Adding teeth to a bucket
/ Adding teeth to a bucket #11
My teeth are installed with 2 bolts,, a 10 minute job,,
(most of that time is finding the right size wrench,,, :laughing:)
It seems the teeth stay on the bucket the 8 warmer months of the year,,
then the teeth come off for winter. :thumbsup:
If I were to design a toothbar,, after having this one,,
the teeth would be three inches wide, spaced 1" further apart than this toothbar.
I would want the wide teeth because of the wear that resulted from the first couple hours of use.
I needed to hard surface weld the teeth within 3 hours of installation.
The wider teeth would work the same, but, not wear as quickly.
/ Adding teeth to a bucket #12
My bucket teeth are a mere 1 1/2" wide with 7 ea on my 4' bucket.
After 7 years they show only slight wear (about 1/4" radius) on the corners, and I move lots of rocks gravel etc.
My teeth are welded up with the cutters being tough, I believe T1 steel.
When attacking something big sparks fly.
Mine are a DIY project that turned out good, in fact better than anticipated.
/ Adding teeth to a bucket #13
"If you don't have a tooth bucket, you may as well wear a dress" to quote a good friend of mine.:D
Nice job 'bumkin:thumbsup:
/ Adding teeth to a bucket #14
I wish I had a friend as smart as that Rusty :laughing:
I agree with you on the nice job the bumpkin did too !!
gg
/ Adding teeth to a bucket #15
I had a skid steer with a smooth bucket and a tooth bucket. I rarely used the smooth bucket. Having the tooth bucket was like having more horsepower and more traction. I also did a lot of digging in sod and roots. Having those teeth to tear apart the chunks was great (they would just roll with the smooth bucket). They work like a harrow for back blading for rough finish. I never had any problems backblading to my satisfaction. I suppose if I was leveling sand for final grade for a concrete floor, or for snow removal, the smooth bucket would be better. That said, the tooth bucket got 90% of the use.
/ Adding teeth to a bucket #16
I have both a smooth and a tooth bucket for my skid steer also. I almost always use the tooth bucket as it digs so much better.
It is harder to do on a tractor but on a skid steer you have great bucket visibility. With a smooth bucket you can tip it down and do some really precise work back dragging the front edge of it. For example I spread some gravel right up to the edge of a metal building. With the smooth bucket I could back drag right up to within a couple inches of the building. Smooth also works better for clean up. Hard to pick up all of a pile of something with teeth.
/ Adding teeth to a bucket #17
I agree... I don't know how folks 'survive' without teeth... whether on their bucket or in their mouth! :laughing: Coming from a proud and happy Piranha tooth bar owner.
/ Adding teeth to a bucket #18
Is there any downside?
You loose the ability to clean off a hard surface and in some cases back dragging isn't as good, but the benefits of teeth outweigh the negatives.
/ Adding teeth to a bucket #19
I haven't had any teeth in my face since 1970 and I eat just fine, even corn on the cob. :D
My bucket has had a tooth bar ever since I got the tractor. They are showing a little wear now but will be okay for the next 2 or so years. Shouldn't that be a teeth bar as 'tooth' is singular and I have 7 teeth on the bar. English is confusing. :confused2:
/ Adding teeth to a bucket #20
You might just say that a tooth bar has teeth,
but then would they not be false teeth and is there such a thing as a tractor denturologist?
Welded would be implants as compared to a toothbar that would be an appliance.
Next on the market will be tractor toothpaste, LOL, but then painting the bucked might qualify.
2011 BIG TEX 40 GOOSENECK (A60736)
2011 BIG TEX 40...
Byron 1514 (A60462)
Byron 1514 (A60462)
SKID STEER ATTACHMENT GRAPPLE GRUBBER (A58214)
SKID STEER...
20' SINGLE AXLE INDUSTRIAL TRAILER (A59823)
20' SINGLE AXLE...
2018 HYUNDAI VC2530152-JS DRY VAN TRAILER (A59575)
2018 HYUNDAI...
HIGH END MINI GOLF CART (A58214)
HIGH END MINI GOLF...
