1963 Case 530CK Backhoe/Loader
/ 1963 Case 530CK Backhoe/Loader #122
Wow. Stan, your workmanship is incredible. I LOVE it! Nice work.
Terry
Terry
Thanks Terry for the very kind words. It really has been fun but labor intensive and time consuming project, I'm working on several new picture presentations with description posts and will be putting them up shortly. I'm going to be taking a bunch of pictures of the backhoe outside in it's no scratches condition before I operate it, because I know it will never look like this again! I'll share a series of these too.
/ 1963 Case 530CK Backhoe/Loader #124
Very nice! Would you be able to post a short video of it running when it's ready?
Well Mancelona Man, another forum member ask the same question earlier in my project. I guess I don't have any qualms in posting a video, but I have never done that process before and don't know what it entails, so I'm open for suggestions. As of now I don't own a movie camera, but was considering one of those new Go Pro types. But, I don't have a clue as to how to post a video. I suppose I can research the internet and check YouTube. I just have never had a reason to do this before now. Thanks for the question.......
Here's one taken late this afternoon.
/ 1963 Case 530CK Backhoe/Loader #127
Better than new! Great job!
I agree^^^, most times when a full restoration is done the machine IS better than new.
My only concern would be with clay type soils the narrow bucket could plug up. That said the existing bucket is much larger radius than on my 110 and should dig faster.
You know jenkinsph, you bring up a valid point. That bucket is smaller than I would like but when I bought the hoe it only came with this 12" and a 36" bucket . I made some modifications to the 12" (my brother) welded on some old worn cutting bar stock onto each side of the bucket to widen it to 16". At the time I built my shop and dug the footing, my neighbor was building his as well. So we made this modification to the 12" bucket to dig his footing. His plans called for a mono-pour with a 16" wide foot that poured with the slab. Anyway, I've always wanted find a 24" bucket for mine, maybe I'll find one sometime.
/ 1963 Case 530CK Backhoe/Loader #129
If you have trouble with cleaning out your narrow bucket while dumping I've seen buckets where the owner has welded a heavy chain inside the bucket. One end gets welded on just behind the teeth and the other end close to the top where the pins are. The idea is that the chain is long enough to lay flat against the back of the bucket while digging and then as you dump it's something that helps the dirt to fall out. It's also something to rattle around inside the bucket to encourage the mud to fall out.
/ 1963 Case 530CK Backhoe/Loader #130
I find it helps to not "curl" so much to totally load your bucket. Try to dig flatter (like following the bottom of the trench) as looser material will fill the bucket.
This may seem inefficient as opposed to taking one big scoop while curling but then shaking the bucket to unload is also.
Another thing that works sometimes is stop dipper travel when the bucket is half full. Reverse direction a few inches then continue filling the bucket. This may help alleviate some of the suction in clay.
Here's my JD resto. Not as nice as your Case. :)
Terry
Hi pmsmechanic, That's pretty interesting and a novel solution to sticking clay. You know, I have never had too much trouble with material sticking to the inside of that 12" bucket but that's an interesting suggestion. Most of the dirt and clay here where I live is what's known as Caliche. It's so darned hard that it's hard to break through it and it doesn't stick to anything, it's like rock! I came from northern Idaho and the clay there was real bad for sticking in buckets. I remember when I was contracting how much the wet clay mud stuck to everything including my Carhartt pants. Thanks very much for the suggestion, I would be willing to try that!
Terry
Hey Big Barn, thanks for the picture of your excavator. And I'll tell you what; it looks every bit as good as my resto! You also had a much bigger job as well.
And your suggestion to not "curl" so much I have tried when digging. You know there are so many little tricks that you learn along the years that a guy adopts and really don't realize you are doing it as you are doing it. I worked around this one operator back in the 70's & 80's and he was just like watching a ballet dancer at work the hoe was just an extension of his hands and arms. I could never hope to work at his level but he taught me a lot over the years...... just watching him as he moved dirt!
/ 1963 Case 530CK Backhoe/Loader #133
Beautiful job! Thanks for taking the time to post your progress through the restoration. I've enjoyed watching it come along and enjoyed your skills as you made the needed parts.
Here are some pictures of the backhoe main frame housing; cleaning, prepping and painting.... My overhead crane was really indispensable for this part of the restore. The metal is so thick and massive that you just can't maneuver it for all the operations that I needed to do, without an ability to lift, swing, tip the part.
This is a shot of the housing upside down and I was stripping paint, chasing threads and prepping for later welding.
Most of the paint off the sides, then lacquer thinner was applied by rag, to clean any remaining grease and paint dust off. I used these really neat paint removing disks on my 4 1/2" angle grinder. For me, it was less messy than liquid paint remover and faster to remove paint and rust.
Just a shot of the right side and still upside down.
Ok, I now have the housing cleaned up and back over behind the tractor, and checking the alignment of the two bores that connect with the tower. Somehow, the upper flat had been bent up and by using a solid straight piece of round 2"bar I was able to see the problem. The lines on the flat shows where I had to heat it, then bend it down for the final alignment. Man that thick iron soaked up the heat. I turned up my largest rose bud tip and it took a long time to get it to a bendable temperature.
This one shows how much it was off. The bottom (self-aligning) bushing was in it's housing and 2'' round bar was about 1/2" off of the bore. I have no idea how you bend an over 1" thick flat stock. It's just that after installing all the new bushings nothing would line up, which means that there was an awful lot of play in all of my connection and now I know why everything was so loose!
This one is just for perspective, show how I was using the crane to align parts.
After machining the pins, bushings and such I now have the right tension set on the bottom pin-bolt and it really rotates nice!
Got the valve body cleaned, painted and bolted up, ready for the levers.
This is a good angle of the boom holder that I designed and fabricated. It really came in handy as a crane connection for moving this part around. It made it so that I didn't have to scratch paint with my lifting chains as I was positioning the heavy thing.
This picture is just showing it's time to hook it up with the docking bars on the tractor.
I've got several more posts that I'm working on to show you guys before I make may final presentation and maybe I'll still get another one out later today, thank you all again.....
/ 1963 Case 530CK Backhoe/Loader #135
Thanks! I've really enjoyed following this thread.
Thanks Terry, I'm glad that you find it entertaining and hopefully helpful.......
I thought maybe I would include a post on one of the tools that I machined to help me with my threading. As I got into this project I found that I needed more than one threaded rod, so out of necessity I made this. I was looking all around the internet and found several designs for threading rod stock. Kind of copied the principal from a site that was selling them complete, but since I have several different diameters of dies I decided to make my own to accommodate my needs . I had a bunch of round bar of different diameters laying around from extra stock that I was using for pins and so I made the various parts:
This will give you a idea of the size of the rod threader. The main shaft, just North of the ruler, has a taper machined on it to insert into my tailstock on the lathe, which is a #3 Morse taper. The handle and fitting just above the main shaft is what holds either the die or tap. And the last piece above the handle is the adapter for holding the different taps.
The handle is now mated over the main shaft and will slide back and forth for about 5" and still be contained and not fall off the shaft.
Now all of the parts are together so you can see how it is set up when in operation. A guy can then slide the handle with the insert and die into a pre- bored hole mounted in the lathe as it is spinning. You then grasp the handle and hold it while the lathe turns and go as deep as you want until either the depth that you are threading has been reached or until it gets too hard to hold. Just release the handle and it will continue to spin on the main shaft but because it is spinning without resistance now nothing is damaged. You then reverse the lathe, hold onto the handle and back it off until you are completely out of the bore. When you thread a piece of rod, that same principal applies. All you have to remember is to release the handle and you won't get wound up in it. The knurling on the handle helps a lot with oily hands.
Just a final shot to show the inserts (die, tap) that can be used. I can thread anything between 6-32 (all metals) to about 1/2x13 threads both course and fine. I made a hex insert that will hold my metric 6 sided set as well. By the way, I thought you should be aware that hand driven threading only works for 5/16" rod stock and smaller, anything above that I mount a lever into the handle and let the handle ride on my lathe carriage to protect my hands.
I've got a cylinder insert that I designed and fabricated to press dents out from the inside of a cylinder that I'll do a write up and pictures. Thanks.
/ 1963 Case 530CK Backhoe/Loader #137
That is a tremendous amount of work with great pictures.:thumbsup:
/ 1963 Case 530CK Backhoe/Loader #139
Hi Stans1
Awesome write-up. I will be replacing the upper and lower bushings in my 1961 Case Backhoe, model 42, and in my service manual the self-centering bushing you refer to is called a "Pivotal Ball Type Bushing". These terms are new to me. I quoted the paragraph where you state you were fortunate to find a replacement bushing. Would you have a part number for it and location where you bought it? I rebuilt my case-o-matic and learned a lot about that if you are in need of any details about that.
"Here are the finished products and you can see how they compare with the old worn out pins. Also you can see how broken the self-centering bushing housing was that I removed from the frame. The new one is to the left of it for comparison. I felt real fortunate to find a new replacement bushing, because I don't think they use that type of bushing any more in the newer hoes and that's something that I could never have manufactured!"
Hi Stans1
Hi Cariboo4x4,
Thank you for the kind words, here is the part referenced in my post:
D2361 New Case Dozer 115B 115C 115D 115E 115G Self Aligning Bushing | eBay
I'll give you more information tomorrow, stans1
F-150 4WD (A63689)
F-150 4WD (A63689)
1999 FONTAINE FLT-7-35HBTW LOWBOY (A62613)
1999 FONTAINE...
(1) HD 24ft Free Standing Corral Panel (A65579)
(1) HD 24ft Free...
Skid Steer Mount 3pt Adapter  (A62679)
Skid Steer Mount...
(2) New 26X9-14.5 severe duty batwing tires on 5-lug batwing rims, Coal Valley, IL (A65640)
(2) New 26X9-14.5...
2008 JLG 3246ES 32ft Scissor Lift (A64553)
2008 JLG 3246ES...
