angle iron axle
/ angle iron axle #12
I want to use a piece of 1/4 x 2 x 2 angle iron for an axle. I cut 2 - 2 inch pieces for the ends. Will bore a hole and attach wheels with a bolt.
What is the best way to align the ends for welding?
Without any information other than what you've given us and realizing this is the bare minimum, I'd just weld a piece of shaft in the inside corners of the angle iron and have it stick out far enough to be the axles.
/ angle iron axle
Now that is the ticket. Fits better with my skill level (none) too.
Since I can't post a picture I will try to ease the worry with a few details.
The axles are 18 inches wide
Wheels are 10" HF
Load is 4 x 6 HF band saw
No you will not be meeting me pulling this down the interstate. Will just be going from shed to under my tree.
Thank you all for the help. I'm having one of those days where I can't get out of my own way. But I've been outside in the sun and I'm happy.
/ angle iron axle #14
For inspiration, here's what I do with 10" wheels on my welding carts.
I plug weld the (solid round stock) axle to the inside of square tube.
Terry
/ angle iron axle #15
18" sounds narrow unless it's for ease of storage, as band-saws tend to be top-heavy. Could QA outriggers help at all?
If you mean HFT's pneumatic tires then I'd foam them or expect tip-overs when haulin' 'er out/in.
/ angle iron axle #16
Love them fenders BB !That shop is immaculate . What do you do with all that machinery ? Do you farm , truck , construction ?
/ angle iron axle #17
Thanks! :)
I'm retired from farming and I just putter.
Terry
/ angle iron axle #19
Yes BB, most impressive.
I too like everything mobile. And if not with wheels/castors, with sufficient clearance underneith to get a pump truck under.
/ angle iron axle #20
I am very fortunate to be in a position to dip into my teenage daughter's potential inheritance money.
I think she realizes it is more 'financially advantageous' to let me indulge in my shop activities than put me in one of the sketchy retirement homes she's been threatening me with. :D
Terry
Water Tank (A61570)
Water Tank (A61570)
Giyi GY-TB47 Telescopic Forklift Boom (A60463)
Giyi GY-TB47...
2015 Ford F-350 4x4 Ext. Cab Service Truck (A61568)
2015 Ford F-350...
2019 CAT 259D (A60462)
Tafe 45DI (A53317)
Tafe 45DI (A53317)
Schulte SBW800 Rock Windrower (A61307)
Schulte SBW800...
