I Learned something today about weight
/ I Learned something today about weight #1
Msamt
Gold Member
Enfield, NH
Kioti Dk45SE
Operated the machine without the counterweight on the 3ph for a few hours - too lazy to put it on after welding the chains to the pins on it
Night and day, so much less stability, and really showed me how much time I save with ballast, it was an eye opener how much surer 900lbs out back made the tractor perform.
Also couldn't back worth a crap either up even slight hills. In 4wd, Low, locked diff.
If you havent considered weight on the 3ph, it's likely the simplest way to work better, and stay alive longer!
MT
/ I Learned something today about weight #2
MT
A good lesson for all. And these problems manifest themselves even more when working on sloped terrain.
/ I Learned something today about weight #3
Here too. I did some loader work without the hoe attached and had trouble climbing a slight hill with the bucket full. Kept spinning the rear wheel. I needed to use four wheel drive to climb.
/ I Learned something today about weight #4
I agree totally, it only took me one bucket full to learn to keep weight on the 3pt hitch. In fact, when using my forks, it will only lift about 3/4 the total weight without lifting the rear filled tires off the ground when there is no weight on the back.
/ I Learned something today about weight #5
Upon reading the title of this thread, I thought the first sentence would begin with:
"Well, the Doc says my broken toes should heal in about 4-6- weeks....." :rolleyes:
...but maybe you've already learned that about weight.
/ I Learned something today about weight #6
Are you running R4's on the rear,if not load them along w/rear ballast more of positive different. :thumbsup:
Now that's funny....
Yep, loaded with Rimguard and dished to the full width. Still need weight on the 3ph using a loader no matter what (at least that's my story, and I'm sticking with it!)
/ I Learned something today about weight #9
That's a good story, one well worth sticking with!
/ I Learned something today about weight #10
Arrgghh! I had a broken foot last summer. Broke the bone from the little toe to the heel on the outside. Not fun. No more noise about broken stuff, it gives me flashbacks...lol :ashamed:
/ I Learned something today about weight #11
The loaded rears will help keep the rear end on the ground, but that doesn't lower the weight on the front axle. Only the 3PH ballast will lower the weight on the front axle, moving it to the rear axle, when lifting a load. :thumbsup:
/ I Learned something today about weight #12
Yeah I learned real quick I like to have the bush hog attached to the 3 point if I am going to be operating large weight in the bucket. Moving small square bales of hay it does not matter. A bucket full of the highly clay soil I have on the other hand...
/ I Learned something today about weight #13
I have a 2538 with loaded rears. 3pt arm bent, or more accurately, I bent it, so had to run around without anything on the rear for a few days. Jeez Louise what a crappy couple of days.
/ I Learned something today about weight #14
Except when I need PTO this never comes off, filled with steel, about 700 Lbs.
