What did I BREAK?!?
/ What did I BREAK?!?
Best I can tell, I possibly need either a new shift fork (#4)
or a new #16,
which rotates on the shaft to slide the fork "fore-and aft"
/ What did I BREAK?!? #12
or a new #16,
Have you tried to adjust the turn buckle above the "L" that attaches to #24,
or even taking the lever loose there and try rotating #24 by hand to see if it engages?
To physically see #4 or #16 it looks to me that the top cover and 3 pt housing willneed to come off.
good luck, you pics look to be very close to the ones for the 3510I
/ What did I BREAK?!? #13
I found the link for that manual, it was here a year ago
Here's a parts break down that covers Branson 2910, 3510, 3820, 4220, 4720, 2910i, 3110i, 3510i, 3820i, 4220i, 4720i Not sure how long it will be available on the Internet so you may want to print it to a PDF file (it's 180 pages)
404 Not Found
To physically see #4 or #16 it looks to me that the top cover and 3 pt housing will need to come off.
No, because when moving the lever you can FEEL that there is DEFINITELY something bent inside the transmission.
Yes, unfortunately - - It looks like the top will have to come off for sure, and also most likely the PTO rear cover as well.
The shear pin in the shredder never sheared, either (It's grade 2). What a disappointment.
One really strange occurrence, is that It doesn't bleed down now! Before, the 3-point hitch wld bleed down in about 6 hours, and the loader would bleed down shortly thereafter. Now, it's been several days – and the 3-point hitch & the loader are still up in the air, off the ground. WEIRD. The knob under the front of the seat has never had much of any effect when the engine was stopped, it only made a difference when the tractor was running.
CASE SV280 SKID STEER (A62129)
CASE SV280 SKID...
John Deere 5300 (A60462)
John Deere 5300...
John Deere 568 Megawide Plus Round Hay Baler (A60462)
John Deere 568...
2020 MACK GRANITE (A60736)
2020 MACK GRANITE...
2023 WRANGLER 5500T ARTICULATED WHEEL LOADER (A58214)
2023 WRANGLER...
BRAD CO. TRENCHER (A60736)
BRAD CO. TRENCHER...
