3pt hitch - adjustable side link use & does anyone ever add a second adjustable?
/ 3pt hitch - adjustable side link use & does anyone ever add a second adjustable? #1
rossn
Denver, CO
Massey Ferguson GC1705
On my tractor, I have one adjustable link that attaches to the right lower arm. I think this is called the side link, or the lift arm leveler.
Do I understand correctly that this is primarily used for tilting an attachment to the left or right?
With a small tractor, I'm also thinking about how I can adjust for implements (i.e. subsoiler) that can't be lifted high enough, or drop low enough. Does anyone ever replace the fixed left link with a second adjustable side link, for the sake of lowering or raising the lift range of the hitch?
/ 3pt hitch - adjustable side link use & does anyone ever add a second adjustable? #2
Re: 3pt hitch - adjustable side link use & does anyone ever add a second adjustable?
I've never heard of nor done that. But I see no reason not to if you are needing additional adjustment that your particular machine isn't providing.
For adjustment purposes remember the 3 PT doesn't have down pressure.
/ 3pt hitch - adjustable side link use & does anyone ever add a second adjustable? #3
Both my old tractor and new one (big agricultural tractors) have both side links that can be adjusted.
There is no problem replacing the one you have with a similar to the one that you have on the other side, granted you need to get one that is just as strong.
On a side note, if you're adjusting them often and need more adjust-ability, look into making them hydraulic. More expensive set up but it may only be a bit more compared to getting an OEM side link.
(Assuming you have a hydraulic exit, you would neee the two hoses, 4 connectors and 1 cylinder)
/ 3pt hitch - adjustable side link use & does anyone ever add a second adjustable? #4
If you need to raise higher, sometimes there are multiple mounting holes where the sidelines attach to the lower arm.
/ 3pt hitch - adjustable side link use & does anyone ever add a second adjustable? #5
This arrangement is Three Point Hitch industry standard.
The correct nomenclature is RIGHT LIFTING ROD. The lower arm is correctly a LOWER LINK, less correctly DRAFT LINK.
Adjustable Lifting Rod's purpose is to level implements, left to right, not tilt them.
If you attempt to tilt, imparting different stresses to the right and left Lifting Rods, one will bend or break. Lifting Rods are engineered to share implement loads equally.
Larger tractors, selling at higher prices, have additional Three Point Hitch adjustments for tilt while Lifting Rods are equally extended, and lift height.
Your tractor is a sub-compact with less than 7" of ground clearance. I do not know of any factory subsoiler that will lift and subsoil as you wish on a tractor with less than 7" ground clearance. (Note: This dimension is an "outlier" in subcompact tractor dimensions.)
King Kutter produces a "red" combo Middlebuster and Subsoiler for subcompacts but I would inquire directly of King Kutter if it will work with your tractor, as it is designed around tractors with 9" ground clearance.
LINK: KK Middle Buster
Unfortunately the are limitations that come with sub-compact tractor ownership.
/ 3pt hitch - adjustable side link use & does anyone ever add a second adjustable? #6
That's the inherent problem with a small tractor.....my 2400, case in point. No reason you can't do what you want there. Just test the full range carefully before you hook up and go with anything.
/ 3pt hitch - adjustable side link use & does anyone ever add a second adjustable? #7
Here is an example of using the 3PH arms NOT leveled (at about 5:15): Tractor and Skid Steer Attachment Videos
It might be handy for creating a crown on a dirt road or laneway. I have heard of some folks adding hydraulic top and tilt and putting the tilt cylinder on the side oposite the existing leveler, so (in a pinch) they'd have even greater range of tilt (ie, by adjusting both in opposited directions, one all-in and one all-out).
I suspect Jeff9366 is correct that this puts stress on the lift arms. A bit of tilt for crowning a driveway might be OK, but, the more extreme the tilt adjustment (like the ditching example in the video), the more extreme this stress would be.
/ 3pt hitch - adjustable side link use & does anyone ever add a second adjustable? #8
Tim's 1025 has a similar problem, he used the heavy hitch subsoiler, he got 14-18 inches out of it, if memory serves. It has an adjustable shank, so you can go as shallow as you need to.
Video:
/ 3pt hitch - adjustable side link use & does anyone ever add a second adjustable? #9
I use the tilt adjustment link to make connecting and disconnecting implements easier. Many times when hooking implements up, one arm or the other gets in the way from lining up perfectly. To eliminate this issue, I'll wind the tilt adjustment out so the adjustable side hangs lower than the stationary link. This keeps it 'out of the way' while I back up to the implement lining up the stationary link. Once it is connected, I'll go to the other side and turn the tilt adjustment to raise the other arm up to the level of the pin so it easily slides on.
When taking off an implement, many times once you slide the arm off the pin, it wants to swing back and catch on the pin. I'll take off the adjustable side first, winding the adjustment out so it can't catch on the pin while I go get the other side off.
This old Ford video shows the process in action (I tried to link it in at the appropriate time within the video, but it didn't take. Advance to 1m49s into the video to see):
/ 3pt hitch - adjustable side link use & does anyone ever add a second adjustable? #10
One of the short comings of the small tractors and hitch is the physical length of the lifting rods. Not much length to work with. What you can do is measure the retracted length and the extended length pin to pin and ask Brian at Fitritehydraulics.com if he can do anything with it. You need enough length to make it practical to spend the money on it.
As an example, I can use a King Kutter middle buster on my garden tractor but the sub soil plow is too long. I can't raise it high enough to hook to the hitch. Your 1705 may have longer lower links and you need to measure to see what the lowered and raised dimensions are on your tractor. Keep that handy when shopping for implements.
When all is said and done I am doubtful that your 1705 can pull a sub soil plow at full depth anyway. It would depend on your soil conditions. Sub soil plows make good parking brakes.
/ 3pt hitch - adjustable side link use & does anyone ever add a second adjustable? #11
Both left and right are adjustable on mine and works great.
/ 3pt hitch - adjustable side link use & does anyone ever add a second adjustable? #12
I believe you CAN replace the fixed lifting rod with an adjustable one. I know you can on the Deere 1-series. I may do it myself, for the same reason you mention... to get another inch or two of lift height.
/ 3pt hitch - adjustable side link use & does anyone ever add a second adjustable? #13
Video:
Thanks for linking our video.
As you saw there, we were getting about 16" of depth. Do folks really even need THAT much depth?
The Deere 1025r could not have pulled it any deeper, and was straining to pull it at that depth. However, it did fine at 12-14 inches.
Tim
/ 3pt hitch - adjustable side link use & does anyone ever add a second adjustable? #14
The OP needs minimum of 6" of additional lift. Better 8" of additional lift.
Should he get a full size Subsoiler in the ground, a doubtful proposition, his 1,450 pound tractor, with less than 22.5-horsepower at over 5,000' altitude, will have neither the tractor weight nor power to pull a Subsoiler through high plains soil.
Subsoilers are best used in dry, not moist soil. OP needs at least a 2,600 pound bare tractor weight to pull a full size Subsoiler in dry ground.
/ 3pt hitch - adjustable side link use & does anyone ever add a second adjustable? #15
I agree, the OP's tractor will not pull the subsoil plow at full depth. Ain't gonna happen.
Hi All -- thanks for all the great the responses. Lots of good information and education here!
No doubt, it is a small tractor and will be limited in power, weight, and all that makes a tractor work well :)
Sounds like adding a second adjustable lifting rod would allow me to push the range up or down 1.5" from its current range, which is about 6.5" - 24.5". I just added Pat's easy change hitch, and that added about an inch on the bottom end (and assuming an inch on the top - haven't had a chance to measure yet). I'll see what Massey gets for a replacement adjustable lifting rod -- from what I can tell, the one on the right side should also fit the left side.
As to the weight... with the FEL and ballasted tires, it should be about 2200lbs... still shy of the 2600 mentioned. I hadn't thought about the lower power generation due to the elevation, though that makes sense.
I also have a tiller on the way, and am thinking that once I've tilled (and let the soil compact a bit agian, I might be able to do some sub-soiling that is deeper than the 6" I'll be able to till. Or, if I'm trying to loosen soil for a trench, etc -- multiple passes may work. I did try to run a 12" compact single bottom plow, and learned painfully that the proper soil conditions are key; however, I can see how I'll be limited in weight and power.
All this said, I'm inclined to still get a subsoiler, and see how I can do with the small tractor under various soil moisture conditions. If nothing else, running it shallow might make it an easier first pass (in at least 70 years) on the tiller. I'm leaning toward the North Star/Rankin (USA) one or the NorTrac (China) or AgriSupply (Overseas) subsoiler design, as they all have a similar adjustable design with 14"/19" length and a shear pin. I was also considering the KingKutter, at 2" deeper, but that doesn't sound like it adds value and doesn't have the shearpin (which might not be much value at my tractor's size).
I will also have a look at the heavy hitch from Tim's video, though I'm thinking the hitch may not hold up to prolonged use with the ripper/subsoiler, and... it seems to me that putting the vertical bar 7-8" behind the plane of the lift arms would actually cause a moment (force), which would lift weight off the tires. I have to think about that more.
Question -- if you pull a ground engaging attachment at top, mid, or lower hitch height -- does the pulling power (or safety) change? I'm trying to understand if there is any reason you can't run a subsoiler at any desired depth.
FWIW, my soil is Sandy Clay Loam (60% Sand, 20% Silt, 20% Clay) that hasn't been worked in 60 years.
Thanks!!
/ 3pt hitch - adjustable side link use & does anyone ever add a second adjustable? #17
From my own experience I learned that it is easy to break your Top Link when it is extended long operating a Subsoiler. I snapped my Top Link in half.
At 3" depth a Subsoiler will have "X" draft force. At 6" depth 2 "X" draft force. At 12" depth 4 "X" draft force.
You have not stated how much land you are working. Before you buy too many implements consider if you would not be better off buying a 2,700 pound bare tractor, with a full size Three Point Hitch early on. In Kubota's line, that would be a L2501/HST. However, without knowing how much land you are working I offer this advice without conviction. I am concerned that the odd dimensions of your tractor and Three Point Hitch will be a continuing problem.
Are you making a large Kitchen Garden or a small Market Garden?
jeff9366 - good question! This is for a relatively small personal kitchen garden. For now, about 3500 sq ft., maybe some more later. We'll also be doing a small orchard and re-landscaping the property, as well. For what we have, the tractor is as big as I'd want, though with the drive being a few hundred feet long, wanted something 4wd to also clear the snow and found a deal on the tractor. I did think the subsoiler would be great for running irrigation and electrical around the property, though sounds like renting a trencher may be the better tool for that -- especially if I want to get any of the water line from the irrigation well to be below frost line.
/ 3pt hitch - adjustable side link use & does anyone ever add a second adjustable? #19
Also shop the modular Three Point Hitch cross-drawbar from Omni Manufacturing, a competitor of Heavy Hitch. I think either will be less sensitive to Three Point Hitch geometry than a standard Subsoiler.
Sub Compact Utility Tractor Hitches - OMNI Mfg LLC
OMNI TRANSFORMER 3 Point Ripper - OMNI Mfg LLC
I have a gut feeling a cross drawbar hitch with pin-adjustable ripper depth will provide better depth control on your tractor, relative to tractor hydraulic depth control. Omni is semi-custom and willing to incorporate small modifications at customer request. You may need a reduced size implement.
I like modular, multi-purpose attachments.
Thanks, jeff9366 -- will definitely consider these options contenders for my needs. I hadn't been as keen on these modular units, but can see how they have a lot of flexibility!
