Buying Advice New Mahindra Checklist/Suggestions?
/ New Mahindra Checklist/Suggestions? #1
Gasifier
St. Lawrence River Valley, N.Y.
2013 Kubota L5460HSTC
Hello all. I have ordered my new Mahindra 3550 HST. I have been reading here about Mahindra Tractors, looks like happy owners and some unhappy owners.
I am wondering if any of you would suggest a checklist, or something else, for me to go through with my dealer. I know some of the problems I have read about are making me a little concerned. But I plan on still purchasing and want to try to check on things at the dealership when all the pieces have arrived there. I have asked the owner to call me when all pieces are in and I would come over to see and inspect them all before they put things together. He said no problem. These folks have a good service reputation, and I have purchased other things here as well from Simplicity, Stihl and Husqvarna.
So here is what should be coming in over the next week or two.
3550 HST Tractor (Open Station)
3550L Loader
75B Backhoe
72" Double Piston Grapple
72" Medium Duty Rotary Cutter
Third Function Valve/controller ordered with the new tractor. (Are the newest ones installed at factory or dealership?)
Any suggestions and checklist items would be great. I appreciate it.
/ New Mahindra Checklist/Suggestions? #2
3550L Loader
75B Backhoe
Double check the 3rd function valve. The Mahindra unit is a diverter valve which is fine in my opinion, but waaaaaay to much $$ from Mahindra. $1857 is just stupid expensive when it should be about $900-$1000 installed. I would stay away from a true 3rd function on that tractor if by chance the dealer is going with a 3rd party 3rd function. I had a customer that had a true 3rd function installed on his 3550 HST by his dealer and when ever he used it, it could be felt throughout the tractor. It really was a problem, we changed it out and over to a diverter 3rd function, or at least I provided parts to do the change over, if he actually ever did I do not know for sure.
What size buckets for the hoe? I would go with a 24" & 16" if it were me, but whatever suits you best.
Good luck with your new machine. :thumbsup:
Interesting MtnView. I am not sure if it's a true 3rd function or a diverter. I'll have to ask.
I asked for a 24" bucket. Wanted to have more capacity for dirt.
I hope the backhoe has enough strength for my liking. They came out with a 65B for the new ones. I didn't want it. Told my dealer if he couldn't find me one of the stronger ones I wasn't buying anything. Thankfully he found me a new 75B at another dealer and said he would go pick it up and bring it back. 8 hours away.
/ New Mahindra Checklist/Suggestions? #4
3550L Loader
75B Backhoe
1. Make sure it has the restrictor installed in the EGR cooler bleed line so that it warms up properly. Should get to about the 2nd dot on the temp gauge.
2. There is new firmware for the ECU that eliminates the problem of going into limp mode from "fuel pressure relief valve" opening. Ensure it has the updated firmware.
3. The foot pedal for steering wheel tilt should have a stop welded to it, to prevent bending the piston from accidentally pushing too hard on the pedal. Mine has a stop now, it's on its 3rd piston. Maybe something that the dealer is willing to do for you, or something you can do yourself once you get it home.
4. The fuel tank will collapse itself due to a a vacuum if the cap is installed tightly. I don't have a great solution for this right now - besides leaving the cap a little loose. I slightly modified my tank to prevent this, but it weeps diesel fuel when it's full due to sloshing. I intend to install a tank vent hose with a fuel filter up under the hood, with enough hose that sloshing won't be an issue.
Mods:
1. Depending on what you're mowing, a skid plate underneath is a nice thing to have. I made one for mine, it attaches to tabs I welded on the backhoe/loader arms. I bent a few things before I had the plate, luckily nothing expensive.
2. A sun shade is a nice addition for protection from the sun and weather, and provides a nice place for mounting lights. The factory lighting is pretty terrible. I have lights on the side of the loader arms, as well as a light bar forward/backward on the sun shade.
3. I have a wr long valve on mine, I think it was about $1k installed. It's an electric/hydraulic setup, with a switch mounted in the loader joystick. It's pretty nice to operate.
4. Not sure if you were considering getting the tires loaded - Mine are not loaded, and I use the loader pretty heavily. I put a 2000 lb concrete block on the back for counterweight, which works pretty well. The backhoe can sometimes be a bit light if you're really pushing the loader, especially on hills. I often will extend the backhoe and swing it to one side to help provide stability, but the block is better. I like not having loaded tires when mowing and hauling on the trailer.
5. You will want to turn up the relief valve for the individual circuit for the boom on the backhoe. I have mine set to about 4000 psi. If you do not do this, the boom will drop when using the crowd or bucket functions, when trying to dig stumps or rocks, or when lifting. The main relief valve for all hydraulics into the backhoe was set from the factory at about 2800, I turned it up just slightly to 3000, to match the relief valve for the aux hydraulic valve. You will not be able to overpressurize the hydraulic system by adjusting the individual boom circuit - since the main pressure relief on the backhoe will protect the pump. All it does is lock the boom in place a bit better when using other functions. The lines are rated to 5k psi, I figured 4k was a decent set point - and I've been much happier with the performance after this adjustment.
6. I personally think a quick hitch is essential, and a hydraulic top link makes it that much better. The one from harbor freight is ok, though it requires a little bit of modification to get it onto the 3550 3 point hitch lower arms. Might not be important to you if you're not swapping 3 point hitch stuff a lot, but I move between implements pretty frequently.
If you have any questions on the machine, let me know.
One of these days I intend to start a thread with mods I've done to mine - and include pictures.
Mods:
Whoa. Thank you jb1390! I will discuss these things with the dealer. I thought he told me that the over cooling issue had been resolved with a change in computer settings. ?
I will print this off and make sure we discuss these issues. I'll also make sure we run it there and see it heating up. How long does it take to heat up, and what RPM should I set it at to see it heating up?
/ New Mahindra Checklist/Suggestions? #6
I have not timed it - but I would estimate less than 10 minutes, under light use (driving around under partial throttle).
The 3550 cooling issue is/was not a computer setting. There are other models that do need to be calibrated, but for the 3550 without the restrictor, the coolant temperature is actually low when measured with a thermocouple in the radiator hose. I built a restrictor that fixed it in mine - I believe they were developing a kit, but haven't heard details on the resolution. I can send you some pictures of my restrictor, it's not too difficult to build if they don't have a kit yet.
Thank you very much. I will see when it gets here and I'll ask him about it and see if they know what I'm talking about or not.
Do you have the 75B backhoe? And how do you like it?
/ New Mahindra Checklist/Suggestions? #8
Yes, I have one. I bought it this past summer - installed it myself. In general I like it. Like I mentioned, the adjustment of the boom relief valve made a big difference. From the factory, they were all set at around 3k psi. If you tried to set the boom at one position, and use the other functions to apply force (bucket when prying a rock or root, crowd when lifting, etc), the boom would drop. Bringing that boom relief up to 4k psi made it much stronger, as the boom will now lock into place much better.
Here's a picture lifting an old GM boiler. I would estimate this at 1200 pounds. IMG_20161031_161515194.jpg
Nice! I wonder if they would know how to do that for me at the dealership. Not sure. They have only been selling Mahindras for a few years. And learning as they go.
/ New Mahindra Checklist/Suggestions? #10
I would make sure the dealer checks for any recalls and takes care of them before delivery. I would also check to make sure the bolts and nuts are tightened, pins are in place fluid levels are full, and
/ New Mahindra Checklist/Suggestions? #11
jb1390, with the main hyd pump being set at 2800psi, how is it that you set any of the other settings higher than the 2800psi with any certainty and what good would it actually do when the supply is only 2800psi? :confused:
/ New Mahindra Checklist/Suggestions? #12
The pump isn't "set" at a pressure, since it is an open center system. The pump provides constant flow, and will reach whatever pressure it can until a relief valve opens. The Aux valve (which the backhoe is connected to), was set by the factory at a relief pressure 3000 psi. The backhoe also has a main relief valve, which I adjusted just slightly to also be 3000 psi.
More importantly, bringing the relief pressure of an individual circuit higher will allow you to lock that function in place, and apply pressure using other functions. The increased pressure in that circuit is "disconnected" from the main hydraulic system until you open the control valve for that circuit.
The way I set the boom circuit to 4000 psi is by first backing off the boom relief valve, to decrease the pressure. I believe that I found that 1/2 turn equates to a change of 250 psi. From there, I brought it back to 3000 psi, then turned it in 2 more turns.
Edit: The reason I initially looked into this is because the backhoe functioned different than other machines that I have used. My neighbor has a 410D that I use frequently. When lifting with that, or digging roots or rocks, the boom is the least powerful function (as it is with the 75B). Once the boom is "stalled", you can lift or pry using the bucket or crowd, and the boom would stay where you left it. That would not happen with the 75B until I made this adjustment.
/ New Mahindra Checklist/Suggestions? #13
Cool, now others will know how to go about doing this and getting the same results. :thumbsup:
So if you brought it back to 3000 psi and then went two more turns you are going two more full turns. 500 psi per full turn. Correct? Counter-clockwise to decrease and clockwise to increase?
Hey jb1390, I haven't put eyes on my tractor yet. Still not in yet. Would you mind taking a couple of pictures of said valve sometime when you are not too busy? Maybe one from back a ways and then one a little closer. Then when my tractor comes in I'll give it a try.
Thank you sir, for the suggestions and sharing of experience/knowledge.
And the same to everyone who responded.
I appreciate it.
/ New Mahindra Checklist/Suggestions? #15
I appreciate it.
If I have a chance, I'll pop the cover off the backhoe and take a picture or two. Also, don't take the information I put in here as gospel - I'm going off of memory, so I'm not positive that one full turn = 500 PSI, that's just what I remember. You'll need a gauge installed, I can take a picture of the gauge setup too if I have a chance. Also don't trust that your valves were set the same from the factory as mine - you will need a gauge to be able to adjust it correctly. You can borrow mine if you want to drive to CT :)
Yes. I thought about this some more and what I will do is try the backhoe first and see how it performs. Then make adjustments if needed. Thanks again. I really appreciate it.
The tractor, attachments, and implements have arrived at the dealership. I'm e-mailing them a list tomorrow of these concerns and he said he will check into them. He, and his technicians, know about several issues. One of his techs just got back from more training on the Mahindras.
Thank you gentlemen. If you think of anything else, let me know.
Tractor is in! Be a few more days before its ready. But I should have it before the next snow/Ice we are predicted to get Tuesday afternoon through Wednesday.
I can't wait to put her to work!
/ New Mahindra Checklist/Suggestions? #20
View attachment 497464View attachment 497465
Congrats!
I'm still "working" on my dealer to be able to get the 75B BH. They're telling me that they can't get the 3550 subframe mount from Mahindra for the 75B BH. They're supposed to be making some phone calls today to see if there's any chance to get it still...so we'll see...
2018 Honda Rubicon TRX500FA5 4X4 ATV (A59231)
2018 Honda Rubicon...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A59904)
2017 FREIGHTLINER...
2018 Toro Groundsmaster 7200 72in Zero Turn Commercial Mower (A59228)
2018 Toro...
32in. Hydraulic Tilting Mini Excavator Attachment (A59228)
32in. Hydraulic...
2017 FREIGHTLINER CORONADO SD122 DAY CAB (A56138)
2009 Jeep Patriot AWD SUV (A59231)
2009 Jeep Patriot...
