Show What Tool You Made*
/ Show What Tool You Made* #481
I made a welding cart for my shop.
/ Show What Tool You Made* #482
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=516409"/>When you need a spanner wrench and don't have the right size.
That's pretty dang brilliant, I love it!
/ Show What Tool You Made* #483
A metal rack converted from a Rocker clamp rack.
/ Show What Tool You Made* #484
I covered a piece of plywood with a piece of leather, to strop my carving tool.
/ Show What Tool You Made* #487
Machined oversize washer that bolts onto the Onan crankshaft timing gear giving the puller something to grab onto.
/ Show What Tool You Made* #490
Wouldn't something like this have been easier and more versatile? You'd then have another tool for the collection that is not implement specific.
/ Show What Tool You Made* #495
Put this one in the ultra crude and simple category. But I find it very useful when I assemble my choker chains. I put a pin formed from 5/16" rod on the loose end of the choker to make it easy to feed the chain under a log. I made this bending jig I use with my torch to put an eyelet in the rod. Just two bolts welded on a piece of 1/4 that I can hold in the vise.
gg
/ Show What Tool You Made* #496
gg
Cool, a bending jig. suitable for bending all sorts of things..:thumbsup:
/ Show What Tool You Made* #497
gg
What goes on the end of the rod and what are you using these choker chains for?
hugs, Brandi
/ Show What Tool You Made* #498
The chokers are used to connect a log(s) to a winch cable. The pins on the end of the choker chain are pushed under the log laying on the ground and then pulled thru from the other side so you can get the chain under to make a wrap. Much easier than trying to push the floppy chain under.
gg
/ Show What Tool You Made* #499
gg
If you were good like me you would just lay a series of chokers on the ground and then fell the tree ONTO the chokers. I like to do it this way as it saves a little time but that's just me. You should try it.
I also cut my felling notch such that the remaining usable trunk is exactly divisible by my sawyer preferred log length. This way there is less waste. You do have to take into account the width of your chain kerf. But that's just how I like to do it. :cool:
/ Show What Tool You Made* #500
Don't know why I never thought to do it that way. Much easier than bending all those rods :D
gg
(1) HD 24ft Free Standing Corral Panel (A65579)
(1) HD 24ft Free...
New/Unused Mini Quick Attach Auger with Bit (A65583)
New/Unused Mini...
HARGEE 18' BOGGIE AXLE METAL TRAILER (A63291)
HARGEE 18' BOGGIE...
Wagon Wheel Rocking Chair (A65583)
Wagon Wheel...
AR500 Deer Target (A65640)
AR500 Deer Target...
2012 Addco DH250-FM Towable Solar Message Board (A64553)
2012 Addco...
