Just had a sickening thought
/ Just had a sickening thought #44
My dad was turning into a store parking lot last week and the car stopped. Wouldn't go forward or backwards. Got out and looked, front tire was turned 90 degrees, axle pulled out of transmission, or something like that. If that had happened while he was on the highway, who knows what would have happened.
/ Just had a sickening thought #45
And always watch out for falling anvils.
/ Just had a sickening thought #46
What if your driving down a hill and the steering wheel comes off in your hand and THEN a tire blows out at the same time?
Which then causes you to crash into your barn knocking you unconscious and leaving the tractor running which then kills you from CO poisoning.
/ Just had a sickening thought #47
I think...you think to much.
I would not worry about this.
Each time you hit the road...somebody can hit you and get killed....
We can't wrap ourselves in bubble wrap all the time...just in case something might maybe, probably not, go wrong !
My :2cents:
/ Just had a sickening thought #48
But if you wrap yourself up in bubble wrap, what if the all interior ones pop at once, causing high pressure, contained by the outer layer, and you can't inhale?
Bruce
/ Just had a sickening thought #49
Or what if the bubble wrap gets wrapped around your mouth suffocating you.
/ Just had a sickening thought #50
Decades ago several friends and I decided to take our motocross bikes to a track about 75 miles away. I had a truck so we put 3 in it while a friend with a Honda Civic pulled the other two on one of those real cheap trailers with 8" wheels. I would say we did 65 mph on the interstate. After about 15 minutes after getting there we were putting on our gear and one of the tires on the trailer exploded. It's the first time and only time I've seen this. Of course it was probably the cheapest quality Chinese made tire. Anything can happen but the odds on a tire not just deflating but exploding when just standing still has to be extremely low.
2015 FORD F-550 XL SUPER DUTY UTILITY TRUCK (A59823)
2015 FORD F-550 XL...
Adams 5 T Fertilizer Spreader (A61307)
Adams 5 T...
2016 DRAGON SAND CONVEYOR (A58214)
2016 DRAGON SAND...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
2003 McCormick XTX 185 XtraSpeed Tractor (A61307)
2003 McCormick XTX...
2014 KEYSTONE COUGAR CAMPER (A60736)
2014 KEYSTONE...
