New Firestone radials on M7040.
/ New Firestone radials on M7040. #1
sixdogs
Super Star Member
Ohio
Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
Here on some pics of new radials on the rear of my M7040. I would have bought front as well but can't get the 9.5x24 in radial. Maybe later. These are Firestone "All Traction DT" and I like that pattern better than the "Performer 85" radial series that has a slightly shallower tread and different shaped bars. There is so much rubber they almost look like an agricultural R-4 tire.
Radials work for me because I have to trailer things with limited weight totals yet sometimes need to pull an 8 ft chisel plow. With a bigger tractor, the weight is too much for the truck. With the lighter weight M7040, radials give me a dramatic increase in pulling power. In addition, I often drive over septic systems or lawns and the radial @6 psi barely leaves a mark. Radials are just perfect for this, or really any agricultural work.
Out with the old Firestone SAT 23
In with the new.
/ New Firestone radials on M7040. #2
They look over aired. Should be some squat to those radials. You will love the radial.
/ New Firestone radials on M7040. #3
DOGS:
WHY DO radials give you a dramatic increase in pulling power? Obviously bigger cleats but what other reasons?
Are radials ever filled with liquid, or always air?
I have some cloudy ideas about experimenting with radials when tire change is necessary on my L3560.
I always use Michelin radial tires on my cars.
/ New Firestone radials on M7040. #4
Those look so much better than the originals! Let us know how you like them.
They sure are over-inflated. I do that for a few days to make sure they seat. I've had them leak at the bead when new. They will go to 6 PSI but have 20 psi in now.
DOGS:
It's the lower air pressure and construction of the tire sidewall that allows the tire to sit flatter to the ground for a greater footprint. That distributes weight over a bigger surface and puts more horsepower to the ground rather than just slipping away. The deeper lugs really make a difference if you have the HP to make use of them.
Michelin makes a great car/truck tire and a great ag tire as well. I just like Firestone ag tires and I think Michelin owns Firestone anyway.
I have a set of four of these All Traction DT Firestone radials on a 90 HP Deere and they are impressive and then some. I can seriously out pull a similar tractor with bias tires and the difference is like a 1960's car tire and a modern Michelin radial. Plus in clay ground compaction is way reduced. You are right and they sure do look better.
/ New Firestone radials on M7040. #6
How many "ply" are radials? Are ply layers optional? I do considerable work around our community burn pile, which is trashy at times.
Do you think radials are as puncture resistant as R4s?
I believe radials are one steel ply that makes up the whole sidewall and tire itself and then several more steel layers were put under where the tread will go. That's what I remember. The sidewalls need to be flexible to make things work.
They are much tougher than bias tires and I can't recall ever seeing one with a puncture. Guys run them in corn stubble at harvest and that takes years to wear the edges out. Bias ply wouldn't last a season. There may be some R4's that are specially made tougher but I'm not sure on that.
/ New Firestone radials on M7040. #9
Have you used radials on the front when using a FEL? I'm curious how they handle the load.
I have. On the Deere 5520 they are the metric equal to 12.4x24 and I pump them up to maybe 28 psi when the loader is on. They handle great at that number with no tire roll or anything with heavy loads. They handle the load just fine.
/ New Firestone radials on M7040. #11
That's good to know. I like the idea of the larger footprint and less compression. What's your guesstimate for cost? Let's say how much more (%) are they than a comparable tread in a bias tire?
The price is probably double and a little bit compared with quality bias tires. I traded in my old ones so not exactly sure but you can search the net. My 16.9x30's probably were $1,200 each. The lesser "Performer 85" would be maybe $1,000 each. A 12.4x24 equal might be $550. Mounting is usually $20 to unmount and $20 to mount. That's if you bring the tractor in and they don't have to remove the wheels.
Radials like Firestone or Michelin aren't usually offered in the smaller sizes like a 9.5x24. You have to look around but European makers often sell them but they may also look European.
/ New Firestone radials on M7040. #13
I have not gotten them yet but BKT makes a radial to replace the 9.5-24. It is a 250-85-24. I think this fall i might get some. The 9.5 are terrible, they tear up everything. Matt
I looked at the BKT and will probably eventually get some for the front. I thought I had a price for them but can't find it. They seemed reasonably priced and I think they had a European looking design. They can still chew things up a bit, especially if the air pressure in higher, the loader is on or you make sharp turns, especially in FWA.
I think there is a guy from Europe or Canada here with an M7040 or 7060 that has those tires on the front. I saw a picture here and am pretty sure of it.
Here is the tire that I think you are talking about. Not much in the way of 9.5x24 (250/85R24)radials around and this is the only one I could find. If you see a price somewhere, let me know. I recall $290 each but not sure.
BKT Tires - AGRIMAX RT 855 Product
EDIT----Just found the quote-- $285 each
/ New Firestone radials on M7040. #16
My L6060 happened to be parked next to my M7, steering tire (540/65R28 Michelin R1-W) alongside the driver (17.5 x 24) on the L6060. There is room to put that large tire on the L6060 but no room for a larger front tire on the CUT to match speed ratios. The R1W tires have a 35% taller lug than a standard R1 ag tire. They also rip up the ground a lot worse than R4s and standard R1s when turning but the traction is great.
I'll bet you have a dramatic increase in pulling power with those Michelins on that tractor.
/ New Firestone radials on M7040. #18
It's fantastic. That little 14' disk behind it isn't normal. My nephew is trying to sell it, wanted the rust worn off the blades, but it started raining while I was disking a week ago. It has rained every day since so it's rusted up again.
/ New Firestone radials on M7040. #19
When I farmed before retiring, we ran Firestone radials and Michelin Agri-Bibs radial tires. The Michelins were a little more aggressive than the Firestone's. If you have never run radials on a tractor, you will be amazed at how much better they pull. They wear better and turn any tractor into an amazing pulling machine.
So I've been trying to find some 250/85R24's to replace the 9.5x24's that are on the front and no dice. MITAS might be sold all over but my tire guy can't seem to find any. Since I'm trading in my old tires I want to buy through him. MITAS is the only maker in that size.
I sure wish Firestone would make a smaller radial but I guess the market isn't there for it. They sell a bunch of small radials in Europe and I think Canada but I can't figure out how to get one here for a reasonable price.
UNVERFERTH PERFECTA II 18' FIELD CULTIVATOR (A63291)
UNVERFERTH...
2012 International WorkStar 7300 AWD Altec DC47TR Insulated Digger Derrick Truck (A60460)
2012 International...
2023 Kubota M7-174P (Premium) 4WD Tractor - 400 Hours (A63688)
2023 Kubota...
karcher pressure washer (A61567)
karcher pressure...
2019 PETERBILT 389 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2019 PETERBILT 389...
2020 Peterbilt 567 Quint Dump (A62613)
2020 Peterbilt 567...
