Installed Camera System on Tractor cab, FEL for plowing snow
/ Installed Camera System on Tractor cab, FEL for plowing snow #1
m35techa2
Galena, Ohio
BX1800
Cold out yesterday to cold to be outside but a great day for shop time
converted a new back up camera and 7" tft screen for my Kubota
made a few custom brackets for it as well
/ Installed Camera System on Tractor cab, FEL for plowing snow #2
I installed the exact one you have on my tractor, it works pretty well..
atsah, glad to hear, i wondered for the cost how it would perform....
/ Installed Camera System on Tractor cab, FEL for plowing snow #4
So far so good.. I use it more for seeing behind me when I'm near the road, it also helps some seeing my back blade..
/ Installed Camera System on Tractor cab, FEL for plowing snow #5
Interesting use. I'm curious, how helpful a camera is on the front bucket? Usually you're already looking in that direction. Unless you're trying to see how close you are to a curb? I have a backup on mine that lets me see my hitch which my view of is blocked by the cab, but I never thought of putting one on the bucket.
fatjay, I wanted to mount a camera on the front to better monitor snow plowing on the driveway and roadway, once we get snow again, heck its almost going to be 60 today......
/ Installed Camera System on Tractor cab, FEL for plowing snow #7
I want to put one in the front to make tree excavation more accurate (less messy) and to be able to see exactly where the auger point hits the ground on my hydraulic auger. It might also help me get closer (but not too close!) to the deck or the side of the barn when I'm clearing snow away with the FEL (ie, backdragging it out to where I can get to it with the blower).
/ Installed Camera System on Tractor cab, FEL for plowing snow #8
I need to get a backup camera system for the rear of mine for snowblowing
2024 Linx EQ07018RS (A60463)
2024 Linx...
1997 FRAC TANK 500BBL WHEELED (A60736)
1997 FRAC TANK...
2014 Chevrolet Silverado 4x4 Crew Cab Pickup Truck (A56858)
2014 Chevrolet...
20' DOUBLE AXLE INDUSTRIAL TRAILER (A59823)
20' DOUBLE AXLE...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2003 FREIGHTLINER FL70 DAY CAB (A60736)
2003 FREIGHTLINER...
