What's the Best Farm Truck to Haul my Tractor and Cattle with?
/ What's the Best Farm Truck to Haul my Tractor and Cattle with? #1
BrokeFarmerJohn
Columbus Ohio
2017 Mahindra 5555, John Blue G-1000, Massey Ferguson 98, John Deere GP
Looking to buy a truck, I'm thinking 3/4 ton or 1 ton.
Truck needs to be dependable, easy to work on and maintain (by myself) and cheap to work on.
Basically a good old farm truck, I need it to haul 7500-10k safely.
I had my eye on a 92 4x4 flatbed F250 with 7.3 IDI with 118k miles
My current truck is a 81 F150 with 4.9 strait 6 with 128k miles, it's been a super dependable truck, starts right up and most I pulled was 5200lbs on the bumper a few times hauling round bales on a tandem 18ft 10k trailer which it handled like a champ accelerating lol i wasn't stopping in a hurry. I don't plan to go more with it but my tractor and trailer combo is around 7900lbs plus gear and attachments.
I also will like to note I own an 85 F350 4x4 dully dump truck which I have been going back and forth about setting up to pull with, it's got a 460 v8 and is manual but the cab has been changed to a 93 XLT and the previous owner didn't hook the emergency break up, half the lights don't work and gas tank leaks. Also no hitch.
I bought it as a project/ to make money on and so far got it running good, new calipers, shoes and rubber break lines on the front and will be tackling a rear steel break line leak and gas tank next (when the weather breaks). It has unknown miles prob close to 275-300k (which is a concern) and was used to push snow so it's had a hard life (another big concern for safely pulling). I was gonna haul gravel for my driveway with it and send it down the road being I don't need a dump truck often. I have part concrete drive and wanted to use a 1 ton so I wouldn't bust up my driveway or I would have a big truck haul gravel for me, instead of a bunch of small trips.
I also thought about upgrading my 81 F150 with a class 4 (7500lb) or 5 (10k) hitch, break controller and trailer hook ups since currently it has non of that, no trailer light hook ups at all, but I can do all that for less than $300 but at the end of the day I can't haul my tractor, I can haul more on the trailer though being it had breaks on both axles, the 4.9 had no probs pulling 5200lbs, stopping was the main concern. My next concern will be burning up the automatic tranny in the truck.
Note: pulling on mainly flat ground 1-50 miles one way mostly.
So if you guys or gals have a old truck you beat up everyday and it keeps asking for more, let me know. I'm trying to expand my cattle endeavor and am quickly out growing my current equipment.
Luckily I bought as big of a tractor I did, trucks are much cheaper to upgrade lol.
And doesn't have to be Ford, I have just owned a lot of them and had good luck with them. When a good deal comes along, usually it's a Ford for me anyway lol
/ What's the Best Farm Truck to Haul my Tractor and Cattle with? #2
If it were me I me I would get a 05 or later F350 with the V10. Good power and none of the diesel issues.
/ What's the Best Farm Truck to Haul my Tractor and Cattle with? #3
How many cattle do you have to move?
/ What's the Best Farm Truck to Haul my Tractor and Cattle with? #4
I sold a 14K rated gooseneck to someone with a naturally asperated 7.3. The trailer weighed about 4500 pounds and the buyer at first was a bit put off on how hard it pulled with that non turbo 7.3.
While there are plenty of dually's around, I see more and more cattle haulers stepping up to small IH's, Ford F-650/750's, etc. Older models can be had for much less than late model dually's and while mileage can be an issue, the lack of or reduced monthly payments add up too. One of the issues going this route is a typical open rear, ie; getting stuck on spit.
I had 2 steers and a bull calf in 2016, my first steer goes to butcher the 27th of this month, if I find ground to rent I want to go up to 5-10 this year depending on what I can afford, it's just to make extra money. And I enjoy it.
I still have a full time job that has been financing everything lol.
If I find 50+ acres to rent who knows in 2-5 years I might be up to 40 or 50 head.
It will be some time before I can buy ground, maybe after the tractor and a few other things are paid off. I'm 26 so I have a little bit of time to figure everything out.
That's a pic I took a few weeks ago when I got another calf. So I just have 4 right now, 3 of which will be heading down the road before too long
/ What's the Best Farm Truck to Haul my Tractor and Cattle with? #6
I'm with you on this, I have had four diesel F -350's and they aren't cheap to maintain, the old 7.3 was a good old truck for sure but they are getting old, F-350 all the way towing what your towing.. The only issue I know of with the V-10 was a spark plug issue and manifold bolts would snap off but if those issues are addressed, they are powerful and reliable.. Nothing wrong with a Chevy 6.0 either..
I have also thought about getting a F350 or 3500, I also haul water with my truck year round and I hear diesels don't like to start, run for 10-15 mins and shut down too often
/ What's the Best Farm Truck to Haul my Tractor and Cattle with? #8
The Chevy 6.0 gasser has been proven to be a good powerplant... couple 200-300k mile trucks at work, but you end up with front suspension parts wearing out.
Personally I'm a fan of '99-newer ford powerstroke trucks. My single wheel F250 has hauled my 20' deckover (over)loaded to about 24k lbs combind gross. Crazy as it sounds, I'd rather tow with the F250 (manual trans) than the dually (Auto trans). If you choose to go the Ford superduty route, and want to avoid diesel, the v10 offers simular power/torque in the same chassis. The superduty trucks are tough, comfortable, and readily avaliable for reasonable money. Buy one from down south with little to no rust. My buddy bought an extended cab long bed F250 4x4 7.3 diesel for $2600 from Georgia.
/ What's the Best Farm Truck to Haul my Tractor and Cattle with? #9
I custom haul cattle/horses (part time) from pasture to pasture or to the sale barn with a old beater '98 chevy 3500 DRW crew cab 4x4 454 4.10 gears long bed and 6-8 mpg. The 454 has been "worked" into a strong gazz guzzler tow motor (375hp/500-520 torque). You need a 4x4 for this type of work.
Most road trips I use my '03 2500 quad cab Dodge/Cummins NV5600 3.73 gear 2wd pulling the same 16k triaxle GN stock trailer when making road trips (all paved) out to around 300-350 miles at 12-13 mpg. This truck has just over 300k miles with little maintenance and gets more road use than the DRW.
Both trucks pull several other GN and bumper pull trailers. I even have a GN bed plate in my wifes '16 chevy crew cab 4x4 so she can pony my empty trailers when needed.
No more than your doing a gas engine will work fine.
I'm surprised nobody had mentioned duramax lol my buddy has a 2500HD with a 6.6 turbo duramax that hauled my tractor home and I like that truck a lot, but there a bit out of my price range right now.
Some serious rigs you have there, I'm still undecided on gasser or diesel, I know a gasser will work for my needs but won't get as good of gas mileage.
I feel a diesel is a little less maintenance and break downs but I have never owned one.
/ What's the Best Farm Truck to Haul my Tractor and Cattle with? #12
I had a Chevy 2000 K2500 7.4L and it was a beast, I pulled a 14k lb mini ex on a gooseneck no problems 65mph down the highway. However beware they have issues with the fuel system, the factory injectors stop up and leak plus the fuel pressure regulator goes bad. If you are halfway handy neither are more than a one weekend project to fix. Don't mess with any of the pre vortec 454 trucks the mileage will be terrible.
/ What's the Best Farm Truck to Haul my Tractor and Cattle with? #13
You need to keep your cost down. A used diesel truck worth anything is $20,000. A gas or even can be had for $7500
/ What's the Best Farm Truck to Haul my Tractor and Cattle with? #14
Diesels are the opposite. My Powerstroke oil filter is $22 and it holds 15qts of oil. Air filters are $40 and and you change the fuel filter yearly at $35.
I have been lucky and had no major repairs but 3 years ago my buddy had to put a set of injectors in his 03 Dura Max. It was $6,800.
/ What's the Best Farm Truck to Haul my Tractor and Cattle with? #15
If you do go with a Ford, stay FAR away from the 2003-2007 6.0 diesel, good for nothing. I had two of them because I thought the first one was a fluke but nope, there trouble.
/ What's the Best Farm Truck to Haul my Tractor and Cattle with? #16
I don't know what a "pre vortec" 454 truck is.
I have a 1997 GMC K2500 4x4 Suburban w/454 (7.3L) pulling a 12K load (combined GVW 20,650).
My Suburban has 130,000 miles on it (I bought it with 100,000, on E-Bay 10 years ago).
The mpg is rather poor (9.6), but I tow less than 1500 miles per year.
If the mileage was exceptional, at 15 mpg., the gas saved over 1500 miles. would be only 56 gal.,($130?) certainly not anywhere near justification for buying a newer 14-15 mpg vehicle.
The 7.3L(454) does not seem to have any problem performing the desired task.
No tailgating, and electric trailer brakes properly set, are important considerations.
/ What's the Best Farm Truck to Haul my Tractor and Cattle with? #17
Around here it's Dodge Cummins, older Super Duty 7.3Ls and then Duramax. In that order. 10 Dodge Cummins for every Duramax.
Yeah I can't tell you how many people around here that dumped loads of money in a 6.0 powerstroke, I like Ford a lot but that engine made me cautious of the powerstrokes all together. I'm not dumping 1000s into any motor, cheaper to take a loss and buy another truck.
I read somewhere that Cummings is king when it comes to pulling but there super expensive to fix, the IDI 7.3 is really cheap to fix but low on power and the older powerstrokes were a happy median, middle of the road power and repair costs weren't terrible.
I never researched repair costs of either but I remember reading that a few days ago.
/ What's the Best Farm Truck to Haul my Tractor and Cattle with? #20
Couple months ago my youngest Son bought an '05 F350 crew long bed 4x4 6.0L AT truck with 180K miles. Very straight Lariat truck. No engine repairs had been done. Paid $3200. Brought it home and discovered it was drinking water. Tore it down and did all the mods and deletes. Spent $1800. All the diesel guys say he now has a very dependable diesel engine. He's in for $5000. Pretty good investment. Time will tell. :)
2015 TEXAS PRIDE TRAILER  30 FLATBED GOOSENECK TRAILER (A58214)
2015 TEXAS PRIDE...
Unused SDJ-4000 9,000lb Two-Post Electric Auto Lift (A55851)
Unused SDJ-4000...
TRACTOR SHEDDER (A60736)
TRACTOR SHEDDER...
2013 PETERBILT 389 SLEEPER (INOPERABLE) (A60736)
2013 PETERBILT 389...
2015 BOBCAT T770 SKID STEER (A62129)
2015 BOBCAT T770...
2012 Kia Optima Sedan (A61569)
2012 Kia Optima...
