Trailer tires
/ Trailer tires #1
Clemracer
Sheridan,in
Kubota b2601
How old should you let your tires go. Mine are 6 years old and just had a blow out.
/ Trailer tires #2
I would inspect them for dry rot / cracks. They can last a VERY long time if kept out of the elements, but with a lot of sun exposure you might be at the end of their life. If they are suspect and one already went it's probably time. I pushed my last set 10+ years, but it's parked in the shade. Larger ply tires can last a bit longer as well.
/ Trailer tires #4
Time for all new ones. Get rsdials with high pressure valve stems and balanced. My favorite brand is Greenball.
/ Trailer tires #5
The only trailer tires I use are the ones on my 5th wheel camper and I change all six every five years, but on a camper, a blowout is usually more than just an inconvenience, it can cause some pretty extensive and expensive damage to the camper.
I've always been told that trailer tires don't wear out, they age out, and that five years is about all you can expect from them. The first 5th wheel I owned, the only blowout I had was during the tires sixth year. They looked good, but one blew out at interstate speeds. I changed the four on the axles during that vacation, but left the spares alone. Four months later, one of the spares blew the sidewall out while bolted to the spare carrier, destroying the tire cover I had on it. Since then, all tires are replaced on a five year interval.
/ Trailer tires #6
^^Yeah, what he said.^^
Also, most if not all "trailer service only" tires are rated for a maximum of 60 mph. I see a lot of hotshots pulling their RVs and trailers of all kinds at speeds far north of 60 mph. Regardless of the tire's speed rating, towing at speeds in excess of 60 mph is a risky activity at best.
/ Trailer tires #8
A blanket statement with which I do not agree. Holding speed to 60 mph on stretches of interstate marked at 70 or higher is more risky than towing at 70+ with good tires / brakes. I could not mentally tolerate a full day of towing at 60 mph or slower in the western parts of the USA.
And I don't consider myself a 'hotshot', especially with the family aboard.
/ Trailer tires #9
Hence the name "Speedy."
My truck finally gets rolling good at 62-64 where it doesn't want to downshift. If I can't drive all day at 73 on the interstate or whatever the flow of traffic dictates, I would see about a different tire.
/ Trailer tires #11
There are speed rated trailer tires now. Power King is one with an "L" rating yielding 75mph.
/ Trailer tires #12
I have taskmaster trailer tires on my equipment trailer and they are rated for 81mph.
/ Trailer tires #13
Got me on that one... Ha.
Good point about the truck being 'in the power'. My 6-speed manual truck is really happy at 70 mph.
/ Trailer tires #14
This is very true.
I have Hartland tires with a speed rating 'N' which is 87 mph. Of course there is a weight and air pressure spec that goes along with that speed rating.
These tires allow me to maintain posted speed and not be a ROAD HAZARD because I have to travel slow due to trailer tires.
/ Trailer tires #15
My Maxxis tires are speed rated. Can't remember the rating and I'm not at home now.
Buy good stuff and use it - that's my plan.
/ Trailer tires #16
The 4 Carlisle Sure Trail ST on my 7x14 landscape trailer are like new. No crack/s in the sidewalls and no problems. They're old, quite old actually and where made in the USA back in 1978. Trailer sits in my shop and is out of the elements at all times unless it's in use, but isn't being used very much anymore. If one blows, they'll get replaced. Otherwise they stay.
/ Trailer tires #17
We can't get any trailer tires around here that aren't made in China. Just have to live with replacing them frequently or using truck tires.
/ Trailer tires #19
My tire speed rating is determined by my towing vehicle, lol.
David from jax
/ Trailer tires #20
You better savor those and keep them out of the sun and don't ever let them go. The newer Carlisle tires are like all the rest GARBAGE.
we got the radials 5 years back and they started cracking within a year or so. Last I knew the radials :)thumbdown: which I know are junk) are made in China. The bias are made in the US and how they perform I can't say.
2015 Ford Taurus AWD Sedan (A64557)
2015 Ford Taurus...
John Deere 5000-Series Tractor Grill Guard (A65640)
John Deere...
New 2x27 Ratchet Strap (A65579)
New 2x27 Ratchet...
Bucket (A64194)
Bucket (A64194)
2025 IRET13 Electric Tricycle (A64194)
2025 IRET13...
INOP/NON - RUNNING 1997 Procraft Fish/Ski Boat (A65579)
INOP/NON - RUNNING...
