. I ordered smooth cut (duckfoot style) blades and should be here Friday. The balance sense pretty good right now. Then I run it over my lawn it has only a small amount of vibration. Out in the field the 3-4 foot grasses make is vibrate more but not awful.
Hello Kirch169,
I am so glad to hear that your Ford 907 Flail Mower is working well for you.
Before I forget to ask this again: do your side slicer knives have a slotted mounting hole or a round mounting hole???
As far as power: and just as an example my father used his Ford Jubilee with a 7 foot John Deere 25A Finish Flail Mower with side slicer to knock down 12-15 foot golden rod to reclaim old farm land that was used for pasture for my animals when the rug rats were barely walking-1986+-. SO you can do a lot with your flail mower as long as you know the mules limitations as far as its available PTO power is used properly.
If the side slicers are dull there is more loading on the flail mower rotor and more vibration. If the brush is thick it will vibrate a bit due to the heavy brush being contacted by the side slicers. In this specific case you need to slow down more to let the side slicers cut faster to create smaller clippings.
In heavy brush its always best to slow down and take half cuts unless you can lower your ground speed more
NOW, if all the mounting stations are intact and all the mounting pins, shackles and side slicer knife Pairs are intact and secure
it brings me to the heart of the matter as far as vibration while mowing is concerned.
You may have a missing balancing weight, worn out snubber pulley bearing or a bad Flail Mower Rotor Bearing OR you have debris wrapped around one bearing housing on the inside of the flail mower.
The V belt could also be stretched and needs to be replaced. It is best to run the mower with the guard off for a few minutes to see how much the V belt flexes if any. The V belt should not move much beyond a 1/4 of an inch under the tension created with the V belt snubber pulley.
Please check to see if there are any grease fittings buried under rubber dust and grease under the V belt guard and check to see if the snubber pulley spins well and does not wobble with the V belt off the mower.
If it is running well I would finish the season, drain the gear box and then take the flail mower to a car wash to clean under the shroud and under thew V belt guard to bare metal. If you can find someone with a steam cleaner to use after a beer and or pizza bribe that would an even better method to clean the flail mower completely so you can paint both the under side and the exterior of the flail mower if you have time and a warm place to work.
NO worries, please do not get discouraged, you have a forever mower and I will be here to help either by posting or by a PM to you.
LeonZ
/ Let's talk flail mowers #4,864
Well I put new bearing all the way around the mower. Main Cutter bearings, Roller bearings, Pulley and idler pulley bearings and even gear box bearings. had the whole unit apart. repaired some cracks in the housing with the welder and ever had to fix two of the adjustment holes since they were elongated when someone ran it with loose bolts. I have had it about 6 years and have been taking the y-blades off every year and doing some minor sharpening.
I will check for missing balancing weight when i take the blades off to change them to the smooth cut ones. I want to try it on the lawn before I put it away for the year.
I have a 72" MMM for the B3030 and it works great just sometimes it shoots missiles and I worry about the cars, house and dogs.
I will keep you posted a post some pictures of the property and where I have been mowing!!
I like they was the blades mount on the 907 three long rods as apposed to single station bolts.
/ Let's talk flail mowers #4,865
Hello Kirch169,
I had forgotten that you mentioned all the bearings were replaced. If you have time can would you mind running the flail mower with the knives and shackles off the rotor before you mount the scoop knives? By doing that we can narrow the vibration issue down even closer.
I had for gotten the Ford 907's had the common mounting rod for the 3 rows of knife mounting stations. The Vrisimo Flail Mowers have been using that method for many years to mount their knife pairs on each mounting station.
LeonZ
/ Let's talk flail mowers #4,866
Yes, the original belts are 46" OD
After seeing your mower this morning with the 45" belt decided to do some checking after work tonight. I thought it looked to me like the engineers originally intended to have the 45" or metric equivalent on it and not the 46". Went to Agri-supply website, found PDF of the manual to see if I could find a picture of the belt setup in the manual. I would say the 45" is the winner. :)
/ Let's talk flail mowers #4,867
Have this flail mower with no identification. Does anyone recognize the manufacturer? Or tell me where to scrape to look for a tag. 7 12' flail 017.jpgIt just fits in the back of my truck, so it's 8' long. Was a Corp of Engr. piece of equipment at one time.
I changed out the gearbox oil, and greased the fittings I could get to. Was going to take it to the farm and put the trail wheels back on and give it a spin, but the rains came. Tomorrow, maybe.7 12' flail 018.jpg7 12' flail 021.jpg7 12' flail 019.jpg7 12' flail 020.jpg
/ Let's talk flail mowers #4,868
View attachment 523753View attachment 523752View attachment 523751
Thanks for the info. The 45 belts sure do not have as much back flexing as the 46 belts. Too much flexing around the idler pulley might be what is causing the belts to crack and fail.
Hopefully I can put the 45 belts to the test and see how they will hold up compared to the 46.
/ Let's talk flail mowers #4,869
Have this flail mower with no identification. Does anyone recognize the manufacturer? Or tell me where to scrape to look for a tag. View attachment 523776It just fits in the back of my truck, so it's 8' long. Was a Corp of Engr. piece of equipment at one time.
I changed out the gearbox oil, and greased the fittings I could get to. Was going to take it to the farm and put the trail wheels back on and give it a spin, but the rains came. Tomorrow, maybe.View attachment 523777View attachment 523778View attachment 523779View attachment 523780
OH MY LORD!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Surround it with farm equipment that cannot be moved without a high horse power mule, chain the dog to it, dig tiger pits and put a spot light on it to keep track of it!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
I want to welcome you as the newest Member of the Flail Mower Nations from Kan.? Mo? please clarify this part.
You have an "original" Mott Interstater finish mower with side slicer knives and gauge wheels to prevent scalping. Put the caster wheels on, grease the stub shafts for caster wheels, Take the V belt cover off and clean off all the grease and rubber dust to expose any buried grease fittings.
If the V belts are the least bit frayed they need to be changed and the Kevlar V belts are the best for shock loading.
Parts are still available and generic as all V belts and bearings are metric and you can purchase them locally if desired or from Flail Master so no worries there, the side slicer knives and knife hangers are common parts and available.
/ Let's talk flail mowers #4,870
That's an Alamo/Mott . It came in 74", 88', and 96". One of the better built flail's around.
/ Let's talk flail mowers #4,871
Leonz and Steave, thanks for your insight. I was looking for a set up to mow a pasture. It's native grasses and about 2' tall now. Wanted to knock it down to about 8", like a Bush Hog would do. Will this do that for me? Can I adjust the gauge wheels for a higher cut?
How much Hp would be required? I have a Case 730 and Deutz 6206 (both diesel, both in the neighbor hood of 60HP) I usually use for mowing.
I'm on the Kansas side. About 20 miles West of the Mo. line, and 25 miles to the suburbs of KC.
/ Let's talk flail mowers #4,872
Hello D2Cat,
Is this pasture an exercise pasture or a forage pasture?
Your mules will have plenty of power the issue is mowing. If your actively grazing 4 legged hay burners mowing shorter will always allow fresh growth UNLESS your dealing with drought.
Using a flail mower at a higher mowing setting/cut will affect its mowing efficiency as your flail mower will mow better at a shorter height of cut and it will keep any poison ivy, oak or sumac under better control.
Mowing at a higher height of cut will work but the mower will not cut very well versus mowing at 2-3.5 inches as there will be much less of a pressure gradient to lift the clippings up and over the flail mower rotor and back down to the ground.
Please understand that I want to help you with this as you have a gem of a flail mower that will out last your mules.
I would like you to readjust your flail mower.
You need to block up your flail mower using hardwood blocking under the flail mower rotor or use jack stands on stable ground or a concrete shop floor to change the mowing height and then readjust the rear roller by lowering it to the lowest mounting holes in the side weldments of the flail mower to raise the cutting height.
Please keep your body and arms out form under the flail mower while doing this.
If the name plate/ID tag is still there it is probably covered in paint on the right or left front or rear cross brace or under the V belt guard on the side weldment.
I am going to attach a manual for a Mott 60 and 72 inch mower here.
  • mott utility 60 & 72.pdf
/ Let's talk flail mowers #4,873
Well I got the smooth cut flail blades and the look great but three of them hit the shroud of the mower. I think I need to take them off and grind them down a bit with the wet wheel and trim them down by 1/10th of an inch or so.
I will let you know how it goes.
--Kirch
/ Let's talk flail mowers #4,874
--Kirch
If only 3 of the knives are hitting the shroud then the shroud is more than likely deformed in that area. Check to see if there is a dent or crease. If you can find the deformation see if you can work the dent back out.
/ Let's talk flail mowers #4,875
Wery much correct. I got my 7' Ford 917 for $100. Put in the missing knives, then promptly foud out why they were missing and I got it for only $100. Took the plasma cutter out & torched out a large chunk of the back of the hood. It was to bent to hammer out, got backed into somethig I'm guessing.Welded a patch over the holes. It's still a piece of crap with a huge crack in the hood, but also better than a new rotary.
Had similar knife strike issues when the rotor bearing blew.
/ Let's talk flail mowers #4,876
I checked that but it looks like the entire width of the one flail in rubbing on the shroud. the other two hit at the back edge of the shroud and not real deformation. I cannot find smooth cut blades for the 907 so these are as close as I could come to the specs of the 907 blades
It realy should be no big deal to alter the blades takes a couple minutes per blade and there are only 33 of them :)
/ Let's talk flail mowers #4,877
Well had more fun with the Graffetta. Mowed two acres of grass that had a years growth on it with irrigation. It was twice the height of the mower. Put a good load on the tractor but did and excellent job of mulching. I do need to raise the side skids a bit as it trapped and drug the long grass leaving big clumps. After mowing I checked the hammers. Definitely need to sharpen them as some had folded over grass stems wrapped up on the hammer. Ill try and take a few pictures tomorrow.
/ Let's talk flail mowers #4,878
Update on the Caroni with the 45" belts and duckfoot blades.
Mowed about 10 acres of pasture this week. The cows have been grazing on it but there's still a pretty good crop of 18" Dallas grass stems everywhere. The cows won't eat those stems and hopefully cutting those and other weeds will stimulate some new fescue growth before the first frost.
Almost all the mowing was done in 5th gear, approximately 3 mph, 2400 engine rpm and 530 pto rpm.
The duckfoot blades did a good job cutting everything that was thrown at them. The new 45" kevlar belts are holding up well and it seems to run a lot cooler too. I can hold my hand on the belt cover as long as I want without being too hot to be uncomfortable. I tried to avoid those pesky fire ant hills but did hit a few. They seem to have had no negative effects to the mower, blades or belts.
Mowing with the flail was actually pretty enjoyable today. Pretty weather, good clean pasture and the mower/ tractor both ran good without any mishaps. Gotta love it.
/ Let's talk flail mowers #4,879
AGREED. :drink:
/ Let's talk flail mowers #4,880
Have a question - sorry if it's already been asked. Has anyone here tried using a front mount flail, using the front PTO? Seems common in Europe, but no one I know around here does anything but pull bush-hogs...
2011 Jeep Wrangler Unlimited 4x4 (MPV), VIN # 1J4BA3H1XBL528743 (A61165)
2011 Jeep Wrangler...
2020 International LT625 Sleeper 48" (A62613)
2020 International...
40ft 10-Door Shipping Container (A61567)
40ft 10-Door...
2025 Hydraulic Drum Mulcher Mini Skid Steer Attachment (A61567)
2025 Hydraulic...
2020 Caterpillar 303.5E2 Mini Excavator (A61567)
2020 Caterpillar...
2000 Volvo VNL Sleeper Cab Truck, VIN # 4V4N21JF6YN250211 (A61165)
2000 Volvo VNL...
