Cast iron routing table....
/ Cast iron routing table.... #1
Richard
Super Member
Knoxville, TN
International 1066 Full sized JCB Loader/Backhoe and a John Deere 430 to mow with
Has a couple rust spots starting...
What can/should I use to coat it with to protect it?
I'm guessing something like mineral oil? (light coat of course)
How about something that I already have on hand, peanut oil?
/ Cast iron routing table.... #2
I like paste furniture wax. Clean up the rust spots with steel wool then apply the wax, it protects and the work piece glides across the surface really nice and smooth.
/ Cast iron routing table.... #3
Yep, don't put any kind of oil on it as it will come off on the wood. Use a wax.
/ Cast iron routing table.... #5
BOESHIELD T9
T-9 Rust Protectant, 12 Ounce Spray, was developed by Boeing Aviation for long term metal protection on aircrafts. A solvent and paraffin wax formula, it penetrates into metal pores, displaces moisture and dries to a thin film that will protect your woodworking equipment for months. Since it contains no silicones or Teflon and dries completely within a few minutes, it will not transfer to wood surfaces or interfere with subsequent finishing. The 12 oz. non-fluorocarbon spray is ozone safe.
No Silicones or Teflon
Dries within minutes
Non-fluorocarbon Spray
/ Cast iron routing table.... #6
Get it smooth and shinny by whatever means you wish. (Belt sander works for me) Then apply naval jelly or phosphoric acid and wait several days before you make it shiny again. Then a wax. I use floor wax but there are many others that would work. Real serious and a coat of clear expoxy might be considered.
I'm guessing with the T-9, I should first put some elbow grease into the growing spots prior to applying it?
/ Cast iron routing table.... #8
MinWax paste wax is what I use. Cut off a chunk of it and put it in 2 layers of cheesecloth. Rub it on the table top, take a break, and buff it out. It lasts quite a while.
/ Cast iron routing table.... #9
With the T-9, I sand all my metal table tops and clean with paint thinner or brake cleaner. Spray on T-9 and let dry for a few minutes and wipe off. Clean top and recoat every few months. Helps the wood slide on the top. If I am doing a lot of wood working I will spray some on and wipe off to help the wood slide easier.
/ Cast iron routing table.... #12
Another vote for paste wax
/ Cast iron routing table.... #15
Back when I had a cabinet grade table saw with a cast iron table, I used bee's wax on it. I would use a fine steel wool on your rust spots, rubbing by hand. I certainly wouldn't use a power sander of any kind, but just me I guess. Now I just have a cheapie "hobbyist" saw with an aluminum table, so no worries there.
/ Cast iron routing table.... #17
Gallon lasts me over a year. I bought a sweet pump spray bottle as per Amazon recommendation. Very handy for my forge area, equipment maintenance etc. I have a couple spray cans for tight areas, nut and bolts, battery terminals, boat stuff etc. it isn't cheap but the rust busting abilities, creep and protection is the best I have found. Spray cans are 12 oz and run 15-20$, a 128oz gallon is a deal.
/ Cast iron routing table.... #18
When I had a rust area on my table saw caused by a cold beverage bottle I used a sanding block with a fine grade sand paper. Once all the rust was gone I used a paste wax to protect it.
/ Cast iron routing table.... #19
I use Johnson Paste wax on my tools. Keep the beds dry and don't allow anyone to put a soda or bottle on your tools.
/ Cast iron routing table.... #20
I use automotive wax. Seems to hold up better than regular paste wax.
20' One-Trip Shipping Container (A66285)
20' One-Trip...
International S1900 (A63689)
International...
Cattle Feeder (A65640)
2012 FOREST RIVER 24' T/A ENCLOSED TRAILER (A65643)
2012 FOREST RIVER...
Kubota V3600-E3-EG60 Diesel Engine - 3.6L - Tier 4i - Irrigation Pump Takeout (A63689)
Kubota...
Stout Utility Grapple XHD84 (A66285)
Stout Utility...
