Rear Ballast Close to or Far out from the tractor??
/ Rear Ballast Close to or Far out from the tractor?? #1
nightdevil
Upper Marlboro, Md
JD 1025R FILB
So I finally got what I think is everything to make my own barrel ballast box. This forum has so much on ballast boxes that its great!
I planned to do something like mikes... http://www.tractorbynet.com/forums/build-yourself/347445-ballast-barrel.html
So I got all my parts and I also picked me up a quick hitch along the way. So this has me thinking. Should I keep the barrel close to the tractor and set the drawbar nearly in the middle or create a way to set it so that I can use the quick hitch?
I figure that setting it out would help with the FEL but I need (or i think I need) it more for traction in the snow (crossing fingers). Yes it would be nice to change implements with the quick hitch but being new to this and welding I believe it requires more pieces/parts/time.
So with that said I guess I have a couple questions.
1. Does the 1-2 ft make that much of a difference? (close to the tractor vs offset with the quick hitch)
2. What would be the best way to create something to off set the barrel for a quick hitch? extension pieces I could weld? I'd prefer to go this route but wouldn't mind trying a basic ballast box first.
/ Rear Ballast Close to or Far out from the tractor?? #2
Once you bought the QH your path is destined.
Design every 3pt piece of equipment to fit the QH. Never take it off. In the end you will consider it an easy chore to pick up the ballast box, use it, set it back down, all without leaving the tractor seat. Why would anything else be considered??
/ Rear Ballast Close to or Far out from the tractor?? #3
If I were you, I'd think about multi-functional counterweight. Example, heavy attachment, or a box, which could be used either loaded with rocks or a piece(s) of concrete, or with water barrel(s) inside. The closer to a tractor you'll make it, the less 3pt hitch lifting force will be needed. It means, the heavier it could be. That box you'd be able to use for the other purposes.
Best solution might be, that you could have a possibility to adjust it's weight.
/ Rear Ballast Close to or Far out from the tractor?? #4
+1 on this way!!
/ Rear Ballast Close to or Far out from the tractor?? #6
+3
You'll be modding all your stuff to fit the QH rather than taking the QH on & off.
I built my busted 60 gallon compressor tank into a ballast box. There is a notch for the QH top hook not a mount for a normal toplink. Haven't put Cat3 bushings on the 3pt bar I welded on for the lift hooks. May or may not put those bushings on at some point.
Weight further back will unload the front axle & put weight on the rear. It will move the weight/traction from one axle to another, but won't change the net traction. A foot or 2 will make a bit of difference. How long is a crowbar, even a small one? It makes a big difference on leverage. A few feet compared to the length of the tractor infront of the rear axle is a lot less though, but it will make a difference.
The best ballast I ever had was my 60" rotary cutter. Even better putting several 50lbs bags of stuff back by the tail wheel. Really unloaded the front axle so I didn't feel bad maxing out my loader moving big bales on my old L3200.
If you are looking for maximum traction you need to go heavy as possible. Moving weight back onto the big rear tires may generate more traction than sitting on the smaller fronts. Not sure on that though.
/ Rear Ballast Close to or Far out from the tractor?? #7
Be careful how heavy you make your ballast box. I had 1000 lbs of cast weights on my three point hitch. I then added a quick tach. That moved the 1000 lbs 4" further back and I couldn't dig properly at all. A 1" stone was enough to lift the bucket out of the ground while digging. I took 400 lbs off and what a difference. You can always add more weight to a ballast box, but if you make it permanent then it's hard to remove.
Any recommendations on how to make a 3pt hitch lift points for on a barrel? Do they sell lifting points/arms I can weld on?
/ Rear Ballast Close to or Far out from the tractor?? #9
Easiest is a cold roll rod thru the barrel and a top link bracket sticking out the top.
This is what I'm thinking
2011 Toyota Camry Sedan (A56859)
2011 Toyota Camry...
2012 INTERNATIONAL PROSTAR+ (A58214)
2012 INTERNATIONAL...
JLG 20MVL MANLIFT (A58214)
JLG 20MVL MANLIFT...
2000 CATERPILLAR 988F WHEEL LOADER (A60429)
2000 CATERPILLAR...
2016 TEXT 26ft T/A Dovetail Flatbed Equipment Trailer (A59230)
2016 TEXT 26ft T/A...
Iranch IRGC40 (A60463)
