What problems are you experiencing? Does it consume most of the tractor lifting capacity? Or could you solve your trouble with rear ballast?
Actually, after reading all the advice here (and reading a thread in the Kubota section on 3pt counterweights), I'm re-thinking. First of all, I usually always have my Farmi winch on when I'm in the woods with the
grapple...that weighs 700 lbs. When doing the fields, I have the Alamo that weighs 900 lbs. So my net is really only +100 lbs to -100 lbs. The tractor is certainly big enough to handle the
grapple; it just seemed like it was built with too much steel. I guess I should stop whining, given the number of photos I've seen here with twisted Chinese or other lesser made equipment.
Finally, I've got some cost into it. Those that have a similar
grapple will note that from the factory, that
grapple is almost a foot higher on the quick attach frame, raising it well above the shoe of the loader arms. To engage the lower tines at all you had to "bucket out" the
grapple, causing the lower tines to dig into the ground.
I cut the
grapple off the bracket and re-attached it so that when the
grapple is level, it's below any part of the loader frame. It works super well, even in fairly soft woodsy material.
Thanks again for all the advice about the unit. You guys (girls) rock.
