Which engine is in your Yanmar
/ Which engine is in your Yanmar #141
Fx335 Engine # 4TNA78-RN
/ Which engine is in your Yanmar #142
YM 2820D
Engine: 3T84T-H
/ Which engine is in your Yanmar #144
3cly pushing about 14Hp. Was this used or refurbished?
A simple single axle flatbed trailer would haul this around really easy.
Did it come with ROPS? If not, check out Fredricks here: http://www.fredricksimporting.com/rops-manuals Your unit may take a ROPS-1 or ROPS-2 setup. These ROPS are foldable and the best insurance against serverly getting hurt or death.
No ROPS. Its used but runs nice. We're still getting acquainted.
/ Which engine is in your Yanmar #148
hello,
does anyone have an updated list?
i would really like to have it.
i have a small workshop in the netherlands and we repair yanmars and kubota's a lot, this list would help us a lot.
thanks in advance
/ Which engine is in your Yanmar #149
hello,
thanks in advance
/ Which engine is in your Yanmar #150
I have a excel file I keep somewhat updated when I come across this info but take it with a grain of salt, because its just info posted in and on the internet. send me an pm with your email and I will send you the file.
/ Which engine is in your Yanmar #151
The Yanmar Yahoo Groups site has an MS-Excel file. From time-to-time I make updates. Several sites are referenced and cross-referenced. However, I do find the best information from these forums when conflicting information is given.
The list includes the John Deere made by Yanmar and Yanmars (mostly in the gray markets). I do have the European Yanmar machine lists, but have not entered any information yet. Interestingly, the Yanmar numbers that are SKIPPED in the USA are the numbers used in Europe and elsewhere.
A person can devote months gathering information just on the gray market versions.
/ Which engine is in your Yanmar #152
I have a john deere 990 it has a yanmar 4tne84ejk motor it needs a piston and head gasket . I would like to know if I have to get these from jd. or is the internal from all 4tne84 blocks the same
/ Which engine is in your Yanmar #154
Hi everyone. First post here. I bought a Zen-noh Yanmar a while back mainly to get the engine, as it was posted for sale as "will not move". Motor purred like it was new so I brought it home, and it has just under 1400 hrs. The gauge cluster calls it a Yanmar F24, but the engine covers are badged by Zen-noh as an F22.
The engine is labeled as a 3TNB84UA, so I'm 99.9% sure it's a Yanmar F24 after the dozen or so hours of internet browsing on it. I did a preliminary inspection in the gearbox and found a broken tooth. I've decided not to part it out, but will end up repairing it and will perform a mild restoration (low cost, high time). Once I get going I'll post a new thread
/ Which engine is in your Yanmar #155
Welcome to the forum. :welcome: What gear was the broken tooth on.
/ Which engine is in your Yanmar #156
Can't wait. But are the gears cast or cut? You gonna run it with a broken tooth or going to have it welded back up and reground? I know gears are in short supply for that so I wouldn't think you could find one unless there was a parts tractor somewhere that they were fine parting out.
/ Which engine is in your Yanmar #157
The broken one I saw didn't look cast to me.
I'm going to weld it if I can. It's not open anymore, so I can't tell you exactly which one(s). One for sure is on top, one of the front 3. The whole tooth was sheared clean off. I'm sure it's still down there. I'll post a pic of the gear first thing when I get going on it.
Will post on a new thread once I get going so we don't get off topic here. I'm tied up all through Oct, so won't get into it for a full month or so.
Thanks for the welcomes, looking forward to getting into this project!
/ Which engine is in your Yanmar #158
I will be surprised if your ring and pinion are not suspect.
/ Which engine is in your Yanmar #160
Wheels locked up, or rolls but can't engage a gear, or ??
Clutch works. It will go in gear, and I have been able to move it a few inches, maybe a foot, then it stops rolling.
Same condition in any gear. I don't know enough about the drive train, so I'm not ruling anything out.... including the possibility of the ring and pinion as Winston mentions. But the sounds it's making is right in the gear cluster area. It makes these bad noises even in neutral, when the R&P are idle. My guess is that theres a bad "important" gear on the main shaft coming from the clutch that needs attention. I'm trying not to move it much, as I don't want to make it worse. 3 weeks and I'll have some time to find out for sure
2015 International WorkStar 7500 29Yd. Side Loader Garbage Truck (A64194)
2015 International...
2019 Toyota Mirai Sedan (A64557)
2019 Toyota Mirai...
2011 International DuraStar 4400 18ft. Cab and Chassis Truck (A64194)
2011 International...
2008 GMC 3500 HD 4x4 Ext. Cab 9Ft. Flatbed Truck (A64194)
2008 GMC 3500 HD...
2010 Workhorse Custom Chassis W62 Delivery Truck with Liftgate (A64556)
2010 Workhorse...
2022 JOHN DEERE 333G SKID STEER (A65053)
2022 JOHN DEERE...
