Comparison Need a Solution if there is one
/ Need a Solution if there is one #1
whatever1
Earth
I have about 7 acres, hillside ranch and the front yard is slopped. and would like something to cut grass, blow snow ( have a steep driveway) and do some yard work 9 moving dirt, stone etc.
Currently I have a Kubota BX-24 for the snow and yard work. And a JD 318 for grass cutting.
Big problem is with the BX going across the front yard, it feels like it is on the edge of tipping. I have spacers on the rear wheels but still feels unstable.
Is there any SCUT that has a lowwer center of gravity ? Or anything I can do to the BX ?
Thanks.
/ Need a Solution if there is one #2
You have a front loader on while mowing ?
/ Need a Solution if there is one #6
No, what kind of fluid ? Will it cause a problem with the wheel spacers ?
Rim Guard. It's waste product from sugar beets, doesn't cause corrosion and is heavier than water. It shouldn't be an issue with your wheel spacers. It will lower the COG of the BX a good bit.
/ Need a Solution if there is one #7
What type of fluid depends on where you are at. I have used beet juice and was not enamored with it - it is a major sticky mess if you have an issue. Water and glycol (anti-freeze) works well but jsut make sure you have the mix right so it never freezes where you are at. (I cannot tell what climate you are in.) Windshield washer fluid works well in some areas.
Everyone Thank you for the suggestions. I was looking also for an alternative to the BX. Did not know if there was anything else more stable with the same capability.
I talked to Kubota and was told to either load the tires or use wheel weights but not both. And definitely NO spacers. So I ordered some weights and going to give that a try. I figured spacers are removable if need be a lot easier than draining liquid.
Thanks Again
2015 Nissan Frontier Ext. Cab Pickup Truck (A64556)
2015 Nissan...
2008 Chrysler Sebring Sedan (A64194)
2008 Chrysler...
2022 Kaufman Trailers Trailer, VIN # 5VGFW5035NL009932 (A65563)
2022 Kaufman...
Ellis Band Metal Saw (A62679)
Ellis Band Metal...
2014 Ford F-150 Pickup Truck (A64556)
2014 Ford F-150...
(2) 15.0/55-17 TIRES W/ 6 LUG RIMS (A64280)
(2) 15.0/55-17...
