lilranch2001
Super Member
- Joined
- Nov 25, 2009
- Messages
- 9,142
- Tractor
- Bobcat CT 235
Hopefully you find it intact
Loader is on I started it at 4:15 and used it with the pallet forks to unload the bucket at 5:45. Was gonna snap a photograph but my phone died. Nice but seems super jumpy gotta play with that some more and get her lubed up.
I had very little play time missus was calling for supper and I was trying to clean up before I came in. Tomorrow I'll use it to move wood to the porch more play time then but first I need to lube it up and go over all the bolts.Every Bota loader I have used seems pretty precise
Hope yours works well
Yeah I'm going to have to see how it goes I'm not new to hydraulics I have run grand dad's ford with bush hog loader extensively and I run all types of equipment at work particularly a lull and this thing is fast, I flipped my bucked up in the air like a coin by accident when I went to put it under the equipment shed.Congrats!!!!
My Brother had an L3240 with FEL. It was horribly jumpy. I never did get used to it for delicate work.
Yeah I'm going to have to see how it goes I'm not new to hydraulics I have run grand dad's ford with bush hog loader extensively and I run all types of equipment at work particularly a lull and this thing is fast, I flipped my bucked up in the air like a coin by accident when I went to put it under the equipment shed.![]()
Have you run the cylinders back and forth to the end of their travel a few times to bleed them? Having a slug of air in the cylinders can cause that and it usually takes 5-8 cycles back and forth to the end of their travel to push it all out.Loader is on I started it at 4:15 and used it with the pallet forks to unload the bucket at 5:45. Was gonna snap a photograph but my phone died. Nice but seems super jumpy gotta play with that some more and get her lubed up.
No I haven't I will when I get home as soon as I get it greased up.Have you run the cylinders back and forth to the end of their travel a few times to bleed them? Having a slug of air in the cylinders can cause that and it usually takes 5-8 cycles back and forth to the end of their travel to push it all out.
Aaron Z
I picked up 2-1/2 gallons of UTD while I was at the dealer yesterday already planning ahead.After you cycle the air out of those cylinders it would be a good idea to check the hydraulic fluid level. They could easily take a couple of quarts to fill up.
Glad it's working out for you!!!! Don't worry about the "Stupid Human" trick. Every one of us have done something similar!!!!! Thanks for posting the pics.![]()
