John Deere 301a power steering pump
/ John Deere 301a power steering pump #1
Dconk91
barnesville, ga
John Deere 301a
I have the open center power steering setup on my 301a, i have replaced bushings and seals TWICE, and it still leaks hydro fluid into crankcase. I ran it for about 15 minutes and it had already dumped about 1 gallon of hydro fluid into crankcase....
/ John Deere 301a power steering pump #2
Welcome to TBN
What condition is pump shaft?
I used a mike on the shaft and it isnt worn, the pump works great, has great pressure, but its leaking, i checked the return side of steering valve, to make sure there were no blockages, and i have good pressure there as well...
I can only find a single lip seal, but i think i need a double lip seal...
/ John Deere 301a power steering pump #5
Local JD dealer should be able to get a dual lip seal. FYI your tractor must be a 300 not a 301A because 301A has only closed center power steering with no engine mounted pump
So what is the difference between a 300 and a 301a besides hydraulics?
/ John Deere 301a power steering pump #7
My knowledge of JD ind equipment is limited because I was employed by an "ag only" dealer but there's not much difference. 301A was built in the yrs following the 300. 301A has closed center steering instead of the open center steering similar to the 300.
16ft. Aluminum Extension Ladder (A65640)
16ft. Aluminum...
Skid Steer Blank Plate (A65640)
Skid Steer Blank...
New Landhonor LHR-COA200,  200lb Cast Iron Anvil (A62679)
New Landhonor...
Caterpillar TL1055D (A62177)
Caterpillar...
(INOP) 2013 MACK ELITE LEU633 GARBAGE TRUCK (A62130)
(INOP) 2013 MACK...
2004 GMC Sierra Pickup Truck, VIN # 1GTHK23U24F110736 (A65563)
2004 GMC Sierra...
