Wheel weights
/ Wheel weights #41
Wheel weight lifters from my projects file.
/ Wheel weights #42
FTG-05<<<<<<<<<<Now I'd call that some darn good redneck engineering, great recipe with very good instructions. I would never think of rebar and plastic barrel. I was wondering what those three outside bolts was for, I see you mount a angle bar to them for mounting on rim, very clever thanks for sharing those pictures.
This will probably be one of my summer projects, how much lead weight did you use?, I'd probably wont use lead, I'd rather use lead for reloading bullets. I know cement is already is heavy but was wondering if adding some scrap steel would help add more weight.
/ Wheel weights #45
I have a heavy floor jack about that same size, think yours will lift a 250 lb. wheel weight off center without tipping over?
Don't know how heavy his wheel weight is, just a picture that I saved.
I would use my shop crane if I needed to do it.
/ Wheel weights #46
This works and is what I do. Weights go on easy. I've also removed a heavy dually pick up bed with one and no problem. It used to take six guys to lift or replace. Shop crane is easier.
/ Wheel weights #47
Also used it with a rope to put a spare tire back up on a gooseneck horse trailer.
/ Wheel weights #48
Oldpath,
The original purpose of the outside bolts holes were for in case I decided to buy Walmart's 100 barbell weights
; I could use those holes to mount them to concrete wheel weights. As you noted, they also turned out to be useful for mounting them.
I used about 40-50 lbs of lead per weight, not really sure how much for each but the 2nd used less, hence why it weighs 20 lbs less (240 vs. 260 lbs).
I got 140 lbs of lead from a reloading friend, but this was lead that apparently was contaminated with something, hence why he didn't want it for bullets.
Concrete weighs about 130-140 lbs per cubic foot. Steel weighs 490 lbs per. Definitely add steel, it will make it heavierr.
Good luck!
What another great idea, having double purpose bolts to add weight also, you're more clever than the average bear. I think this is an outstanding wheel weight design and so simple a caveman could do it. We'll if steel is a lot heavier, I have about 20' of rail road rail that's been through a fire but it's still heavy and it's no good for anything, seems so couple 6" pieces of that encased in cement would work pretty good for weight, thanks for the input.
/ Wheel weights #49
How did you mount the weights on the L39 Rim? I have an L39 as well and I am going to add RimGuard but I was thinking of some weights on the rims as well.
I have about 750 Lbs of weight on my L39 Weights are on both sides of the rim, the inners act as spacers. Weight plus stance adds stability, especially with enhanced hydraulics.
/ Wheel weights #50
You're welcome!
/ Wheel weights #51
/ Wheel weights #52
Without access to a big lathe from a loving place of work and the money one spends for the cast ingot from a place like (Peterson Steel Corporation) then take the ingot to a machine shop capable of machining something that big, I can see $1,000.00/wheel. The cost might be a liitle less if the ingot is cut to fit a tractor without lathe work but I think some big holes still have to be drilled, say like 3/4" size.
So saying that one has 4 ingots at 2" thick x 16" round per side to get the required weight, that some serious 3/4" hole drilling.
2017 Dodge Charger Sedan (A61574)
2017 Dodge Charger...
(2) Titan 21.5L-16 Tires & Rims (A62183)
(2) Titan 21.5L-16...
Safety Basket Forklift Attachment (A61572)
Safety Basket...
Swict 78" Bucket (A62183)
Swict 78" Bucket...
2020 FREIGHTLINER CASCADIA SLEEPER TRUCK (A59910)
2020 FREIGHTLINER...
Midwestern Industries MEV Screen Model MEV 5X10-2 (A63118)
Midwestern...
