Snow Equipment Owning/Operating Backblade vs Landscape Rake For Snow Removal
   / Backblade vs Landscape Rake For Snow Removal #12
I had been raking leaves a couple weeks before,,,
I was too lazy to switch to the blade,,,:laughing:
I get it... I'm always thinking of ways how not to swap out implements. :D
   / Backblade vs Landscape Rake For Snow Removal #13
What do you do when the snow being pulled by the rake builds up and reaches your back tires? You can angle a blade and the snow slide off to the side of your road. Because of the spaces between the tines, the snow just hangs up. I have both a rear blade and landscape rake and I've used the rake for snow once just because it was already attached. Never again.
I'm in your camp. After using the blade I would be hard pressed to go back and use my rake again for snow removal.
   / Backblade vs Landscape Rake For Snow Removal #15
Of course, but you do what you can do. I still love the pic.
   / Backblade vs Landscape Rake For Snow Removal #16
Hello, my Kubota dealer advised me not to push the blade in reverse as it adds additional stress to the 3pt arms and could possibly cause them to bend should I hit a unforeseen obstruction. It sounds like good advise to me. Best, Clay
Yes, you do need to be cautious but... rear mounted snow blowers are very common and they can take a lot of force to push through the snow and you can easily hit something with them as well.
   / Backblade vs Landscape Rake For Snow Removal #17
550 GALLON FLAT BOTTOM POLY TANK (A58374)
550 GALLON FLAT...
2019 MQ POWER WHISPERWATT DCA-25 GENERATOR (A58214)
2019 MQ POWER...
NEW Fork Extensions (A59000)
NEW Fork...
towable floodlights (A56857)
towable...
2017 Komatsu WA500-8 Wheel Loader, S/N A96097, PIN# KMTWA134LGNA96097, Komatsu Turbo Diesel Engine, (A59076)
2017 Komatsu...
2005 EZ-GO Utility Cart (A55851)
2005 EZ-GO Utility...
