Complete Turf Care
- Joined
- Mar 31, 2013
- Messages
- 2,442
- Location
- South Louisiana
- Tractor
- 2022 Kubota Grand L6060 (no loader), 2017 Kubota Grand L6060, 2011 Kubota L5740 HSTC-3, 1997 Kubota M4700
I managed to test out the system doing some pallet work. My current mount (see picture a couple of posts up) tends to lose perspective when I have the forks down and am looking to drive them forward: of course, this is the position that matters most; having the FEL in any other position I can see things pretty well. I put the camera lower, on the bottom part of the brush guard, but that isn't quite working out either. Note: when I placed it lower I rolled it upside down- reason I'm mentioning this is that with the camera upside down I no longer have to mess with the ROTATE button when I toggle between front and rear cameras (someone in an earlier post had mentioned an issue such as this).
I'm still thinking that I'd like to have the camera attached to the tractor's body rather than the FEL. I'll see if I can mount the camera down lower, below the bottom of the hood.
Pretty impressed with these little Esky cameras.
You might want to try a small ball and socket mount along with a good strong magnet to stick it where ever you need for which ever attachment you're using. That should get you all the mounting flexibility you'll ever need.
Go to post #301 in this thread http://www.tractorbynet.com/forums/...up-camera-50-a-31.html?highlight=#post4092141 and you can see what I did to mount my front camera. I did replace the magnets I bought from CarQuest with some stronger ones I bought online. This mount has worked very well for me. It allows me to mount the front camera on any attachment. And it has never come off while working, except when I raised the loader too high for the wire I had and even then, the magnets did not budge, but the wires pulled out.
