Build your own grinder plans
/ Build your own grinder plans #1
Cord
Richfield, Wi
Resident Architect
Earlier today I was watching an old episode of Forged In Fire. I kinda dig the show and I took notice of the belt grinders they were using. At first I thought they were multi thousand dollar pro units, but I noticed the interchangeable attachments had a home made look to them. I tried to do a google search and turned up several grinder plans that people use to build their own grinder. That certainly works with my budget! I was able to find two different grinder designs and both seem to have their own advantages. I've got a 1.5hp motor left over from a past project but these guys seem to be liking variable speed grinders. One design uses a belt and pulley to change the speed, the other builder uses a VFD to control the motor speed. VFD's are a really slick, but honestly, I'm not sure why there is a need to change the speed at all. Has anybody ever tried building a grinder from these designs? Was the outcome satisfying or prone to problems?
No Weld Grinder Detailed Plans to Build Knife Grinder | eBay
Grinders
/ Build your own grinder plans #2
Pick a set of plans for a design you like, but SKIP the "no weld" approach. I'm certain you will be able to build a nice unit unencumbered by all those nuts and bolts. Ugh.
JMHO of course
I considered building one also until I started adding up the parts (didn't have a spare motor like you do).
I found bought this used one off eBay (Burr King 482) for $500USD plus shipping. Needed a bit of work though.
Good luck!
Terry
/ Build your own grinder plans #3
I built a "Grinder in a Box" from the Polar Bear Forge,
It's been a serious metal eating workhorse in my shop, but you will spend some serious coin on it after you get real wheels especially, mine are from Beaumont Metal Works. I use a 3HP, 3-phase motor for mine (bought for only $100), and run it with a VFD for speed control.
Here is a video I made of it: Grinder in a Box (GIB) Build, Details and Operation. - YouTube
Here are some pics, most are captioned I think: GIB Build
I still have a few things I'd like to finish better and improve-mostly the platen but I never seem to have time to get to it!
Oh: I did buy the "no weld" plans first...I was not very impressed.
I agree that no weld design does look hokey. Can I ask what the wheels ran you?
/ Build your own grinder plans #6
It's been a few years, but I seem to recall $500-600 but I built two attachments/tool arms and used a expensive 8" wheel on one of them. You'll have to decide the style you'd want want to build then price them at the link I posted above for Beaumont. You'll also need to pick a drive wheel diameter once you determine the motor your using and the belt speed you want to achieve. I just saw there is a new wheel/parts source linked on the PBF page, I know nothing about them though. Rob at Beaumont has a great reputation for service a quality parts.
/ Build your own grinder plans #7
1x42 belt sander from an old clothes dryer for the motor, idler, a stand off a John Deere hay bailer and a roller skate wheel.
No need to get fancy if you just want something that works and don't care what it looks like.
306806d1362625200-show-what-tool-you-made-img_20130306_205823_592-jpg
/ Build your own grinder plans #8
Looks pretty nice to me. :)
Terry
/ Build your own grinder plans #11
If you like the clothes dryer one, you might like this one too. I machined an aluminum wheel to take the place of a stone on a bench grinder, and added the rest of the sander to a plate the grinder bolts to. And recycled another roller skate wheel.
509187d1494559987-build-your-own-grinder-plans-image-jpeg
/ Build your own grinder plans #12
This is such a brilliant idea and I'm considering it! Thanks for sharing!
/ Build your own grinder plans #13
I saw plans some time back (I used to build bows, as in recurve and longbow) that a guy made from wood. In some woodworking book. Anyway, the "wheels" were nothing more than MDF (I think) circles that were glued together, with a centered hole all the way through for the shaft, with larger holes on the outside with bearings pressed in them.
This was a horizontal sander. One "wheel" was cut with a crown to facilitate belt centering and adjustment.
2013 WESTERN STAR 4900 SB MIDROOF SLEEPER (A63569)
2013 WESTERN STAR...
Tank (A64047)
Tank (A64047)
2020 DRAGON ESP 150BBL ALUMINUM (A63569)
2020 DRAGON ESP...
YALE VERACITOR 50VX STRAIGHT MAST FORKLIFT (A63276)
YALE VERACITOR...
Bobcat T76 Compact Track Loader (A64047)
Bobcat T76 Compact...
EZ-GO GAS GOLF CART (A63276)
EZ-GO GAS GOLF...
