Flail Mower Let's talk flail mowers
/ Let's talk flail mowers #4,681
Your field looks great! It looks like your skids are very low, are you getting any scraping at all? When in use, those skids shouldn't be touching the ground. The flail should be supported by the rear roller and the 3pt hitch.
/ Let's talk flail mowers #4,683
Agree Roy's skids are set pretty low. If he's not gouging turf then I guess his field is nice and smooth and level. I'd tear up the grass in areas I mow if my skids were that low. And, remember, the skids are just there mostly to protect the rotor and knives when the mower is dismounted. I suppose it isn't good to leave the knives in contact with wet soil for long but certainly no harm will come from being left on soft turf for a week or so. Mine lives outside on turf over sandy soil during the off season. No harm after ten years.
/ Let's talk flail mowers #4,684
The one picture with the skid shoes set so low was taken before any mowing...I re-positioned the shoes much lower before mowing (one hole up). I'll re-position them again (lower) before mowing again to see how that works.
These pictures clarify the skid shoes.
I set them when I lowered the roller...I reckon I can re-position them. I'll admit, I a novice when it comes to flail mowers...I'll learn as I go and heed the advice of fellow TBNers with more experience than I.
/ Let's talk flail mowers #4,685
Hello Roy,
I know you will love how the turf looks when you have your final mowing height set and by then all the scrub and the thick stemmed weeds will be gone and you can spread good grass seed in the fall to generate more good turf and choke out the weeds even further.
/ Let's talk flail mowers #4,686
The pics you posted above are good, that's exactly how you should be running the flail mower, with the skids not making ground contact. No need to readjust! The first pics you posted had the skids touching the ground. If they touch the ground you'll get gouge marks all over unless you have perfectly flat ground.
You've got it figured out, nice looking unit!
/ Let's talk flail mowers #4,687
They make a MiniMax now in 48, 60 and 72 inch sizes and the smaller one is around that price. I really prefer the Mighty Max, but the smallest is a 70" cut, but it's a touch over $5k in price. They are very, very good mowers but certainly are priced like something built very well right here in America, in fact right here in California. They are so smooth and quiet.
I do realize that most folks can't justify the cost unless they mow a ton or mow commercially.
Hello Dave,
What are the differences between the Mini Max and the Might Max, other than the differences in cutting width ranges (48"/60"/72" vs 70" and up)?
/ Let's talk flail mowers #4,688
Hello Dave,
The Mighty Max is about 50% heavier for a similar size. For example the Mini Max MM72 is 490 lbs, the Mighty Max C72 is 745 lbs. Everything is just heavier duty, especially around the a-frame area. The Mini is a good little mower and a step up from most imports, but to me the real desirable Vrisimo starts at the Mighty Max model and heavier.
/ Let's talk flail mowers #4,689
That certainly makes sense.
/ Let's talk flail mowers #4,690
I'm surprised by how light the Mini Max 72 is. The 73" Caroni TM1900 is listed at 650lbs.
/ Let's talk flail mowers #4,691
Toe to toe combat with big shale rock hiding in tall grass yesterday. Lost one blade but the rock split in two. I'm calling it a draw. IMG_1165.JPG
Pretty impressive. What was remarkable to me is that the old Caroni metric clevis survived and it was the blade that broke off. Usually the clevis is the weak point with these rock strikes.
BTW, photo shows good comparison of Caroni clevis and blade on left with Flailmaster clevis and blades on right. Slight difference in weight doesn't bother the mower. The Flailmaster clevis has shoulders ground down to fit but is still beefier than the Caroni.
/ Let's talk flail mowers #4,692
I've just recently started looking at flail mowers again. I did read the entire thread about a year ago. Roy, buying his new Caroni flail, got me interested again.
I've been looking at the Land Pride FM2584 and FM3188 mowers.
One of the tasks I have is mowing the edges of two ponds so, the offset feature should make that easier. I'm looking at the wider flails to achieve significant mowing track to the right of my tires. Right now I'm using a TSC Branded Switzer push type string trimmer. It does a good job but, it's not self propelled so, a lot of work to be sure.
Another feature of the LP Flails is both have Cat1 / Cat 2 hitches so I could use on both of our tractors.
The Woodmaxx flails are interesting but, their wider models are Cat 2 only.
The majority of my use would be with my LS XR4046HC tractor which is Cat 1.
Anyone have experience with the LandPride flails? We have two local dealers within 30 miles of ranch.
Thanks!
/ Let's talk flail mowers #4,693
Thanks!
Our fellow resident "Flail Mower Nations" member Docsfarm has a Maschio/Landpride flailmower on his Mahindra brand of water buffalo/mule and he loves it.
If either of those units is equipped with the cast flail hammers and brush ejection door they are the Maschio flail mowers from Italy with land pride paint and either one will work for you very well.
Land pride is making their flail mowers now and they do not have the brush ejection doors that lets you mow in tall brush without plugging and replace any broken hammers without crawling under the mower or turning the mower over to change them.
I cannot say anything as to the quality of the landpride built flail mowers one way or the other and I wish they had kept the relationship they had with Maschio as the Maschio company has always made heavy duty farm machinery and vineyard mowers and rototillers.
/ Let's talk flail mowers #4,695
/ Let's talk flail mowers #4,696
/ Let's talk flail mowers #4,697
The Chinese ones are in the $2500 range from Betstco for example. There's a lot of Italian ones too, many smaller than the link I provided above.
/ Let's talk flail mowers #4,698
Thanks for the info and links guys.
I think, if I can get sufficient cutter outside my right tire with wider cutter and good offset, I'll be ok.
/ Let's talk flail mowers #4,699
There's also ditch bank flail mowers. They can be offset much farther over than a regular offset flail.
For example: Iowa Farm Equipment -- Maschio GIRAFFA Series Ditch Bank Flail Mowers
I have the Giraffeta 160SE from these folks ( next unit lighter than the Giraffa). It has the outboard gear box so it can reach further. When I even do normal cutting I set it outside my tire track like I do with my drum mower. This reduces any uncut mowhocks that can occur after running over the grass before it is cut. Is also slick for cutting around trees as you just adjust the reach on the go to get around them. Being able to tilt it on its side makes it also a breeze to inspect and touch up the hammer flails if needed. Well built unit.
As a side note I know many units from Europe have the trash door. Mine was supposed to have it, but I believe their regulations now don't allow that feature as of 2016. I could be wrong, so be sure to ask the dealer.
/ Let's talk flail mowers #4,700
Thanks!
After 5 years with a 60" New Holland 918L, I have just bought and used a 72" LandPride (FM2172). I mow a 4-5 acre field with my Kubota B3300. The difference, as you might expect, is substantial. The duckfoot knives cut through tall, thck grass and twigs with ease, and the roller turns without digging into the ground. It's substantially heavier (it weights about 750 lbs.) than my New Holland, but the Kubota B3300, with the front end loader, handles the weight just fine. This is a first rate, well built machine, but then again it should be given the cost.
Sam
Clamp-On Heavy Duty Bucket Forks Attachment (A64553)
Clamp-On Heavy...
Woodsman 332 T/A Towable Brush Chipper (A64194)
Woodsman 332 T/A...
2004 Ford F-150 Ext. Cab Pickup Truck (A64556)
2004 Ford F-150...
2019 CATERPILLAR D3K2 LGP CRAWLER DOZER (A65053)
2019 CATERPILLAR...
2017 Gravely ZT-X 52in Zero Turn Commercial Mower (A64194)
2017 Gravely ZT-X...
2023 JOHN DEERE 450P LGP CRAWLER DOZER (A65053)
2023 JOHN DEERE...
