Flail Mower Let's talk flail mowers
/ Let's talk flail mowers #4,621
Shaeff, check your pm. Those are the knives I just took off my dandl. Yours for the FRB postage.
/ Let's talk flail mowers #4,622
Couple more photos from taking our 54" Caroni out for a spin(har har) the other day. Really impressed with how it did on the hood-level brush. More than a few thistles and blackberry bushes in there that were no match. One thing I did notice is some of the tall grass would occasionally get missed an pop back up. I'm mowing at 4" so I'm assuming if I set it lower that wouldn't happen? We still want to leave some graze for our livestock so I think I'll leave it at that level for now.
Also, does everyone adjust their skids when they adjust cutting height? I know that's what the manual says to adjust them both but changing 10 bolts is a pain. If the skids are just to keep the flail from hitting the ground wouldn't just having it at close to the lowest setting make changing the height much simpler.
/ Let's talk flail mowers #4,623
No, skids just keep the rotor & to some degree the flails from hitting the ground. I always leave my skids up. Sometimes I run it really low so the flails graze the dirt. Like this week right before I had an arena tilling job. Rough on the flails I expect, but they have survived worse for over 2 years. Lost a couple flails finally the other day to a softball sized rock (dam that field was trashy).
Mine cuts fine despite the wear & abuse on the side slicers, so I don't feel the need to bother sharpening them.
/ Let's talk flail mowers #4,624
Subscribed to thread
Glad to have you over here Roy. Watch out you might learn something :laughing: . Do you own a flail mower? I've got a couple of old beaters but they cut good. I don't think I have them listed in my profile, one is a Mott 72 and the other is a Ford 907. Mott = Finish. . . .Ford = Rough cut (sorta)
/ Let's talk flail mowers #4,625
Got it, yeah I couldn't figure why the manual wanted to change 10 bolts each time you switch mowing height. Doing them by hand with a breaker bar is a pain.
/ Let's talk flail mowers #4,626
Well I sorta own a Caroni TM 1900...bought and paid for, hasn't been delivered yet.
Since I'm not familiar with Flail Mowers, I joined this thread to learn a few things. There are a couple guys on the thread who do have pretty extensive knowledge of Caroni flail mowers.
/ Let's talk flail mowers #4,627
If I'm ever in the market for a new or newer flail I'd check out the Caroni closely. From what most say about them you can't go wrong. I'd hate to think I had to make a decision on what to buy if that time ever comes. When it comes to dropping 2 grand or more I get very indecisive like a squirrel trying to cross the road.
/ Let's talk flail mowers #4,628
Well I got my belts last Saturday but, when it came to fitment, I discovered that they were the wrong ones. Far too big. There's no tension to speak of even with the tensioner fully screwed in. Back to the place I bought them from. Pita!
/ Let's talk flail mowers #4,629
Finally had a chance to get out and get some long overdue mowing in. Grass was hood high on my Oliver 770 in spots!
I have an Oliver 770 diesel with an aftermarket 3 point hitch paired with a Mott/Alamo SD88. Ideally I'd love 5-10 more HP but the vast majority of the time it's a great pairing.
/ Let's talk flail mowers #4,630
Raising the skids is more useful when cutting good sod grass as you know what yopu are driving over at all times.
If you lower the rear roller to 2 inches in cutting height your animals/feed burners will have more grass shoots than they know what to do with. The more you top the sod(mow) the more weeds you will get rid of so no worries there either and the stalks will rot away as they will have no leaves to collect sunlight.
With the skids the primary concern is protecting the flail mower rotor, bearings and knife sets at all costs; so as long as the flail mower is absolutely level when mowing and the skids are 2 inches above the ground you will not have issues with scalping.
Where ever you set the cutting height you must set the mower level and you do this by using a torpedo level on the gearbox as you adjust the top link to dial it in.
(you must also be mindful of the lower links assuring that they cannot sink on you by either using the locking knob on the control valve)
I would feel so much better if all the manufacturers used a 4 wheel adjustment system to protect the mowers at all times and it would still let the mower ride on the rear roller.
It would cost more in purchase price but the mower would last longer than any mule tied to it as the the adjustments are done by using thick steel washers on the wheel sets by adding to the lower portion of the individual wheel weldment stub to raise the flail mowers cutting height from side to side and front to back or to lower the cutting height by removing them on all four corners and putting the washers on the top under the locking lynch pin to secure them and the mower is protected at all times.
/ Let's talk flail mowers #4,631
Figured I'll chime in here for the first time. Ive read most of the posts so I'm up on some stuff. I bought an older Bush hog fh188-01 just last week and have been working on it to make it better then it was.
I changed the oil and greased the bearings, tightened the belt and generally went over it to get it ready to use. Yes I did say belt as in just one. It is a Gates 2/B54. I love this belt it is a double V-belt bonded together. Works great now that I got the tensioner pull on the right side of the belt.. It was on the inside of the belt with the V's riding on it instead of on the outside so the pulley was riding on the back of the belt. Looks and works a lot better that way. I bought 3 new knives and links for it to replace the ones missing and now it works great. I mean it worked good enough without them, just left 3 stripes where they weren't.
I'm using my new LS G3033 with FEL to run it and havent had any problems other then having to go to a lower gear where the brush got a bit thick. All in all I like the flail better for the finish it gives in in the field but I still use the Rotary to knock down the 1-2" garbage in the woods area,
Looks like the Bush Hog and the Ford or is it Mott are the same. I forget which it was since the information overload of reading over 4,000 posts is a bit much to handle at my age. How old am I? Well let's just say that I know the class of '67 was the best.
Anyway just wanted to touch base and give a bit of info.
MG
/ Let's talk flail mowers #4,632
Welcome Clearsmoker. I also use a rotary for initial mowing of heavy brush, mostly because there is a lot of metallic and rock debris in some of the overgrown fields. I think you'd find that the flail will handle up to 1.5" without much bother but beyond that size the rotary is better for the initial messy cut.
/ Let's talk flail mowers #4,633
Welcome to the club, Clearsmoker!
I knocked my roughly 2 acre field down five weeks ago, then again a few days ago. Trying to get rid of a lot of the weeds and get it to remain field grass.
/ Let's talk flail mowers #4,634
Yes I have read that the flail will handle up to 1.5". Unfortunately I found that like a few other people my flail will only bend those over and strip the branches off. On anything up to about 3/4" it works just fine. That's why I did the rotary first just running around and cutting down the bigger little pines and then the flail for the nice fine cut and manicured look. Also found out that it will prepare a nice seedbed for new grass if you lower it to the bottom. Just had to go slow. Probably not too great for the knives but I'm planning on getting new scoop knives to replace the wore airplien wing knives that are on there.
I'm glad I don't have any rocks to worry about, just some pieces of badly rusted sheet metal that I ran into. That woke me up! No wire yet unless you count the extension cord that the mower found in one corner. Popped the shear bolt but the cord wasn't even skinned open.. Only took 2 min to unwind it. Looks like I have a new extension cord to use. Nah only kidding. It's going to metal recycling.
/ Let's talk flail mowers #4,635
My flail has better eyes than me, as somebody said, it can seek out and fine stuff I don't see. Wrapped up some baling twine at my neighbors pasture that I didn't see but took a lot more time than your 2 min unwind to remove it all.
I have a couple of old flails I use and just bought another this week. It's a Bush Hog FH 174. It's a beater with several of the side slicer knives missing and parts of the deck cut out where it probably got bent and letting the knives hit so they just cut it out. I just use these to keep junk knocked down around the field roads except for my Mott 72. It's a finish cut flail with lots of the side slicer knives. I use it on my extended lawn but use a lawnmower around the house.
My Ford 907 had the wing looking knives on it when I got it but I've since changed it to scoop knives. The Bush Hog I just got has the side slicers on it but they are heavy built... 2" wide X 1/4" thick. There's only 30 ish,,, stations on it so its more of a rough cut I think. Haven't had time to look at it much to see if it's worth repairing. Also needs bearings in the back roller.
/ Let's talk flail mowers #4,636
Does your Bush Hog FH174 have the same drive belt arrangement as your Ford 907?
My Bush Hog FH188 looks exactly like this.
And the belt system is the same as below even though I belive I downloaded the pics from a post that said it was a Ford.
Of course mine started out a red color but is now a very shiny blue.
/ Let's talk flail mowers #4,637
That & maybe all of the older Brush Hog flails are just rebadged Ford flails. Not that it's a problem, I like my Ford 917, other than is 20-30 years past it's prime & beat to **** these days.
/ Let's talk flail mowers #4,638
This is the Ford 907 it has 1 "C" size belt.
This is the Mott 72 I use mostly for finish cut. It has 1 "C" size belt and 96 stations = 192 blades.
I haven't had time to look at the Bush Hog FH 174 haven't even taken the cover off but it does have the twin belts that are tied together as 1 belt. Don't know what you call them. Here's a picture I took Monday when I picked it up. It was sold as parts only but might be worth repairing. ?? I'll post some pictures of the drive as soon as I can maybe a few days.
/ Let's talk flail mowers #4,639
My ford 907 is not as heavy built as your 917. I think it's a older mower also. It's heavy enough for what I do with it but not as hefty. The 907 and 917 can use some of the same knives and mine had the wing looking blades until I changed them to scoop. The scoop knives were a bit longer so I also had to replace the hanger.../D ring or V/ring with a shorter one. I'd been better off the just replace with the original wing. The side slicers for these mowers are pretty heavy built but to me it's just not enough of them compared to my Mott. Mott has 4 rows of stations with 24 in each = 96 stations = 192 knives. Ford has 3 rows of stations with 11 in each = 33 stations = 66 knives. Both are 72" cut.
I was looking for a 917 when I ran across this 907 and settled for it since the pickens are slim for flail mowers around here except for the crop choppers used by farmers.
/ Let's talk flail mowers #4,640
I have seen posts about how to set the flail mower to cut a certain height. Here is what I did and do.
I moved my Caroni 1900 skids up one bolt, may have moved the roller up one also...can't remember. The way I set the Caroni to mow is I have the tractor and mower on level ground, lower the 3 point hitch until the roller touches the ground, then lower it further until the front edge of the skids are a couple of inches above the ground. I set the 3 point hitch controller stop at this height. I then adjust the top link to put the hitch pin in the center of the slotted hole on the Caroni. I then double check the height of the front edge of the skids and adjust the 3 point hitch height stop as necessary and check the top link pin position again and adjust again as necessary.
I get about a 3 to 3.5 inch cut which is perfect for bermuda grass
2023 John Deere 317G Compact Track Loader Skid Steer (A64553)
2023 John Deere...
BRIGGS & STRATTON STORM RESPONDER GENERATOR (A64276)
BRIGGS & STRATTON...
2017 Cadillac Federal 70IN Limo w 27466 Miles, Premium Federal Coachwork, Luxury Transport (A63689)
2017 Cadillac...
1999 INTERNATIONAL 4700 - 6 WHEEL GRAIN TRUCK (A64278)
1999 INTERNATIONAL...
2018 Chevrolet Tahoe SUV (A64194)
2018 Chevrolet...
2025 KENWORTH T880 DUMP TRUCK (A63276)
2025 KENWORTH T880...
