With my wider (than my tractor)
grapple I am able to test the space in which I will run my tractor through, test to see if I will fit (with a bit of wiggle room). I can also probe off to the sides where I don't know what's in the underlying brush: I have a lot of logging debris to contend with.
I have found that (because I can never seem to perfect the art of determining the perfect balancing point) in cases in which I have an off-center load that the wider
grapple base works well to hold a load: most times I don't have the best angle to attack things- it's my world, I'm pretty used to working in it
Travis, I think that you had recently posted some pictures of such loads that I'd placed in another thread. Does it put a twisting strain on the loader? Sure. But but with a more concentrated load in a smaller
grapple you can have a load shift and present an equally, if not an ever greater, twisting force: this argument is overblown. A wider
grapple also allows one to rip a wider section when ripping up roots: I have lots of area to clear, lots of blackberries and salmon berries- LOTS of roots! (with bush hog in the rear and the
grapple in the front I'm able to make for pretty quick work of this)
It's a BIG world out there. Sometimes one has to have a BIG
grapple! :thumbsup:
