Price Check New Holland TC45D
/ New Holland TC45D #1
missesalot
Brockport NY
tc45d
Hi all,
I am going to check out a 2003 New Holland TC45D today. It comes with a matching loader and sub frame backhoe. The machine has a cab of some sort on it and is listed as having heat, and has approximately 1500 hours. The machine has seen duty on a horse farm, and is listed at 19,900. Pictures look great, and the cosmetic condition is described as good to very good, and the mechanical as excellent.
I am wondering about the price as I see prices all over the place corresponding to a wide range of conditions and geographical desperity. I am mostly feeling that this is a good and possibly great buy. Would love to hear your thoughts.
/ New Holland TC45D #2
The TC models were made for NH by Shibaura and are very reliable workhorses. Parts are still available and should be for a long time. That price is not out of the ballpark for what others are listed at if it is in good condition. Remember that is asking price, not selling price.
Welcome to TBN. :welcome: Let everyone know how it worked out. We have a rule about buying a new to you tractor. No pictures, it never happened, so post a picture if you bring it home.
/ New Holland TC45D #3
I don't know about the price being out of the ballpark.
Tractor House is showing several in that price range without cab OR backhoe.
TractorHouse.com | NEW HOLLAND TC45D For Sale - 11 Listings - Page 1.
That being said those are all seriously lower hour'd machines.
I'd use the clock as a lever to whittle the asking price down some.
I own/run an equestrian facility myself and know the hard hours my LS puts in (w/o dragging a backhoe around)
Enjoy the search. The hard work begins with ownership.
The journey to get there is fun, though.
/ New Holland TC45D
Just got home. The guy couldn't get the PTO to work. Someone dropped a rock on the hood from the back of the loader. Those were really the only things. I believe the pto is more of a how to work it thing because it's never been used, he's going to get with the dealer in the morning. The thing was really tight and solid, more cosmetic blemishes like corrosion on the feet of the backhoe stabilizers and the bottom of the buckets being rusty from sitting on a stone floor in a barn. The cab is an aftermarket cab with the vinyl doors like Jeep soft tops, but the heat works real well. I left a deposit conditional on the pto working and being tested. Will post pics if/when I get her home. That's going to be a project in itself!
/ New Holland TC45D #5
Good luck. Surface rust is usually not a big issue but make sure that is all it is. I store mine with the bucket front edge down so water will not collect in it. To really test the PTO the backhoe will need to come off and an implement like a cutter or tiller put on. Depending on how far away it is and the roads you could possibly drive it home. I have driven my TC40DA 10 miles one way to the shop. I can do that faster than I can trailer it. In Texas a tractor on the road is a common site.
/ New Holland TC45D #6
I have a TC30. The pto was awfully hard to slide the lever forward to get it to run. Previous owner never used it. After using it a few times - goes in without a problem. - Check the bell housing for crakc where the loader or sub frame bolt on. Some people reported problems on tbn. Do a search for more info.
Good luck
/ New Holland TC45D
I heard from him, they were able to get it freed up by spraying some lube into the parts by removing the seat and a panel. Sounds like tcreeley describes. The PTO has never been used .
/ New Holland TC45D
going to pick big blue up tomorrow :) here is a pic
/ New Holland TC45D #9
Nice tractor. If they don't have one buy an owner's manual from a NH dealer. It has very detailed wiring specs that come in handy.
I just got through mowing for the fourth time this year and cleaning stalls. That white stuff on the ground does not look like the same stuff that my horses put down. :laughing:
/ New Holland TC45D #10
That is a supersteer unit, right? You will LOVE supersteer.
/ New Holland TC45D
Yes sir this is a supersteer unit, have not really used it yet as I need to have at least one tire replaced, but that feature seems great
/ New Holland TC45D #12
That's a great tractor, and you got it for a good price. The Shibaura NH tractors are some of the best.
Enjoy it and work safely.
/ New Holland TC45D #13
I have the exact same tractor with the super steer feature.
Super steer is great for short turning radius but a PITA for hooking up quick attach FEL buckets or pallet forks as any last minute alignment steering results in the FEL arms moving opposite of the intended direction. It takes a little practice to get it right the first time but keep trying, you'll get the hang of it.
With respect to the back hoe attachment, the sub frame mount is rock solid but also a PITA to get aligned and attached to the tractor with out making a Castered dolly to store the BH on. It's whole lot easier to roll the dollied BH to the tractor rather than the other way around. Building the BH dolly was time well spent.
Those New Holland blues are great tractors so enjoy your new found friend.
B. John
/ New Holland TC45D
Hey Bud-John, can you post a pic of your dolly? This machine is going to live in the woods for a while so I'd need to study it in hopes of find a way to make it work without a hard floor
Landhonor Plasma Cutter (A66408)
Landhonor Plasma...
New/Unused AGROTK Tire Changer (A65583)
New/Unused AGROTK...
2024 BIG TEX 102" X 25' GOOSENECK TRAILER (A65054)
2024 BIG TEX 102"...
2020 PETERBILT 367 (A65643)
2020 PETERBILT 367...
2010 Rhodes AS3575-3 35ft. 75yd. Tri-Axle Aluminum End Dump Trailer (A64556)
2010 Rhodes...
2019 East Manufacturing 48ft. T/A Walking Floor Trailer (A64556)
2019 East...
