Buying Advice New tractor purchase.
/ New tractor purchase. #1
Gasifier
St. Lawrence River Valley, N.Y.
Kubota L-47 TLB
Hello all. I have been buying used, low hour machines in the past. Working them for 1-2 years and then selling them. Get a lot of work done with them and then get most of my money back out of them.
This time I have decided to go new. Get a warranty and have a local dealer to service it. I've decided on a Mahindra 3550 HST with QA Loader, QA bucket, QA 72" double piston grapple, a 6' medium duty rotary cutter, and a 75B QA backhoe. (Will add forks later.)
I have read mostly good reviews about Mahindras, but have also read about some people having bad experiences with them, to say the least. Including a few guys here on TBN. And a few who had bad experiences with this exact model. This is making me a little worried.
My tractor has not come in yet, but I did order it. A new one from the factory, or distribution center I guess, will be coming in a few weeks.
I decided to go with Mahindra for several reasons. Strength of machine for its size, weight of machine, side by side hydro pedals I like ( I have a lot of woods cleanup work to do with the loader and trail work.)
But the other big reason is the dealer is close by and I have purchased Simplicity, Stihl, Husqvarna equipment from them before and they have a good service department.
In the past I have owned and operated Kubota, Bobcat, and Deere tractors and construction TLBs. Did not have any major problems with them.
Should I be confident in my purchase of a Mahindra? Or reconsider and go with a Kubota? I am spending a lot of money on this package, but a similar package from Kubota would be even more and from Deere would be, well let's just say too much.
Your thoughts would be appreciated.
My plan is to stick with my decision and my dealer, but I think I'm getting cold feet. Ugh!
/ New tractor purchase. #2
If you wanted a heavy tractor, you ordered it. IF you think the dealer will support you, they stay the course.
/ New tractor purchase. #3
I have a love hate relationship with my Mahindra. For the price - you won't find a beefier tractor. It will lift more, pull more, and handle better than any other tractor in the same price range. Sounds good - right??? Well - hydraulic and coolant leaks have been a problem since day 1. They have finally fixed the coolant leaks, but hydraulic leaks pop up pretty much every time I use the tractor. If it weren't for the leaks - I would love the tractor! Because of the leaks - I contimplate selling it often. I'm not very mechanically inclined and I have a full time day job. I have to rely on the dealer to fix most of these issues. For now I am just dealing with one slow hydraulic leak, but I'm pretty sure that another one will pop up pretty soon. Basically - its a lesson in "you get what you pay for". You aren't going to get Toyota quality from a Kia.
I am use to heavier tractors and TLBs. So I don't mind the weight of this one, it is less than a few I have owned (that's good), and heavier than the Kubota's. With the larger Ag tires it should do well. I think the weight will be good in lifting heavy loads with the grapple and muscling through the pushing and pulling of cleaning up the woods. I have recently had a logger come in and harvest about 40-50% of the trees on our 81 acres, as the woods was way too thick. So I have a lot of clean up work to do. We will be using his logging trails for access and we can now get around and all through the property. Really one of the big advantages. Now I have to clean up, drain, and dress up these trails. And keep them cut/clear. Some will be put into piles and left for animal coverage. Some will be piled and burned or chipped into piles for use in landscaping and gardening.
As far as the dealer goes they have always done well for me. I have never bought a tractor from them. They just became a Mahindra dealer a few years back. But employees in the service department have been to training and seem to be good mechanics/small engine maintenance/gear heads. Whatever you want to call them. They have always fixed my stuff and got it done quick. The place seems to be well respected.
My only reservation is trying a new brand of tractor I am not use to. I know the Kubotas are reliable. That is why I am having a hard time with this.
Sorry about your troubles with your tractor justinramani. What year is your 4035 Mahindra? I hope you have better luck going forward sir. This is my concern. I know the Kubotas I have had have been good. A few leaks here and there, but usually the front axle area. But no major problems. I hate to change my mind and do that to my dealer. I will stay with my decision and if I have problems be a problem solver. Hopefully I will be one of the lucky ones who loves his Mahindra.
/ New tractor purchase. #6
I put in a pseudo-order for the very same setup, minus the attachments. I was told by my local dealers that the 3550's now come with the 65B backhoe and the 75B is no longer available. Are you certain that you're getting the 75B?
Yes. They still list the 75B on the web site as coming with the 3550. But you are correct. I went to order mine and they said the new ones come with the 65B. I ran one of the 65Bs on a different tractor they had on the lot. Nice little backhoe, but I looked up the specs on the 75B and I didn't want one that was less than that. So I told my dealer I really wanted an 85B. Or a 595. If they could find me one. They said not a good idea because of warranty issues. I said I want a 75B then. I will not take a 65B. He found me a brand new 75B at another dealer, and said he would go and pick it up. Will still be under warranty because they sold the 75B with that tractor. I really don't know why they are switching to the 65B. I have not read about any complaints of the 75B creating a problem. Were they tearing the tractors up? I highly doubt it. This is a heavy, 49.5 hp tractor. Should handle that size backhoe no problem. Is the reason just that they will make a better profit this way? I don't know. But I almost didn't go with this tractor because I really would have liked the 85B or the 595. The 85B is more powerful, and the 595 was even a little more powerful. It was a tough decision. I almost went with a Kubota L45. Used one of course, but you can not buy them with Ag tires. I really want Ag tires for the woods and some field work I want to do. I have had the R-4s on a couple of tractors and TLBs before. And most of the time they are good, until you get into deeper snow or you get into mud. Then they just do not have the bite that the Ag tires have. I also pull a York rake behind for finishing areas off, and trail work. When things are getting muddy, the R1s do much better.
/ New tractor purchase. #8
If you wanted a seroius BH the L45 10' hoe that attaches to the cradle type full subframe is in another league compared to a hoe on an AG machine. You would have to use chains or Get Ag tires with new rims. Due to the weight of the L45, with small industrial tires, it is not so good on soft wet ground. I wish they put 10-16.5 tires in front and 43-16 x20 in the rear, with 8 Ply rating. The 595 hoe is not to shabby either.
Yes. The Kubota TLBs are digging machines. I owned an L35 not to long back. Liked it. Sold it to buy a bigger machine for a bigger job, JD210C. Finished that job and sold it. But I need something with Ag tires this time. The Kubota dealer here says they do not put them on the TLBs. I also want a removable loader. Can't get those on the TLBs either. So here I am. They said they could not find me a 595. And I don't think they want to put a new one on this tractor. Nice L39!
/ New tractor purchase. #10
I don't think I have ever seen Ag tires on dedicated backhoes, likely due to the loads/uses -- the Ag tires aren't rated for the same loads and are not as puncture resistant as R4 tires, so I imagine they aren't something most backhoe users would want on construction sites/etc. The same issues probably apply to larger tractor/hoe combinations. For smaller tractor/hoe combinations Ag tires are probably fine.
/ New tractor purchase. #11
Good deal. I'm going to attempt to do the same with my dealer. He said they have some 75Bs on the lot (I assume on other tractors) so I'm going to see if he'll give me one of those instead. If he can't do it then I may end up not purchasing the backhoe and just go directly to Bradco and buy the 509 or 511. I need the reach...
Well. I hope these Ag tires won't be a problem for me with the weight of tractor, loader, backhoe, and grapple or bucket with a load in it.
Do you or anyone else think that will be an issue?
/ New tractor purchase. #13
audsp98
I'd hang that 511 on it and just not get stupid with it like I do, Check frame bolt torque often. 7-1/2' hoe really lacks reach.
audsp98
The 75B has a maximum dig depth of 116" or 9.66 feet. Reach from swing post is 153" or 12.75 feet. I am not as much worried about dig depth and reach as I am about power. Being able to break roots of stumps and pull stumps and rocks. I know it won't do what a TLB will. But I want to have as much power as I can and not void warranty. I considered going with a larger tractor buy you can not get HST or even a full power shuttle on them. And be in same budget range. When I can afford it I will rent a larger Excavator to pull the larger stumps. Maybe in the 33,000lb. size. I will just pull smaller ones with the tractor.
/ New tractor purchase. #15
Yeah. The 65B loses about 2 ft of reach and 2000 of breakout force. I can get that performance from just about every other brand of tractor. The 75B performance set the Mahindra backhoe apart.
Well I had the dealership order my new Mahindra 3550HST two weeks ago. They said it would probably take 2 to 2-1/2 weeks for it to get there and a little time for them to get it all ready to go. They were expecting it in sometime this week. I have been without a machine for over 3 weeks now. :eek: I think this is longest I have been without one in about 10 years. LOL The waiting is slowly getting to me. But I have found plenty of other things to do. Firewood for next year has begun, and I have some logs piled that I can start cutting up on my days off. It sure would be nice to have that tractor with the grapple to pick those logs up with though!
I've put 19 hours on the tractor so far. Moving snow, grappling logs to be blocked up for next seasons firewood, and pushing downed trees and brush off the logging trails.
Up to 250 hours now. Have had several hydraulic leaks, an electrical issue, an occasional hydraulic "bogging down power issue", and worst of all my transmission stopped going into low gear. UGH!
The dealership has been good and either fixed my tractor at my place or came and got it and took it to their shop to fix it. But I'm getting tired of have problems with a brand new tractor.
They currently have it again to fix that transmission low gear problem, a hydraulic leak, and hydraulic bogging down problem.
When all is working right the tractor really is a work horse, but when I can't get a project done because of one issue or another it is very frustrating.
/ New tractor purchase. #19
Sounds like you ignored your gut. I've done that many times. Sometimes you get away with it but when you don't it doesn't sit well.
My course of action would be to get out of the "bad decision" even if it cost some money upfront and consider it money well spent. Life is short and this problem tractor has the potential to get worse.
:2cents:
:2cents:
I have/am considering that. I don't know if the dealer would do anything for me or not. If I have any options. ? It's frustrating though.
When everything is working right it's production is very good. I really like the side by side hydrostatic pedals with the Ag tires. Good power for what I do using bucket and grapple up front. The 75B backhoe has been very good.
Mercury Black Max 150HP Outboard Boat Motor. (A66738)
Mercury Black Max...
Unused 2021 IDeal RC6MD 6ft. Rotary Brush Cutter Tractor Attachment (A66734)
Unused 2021 IDeal...
2017 Ford E-450 Super Duty Shuttle Bus (A66736)
2017 Ford E-450...
2023 Kubota L4802DT 4WD 48HP Utility Loader Tractor (A66734)
2023 Kubota...
2015 PETERBILT 567 TANDEM AXLE DAY CAB (A66091)
2015 PETERBILT 567...
2016 Dodge Grand Caravan (A66738)
2016 Dodge Grand...
