I Learned something today about weight
   / I Learned something today about weight #1
Msamt
Enfield, NH
Kioti Dk45SE
Operated the machine without the counterweight on the 3ph for a few hours - too lazy to put it on after welding the chains to the pins on it
Night and day, so much less stability, and really showed me how much time I save with ballast, it was an eye opener how much surer 900lbs out back made the tractor perform.
Also couldn't back worth a crap either up even slight hills. In 4wd, Low, locked diff.
If you havent considered weight on the 3ph, it's likely the simplest way to work better, and stay alive longer!
MT
   / I Learned something today about weight #2
MT
A good lesson for all. And these problems manifest themselves even more when working on sloped terrain.
   / I Learned something today about weight #3
Here too. I did some loader work without the hoe attached and had trouble climbing a slight hill with the bucket full. Kept spinning the rear wheel. I needed to use four wheel drive to climb.
   / I Learned something today about weight #4
I agree totally, it only took me one bucket full to learn to keep weight on the 3pt hitch. In fact, when using my forks, it will only lift about 3/4 the total weight without lifting the rear filled tires off the ground when there is no weight on the back.
   / I Learned something today about weight #5
Upon reading the title of this thread, I thought the first sentence would begin with:
"Well, the Doc says my broken toes should heal in about 4-6- weeks....." :rolleyes:
...but maybe you've already learned that about weight.
   / I Learned something today about weight #6
Are you running R4's on the rear,if not load them along w/rear ballast more of positive different. :thumbsup:
Now that's funny....
Yep, loaded with Rimguard and dished to the full width. Still need weight on the 3ph using a loader no matter what (at least that's my story, and I'm sticking with it!)
   / I Learned something today about weight #9
That's a good story, one well worth sticking with!
   / I Learned something today about weight #10
Arrgghh! I had a broken foot last summer. Broke the bone from the little toe to the heel on the outside. Not fun. No more noise about broken stuff, it gives me flashbacks...lol :ashamed:
2019 PJ TRAILER 32FT GOOSENECK (A58214)
2019 PJ TRAILER...
New Holland 650 Hay Baler (A53317)
New Holland 650...
2009 International 7400 T/A VacCon V311LHA Combination Sewer Jetter Vacuum Truck (A56858)
2009 International...
UNUSED FUTURE ML32 - 32" MINI HYD MULCHER (A52706)
UNUSED FUTURE ML32...
2019 ALLMAND BROS, INC. ALLMAND BROS, INC. (A55745)
2019 ALLMAND BROS...
2013 Ford Taurus Sedan (A56859)
2013 Ford Taurus...
