bmaverick
Super Member
- Joined
- Sep 17, 2013
- Messages
- 6,954
- Location
- Beloit-WI
- Tractor
- Yanmar YM2610 ■YANMAR GURU■ EXTRAORDINAIRE
I'll echo Kenmac's statement too!
DO NOT use garden hose flushing for any vehicle's cooling system PERIOD. Regular tap water, even semi-filtered, has contaminates that will in time (months) cause galvanic corrosion internally to the system. Distilled water, RO water and even Berkey filtered water passes the needed requirements for the cooling system. I had spent nearly 15-years working for GM in the sciences of HVAC+engine-cooling technologies along with a few US patents over those years.
To do a flush, use distilled white vinegar 50% with 50% water as mentioned above. Run the tractor for 3-5mins on low idle. Drain, flush with 100% water mentioned above. Now add the good ol green stuff premix 50/50. If the first flushing is really dirty, redo the first step.
BTW, NEVER use DEXCOOL in anything. :2cents: That is another story and I can not go into those details. Look it up on the web, the evidence is all there.
